09-18-2016, 10:03 PM | #76 |
Re: 1972 Blazer 4WD to 2WD conversion in Texas.
Some photos of the truck outside the house.
09-18-2016, 10:08 PM | #77 |
Finished air intake system.
09-18-2016, 10:14 PM | #78 |
Photo session.
09-19-2016, 01:21 AM | #79 |
A guy with a truck
Such a nice truck. I like the brace you used on the intake--clean!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-19-2016, 07:39 PM | #80 |
09-19-2016, 10:40 PM | #81 |
Thanks. Intake is a modified Spectre kit. I cut the brace off another location on the tube, had it welded at the new location and had the tubes re-polished. Tried to keep it as simple as possible.
09-19-2016, 10:46 PM | #82 |
elkniks
Had to wallow out the holes on the front of the frame a little but other than that it lined up pretty good. Both bumpers are replacement Premium Chrome Bumpers from LMC. |
11-24-2016, 02:32 AM | #83 |
Testing and modifying engine covers, changed A/C compressor bracket and installing overflow canister.
11-24-2016, 02:39 AM | #84 |
Modifying spare tire holder and paint underside of hood.
11-24-2016, 02:47 AM | #85 |
Finish fiberglass work and paint hatch black.
11-24-2016, 02:50 AM | #86 |
Change outside hatch color to white.
11-24-2016, 02:55 AM | #87 |
Color sand and buff.
11-24-2016, 02:58 AM | #88 |
Finished color sand and buffing, heading back to San Antonio.
11-24-2016, 03:04 AM | #89 |
Install parts and rear chrome.
11-24-2016, 09:17 AM | #90 |
Just ran across your conversion. That is quite an impressive transformation and timeline. Just Awsome !
11-24-2016, 11:12 AM | #91 |
A guy with a truck
Looking good! Why the need to knock the nubs off the tire rack?
11-24-2016, 03:15 PM | #92 |
gringoloco
I modified the spare tire holder to fit the larger 275 60 15 tire. The bumps would push into the tread before the modification. |
11-24-2016, 04:34 PM | #93 |
very thourough what harness are you running that allows the bulk of the harness to run behind the engine and placing of pcm under the seat??? very niCE.
11-24-2016, 07:39 PM | #94 |
I've never heard of a "Vortec Max" ! Which trucks used this engine ? Might be a US only available option.
11-24-2016, 08:00 PM | #95 |
hemi43
I saw an LS Swap here in San Antonio with the Vortec Max covers and i knew that was the direction I wanted to go. It looks like the Vortec Max was an option on the chevy silverado's. I am working on a new set of covers. Attached is a sneak peak. |
11-24-2016, 08:55 PM | #96 |
Cool!! I have never seen the side covers that go over the coil packs. Looks good.
11-25-2016, 12:33 AM | #97 |
Purchased the first set of covers (Post #83) from GM Parts Outlet
12597908 20.75 Drivers Side Cover 12598332 39.46 Center Cover 12574573 35.31 Passenger Side Cover 95.52 Plus Shipping |
11-25-2016, 12:48 AM | #98 |
bL.A.zer90045
There are a few companies that fabricate LS Swap harnesses. I used Speartech because a friend purchased his harness from them and he was happy with the product. Once I spoke to Speartech on the phone I felt they understood the modifications I wanted and the price was about the same as everyone else. I had the MAP sensor exit the harness on the drivers side, had the harness made 6' longer to reach under the drivers seat, and had Speartech wire in a 3 wire oil sending unit to be compatible with the Dakota Digital Guages (2002 stock is 1 wire). The 2002 computer does not sent the correct signal for the 3 wire oil sending unit so that modification did not work. I ended up not plugging in the oil sending unit connector and used the Dakota Digital oil sending unit wire harness that was provided with the instrument cluster. |
11-26-2016, 12:46 AM | #99 |
Inner fenders painted and final engine covers installed.
11-26-2016, 08:39 AM | #100 |
Big Block
A work of art. Looks like first rate craftsmanship. Just beautiful. Quite the accomplishment in such a short time. Your hard work certainly paid off. Just WOW! :-)
