Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-22-2020, 02:53 PM   #76
ajgriffin
ajgriffin's Avatar
Re: 72 Plaid Sub
I hate that I discovered the push on seals AFTER I had already purchased the glue ons.
You think you'll make the Git Down with the Plaid Burb finished this year?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 05-22-2020, 03:30 PM   #77
Heliarcn
Re: 72 Plaid Sub
Yes, hopefully things are somewhat back to normal by the Git Down.
Bret
1972 Chevy Suburban
1976 Blazer
Heliarcn is offline   Reply With Quote
Old 05-22-2020, 03:54 PM   #78
Heliarcn
Re: 72 Plaid Sub
Had to do some adjusting on the 3rd door window frame to get it to match the other door gaps. Had to cut it loose, manhandle it a little, and weld it up.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-22-2020, 04:01 PM   #79
Heliarcn
Re: 72 Plaid Sub
Everything in high build primer but the hatch. Mine was rusted beyond repair.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-22-2020, 04:20 PM   #80
Heliarcn
Re: 72 Plaid Sub
Somewhere around September 2019 at this point. Got all the body work looking good and decided to pull the cab off the chassis and put it on a rotisserie to finish the floor and paint the roof. Probably should have done this earlier, oh well.
For the record, I was never comfortable flipping that cab over! I couldn't get rid of that rotisserie fast enough!
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-22-2020, 04:25 PM   #81
Heliarcn
Re: 72 Plaid Sub
I sprayed 2 gallons of the Lizard Skin ceramic insulation and another 2 gallons of the thermal insulation on the bottom. Here is is sealed up, but I can't find the Lizard Skin pics anywhere.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-22-2020, 04:38 PM   #82
FLYNAVY30
Re: 72 Plaid Sub
Man, I didn't realize the body lines on ANY Suburban could be that straight....looks great!
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
FLYNAVY30 is offline   Reply With Quote
Old 05-22-2020, 04:58 PM   #83
Heliarcn
Re: 72 Plaid Sub
I don't think they were ever meant to be! Thank you.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-22-2020, 09:40 PM   #84
FLYNAVY30
Re: 72 Plaid Sub
certainly not, but the fact that you got that much real-estate straight as an arrow is quite the accomplishment!
1972 C20 Suburban
1964 Corvette Coupe
1997 Lexus LX450
Old 05-23-2020, 12:47 PM   #85
CG
BlahBlahBlah
Re: 72 Plaid Sub
That is a nice looking rotisserie. Doesnt look like it would be the least bit sketchy.
Old 05-26-2020, 09:47 AM   #86
Heliarcn
Re: 72 Plaid Sub
It was really nice, just a lot of rotating mass there. I had done tons of metal and body work at that point and any accidents would have been real set back.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-26-2020, 09:49 AM   #87
Heliarcn
Re: 72 Plaid Sub
Thanks!!
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-26-2020, 10:33 AM   #88
Stickman
Stickman's Avatar
Re: 72 Plaid Sub
Beautiful work and I agree with some of the others, that is a lot of real estate to body work. I'll bet you had a few hours invested. Very nice.
Stickman is offline   Reply With Quote
Old 05-28-2020, 11:13 AM   #89
Heliarcn
Re: 72 Plaid Sub
Yes, lots of hours!. Thank you.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-28-2020, 11:17 AM   #90
Heliarcn
Re: 72 Plaid Sub
I decided to have some custom emblems cut for the burb. Late last summer I was contacted by Street Trucks to be part of a "Rendering to Reality" article they were doing.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-28-2020, 11:22 AM   #91
Heliarcn
Re: 72 Plaid Sub
Getting the frame together after powder coat. Spraying some paint on the motor and trans. September/October 2019.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-28-2020, 12:52 PM   #92
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 Plaid Sub
Lookin' good! Congrats on the magazine article too.
LockDoc
Leon
Old 05-28-2020, 04:13 PM   #93
Heliarcn
Re: 72 Plaid Sub
LockDoc
Thanks LockDoc. I still need to have you rekey my blazer tailgate at some point.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-28-2020, 04:19 PM   #94
LockDoc
LockDoc's Avatar
Re: 72 Plaid Sub
Just let me know whenever you are ready.
LockDoc
Leon
Old 10-02-2020, 12:49 PM   #95
WannaBe68
WannaBe68's Avatar
Re: 72 Plaid Sub
This Burb is looking great!
If I may make a suggestion. Get some of this radiant barrier from Aircraft Spruce. It is used for airplane firewalls and I put it on the underside of my trans hump. Aluminum facing the trans. It is peel and stick and I can honestly say that it COMPLETELY changed the temp at the hump area from unbearable to basically no heat at all. it is simply amazing how it literally is night and day different. The adhesive is rated up to 300 deg...and it is rated to reflect up to 2,000 deg! It is thin and light weight...
I also covered the underside of my roof and it turned the inside of the Burb from an oven to very comfortable!
https://www.aircraftspruce.com/catal...atbarriers.php
WannaBe68 is offline   Reply With Quote
Old 10-29-2020, 06:23 PM   #96
1956cameo
1956cameo's Avatar
Re: 72 Plaid Sub
Amazing build! The work going into this one is on a whole other level. Looking forward to seeing this one getting done. I also really love that red and white Blazer in the background of a few shots.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 05-11-2021, 11:14 AM   #97
Heliarcn
Re: 72 Plaid Sub
Back working on the burb. Inside of the cab and jambs in epoxy. Then 70s Catalina Blue Metallic.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-11-2021, 11:23 AM   #98
Heliarcn
Re: 72 Plaid Sub
Aluminum hard lines for the air. Fuel and brakes in stainless.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-11-2021, 11:28 AM   #99
Heliarcn
Re: 72 Plaid Sub
Touchdown. The cab is back on the frame. That metallic blue looks amazing in the afternoon sun.
Bret
1972 Chevy Suburban
1976 Blazer
Old 05-11-2021, 11:35 AM   #100
Heliarcn
Re: 72 Plaid Sub
Finally getting some parts painted. Inside of the wheel tubs and bumpers epoxy and bed liner.
Bret
1972 Chevy Suburban
1976 Blazer
