Old 10-21-2018, 09:59 AM   #76
Moscowmule
Re: building a mule
Originally Posted by LT7A View Post
Moscow, you're sure giving that thing the treatment. Was the undercoat on the frame meant to protect it from chipping? Looks nice. Are going to scrape it off where things bolt to it?
when i put the por 15 on it looked fine although there were a few spots with runs. por 15 has no uv protection and not great for scuffs and scrapes so i took some of that spray on perma tex stuff and shot a bit of it on the bottom and i really liked how it looked figured what the heck and did the whole thing. its not real thick anywhere and i keprt it to a minimum where there was bolt padads and such. we will see how it goes
Moscowmule is offline   Reply With Quote
Old 10-22-2018, 01:18 PM   #77
LT7A
Re: building a mule
OK. cool. Hope it works out well. Look forward to seeing your progress.
Old 02-11-2019, 03:32 AM   #78
Moscowmule
Re: building a mule
has anybody installed one of the early classics fuel tanks in our trucks I bought one gently used from a member and there is no instructions. I messed with it a bit and nothing seems to land any where that makes sense
Any help would be great.
Old 03-24-2019, 05:16 PM   #79
Moscowmule
Re: building a mule
nobody ?
Old 03-25-2019, 12:02 AM   #80
Captainfab
60-66 Nut
Re: building a mule
Is it a '69-'72 blazer tank or is it a fabricated aluminum tank? What about it doesn't fit or line up?
Old 03-26-2019, 02:59 PM   #81
Moscowmule
Re: building a mule
Its an Early classics fuel tanks supposed to fit our trucks problem is i have no idea how or where it is supposed to fit
Old 03-26-2019, 03:13 PM   #82
Moscowmule
Re: building a mule
The tank was purchased from a member here his post is called early classics fuel tank kit his name is number 98 the post has sme pics t show what im dealing with i would post my own but i cant seam to be able to from my phone
Old 03-26-2019, 06:20 PM   #83
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: building a mule
Is this it?
https://www.earlyclassic.com/node/1394
And information on how to put it in.
https://www.earlyclassic.com/node/1417
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-28-2019, 05:42 PM   #84
Moscowmule
Re: building a mule
Nice thank you so much the link was perfect I didn't realize the frames were different k10 vs c10 that was my problem and they want me to remove the x member again thanks
Old 03-28-2019, 05:43 PM   #85
Moscowmule
Re: building a mule
Originally Posted by Clyde65 View Post
I looked for a link for a month never found one you probably found it in 2 min thanks a ton
Old 10-10-2019, 08:36 AM   #86
Moscowmule
Re: building a mule
I have made some progress!!!
Got the fuel tank basically in needs some fine tuning but at least its not laying on the floor anymore!!!
Old 10-10-2019, 08:54 AM   #87
Moscowmule
Re: building a mule
I've got the front end kind of mocked up waiting for some new springs.
I found an outfit that used to have them as a stock item but now they are special order 10 week lead time. which is fine for me because im back at sea until the end of november
Old 10-10-2019, 09:03 AM   #88
Moscowmule
Re: building a mule
also got some parts from CaptainFab motor maount set up he had laying around my wife stopped in to see him and pick up the parts. She said he was a very nice guy and that he had a "neat old truck" he was working on. Thanks Cap
Old 10-10-2019, 09:09 AM   #89
Moscowmule
Re: building a mule
Got my engine back from the machine shop its got a bit of a cam upgrade verything else brand new stock build. probably going to replace the tin the valve covers are beat up pretty good and there are some dents in the oil pan
Old 10-10-2019, 11:19 PM   #90
Captainfab
60-66 Nut
Re: building a mule
Glad to see you make some progress. What is the name of the company that is making springs for you? Thanks for the compliment. Your wife must be talking about my '66 Suburban.
Old 10-11-2019, 07:56 AM   #91
Moscowmule
Re: building a mule
The outfit im buying them from is called TNT springs in belgrade mt im not sure who they sourced them from but they were 265 each with bushings no pins lmc was 495 each
Old 10-11-2019, 07:58 AM   #92
Moscowmule
Re: building a mule
not really sure if its a compliment shes kinda crazy thinks I'm nice too
Old 10-11-2019, 06:56 PM   #93
72cs20
Re: building a mule
That is a lot of money for these springs. I bought mine here -
https://www.generalspringkc.com/Leaf...966_s/1821.htm
Good springs and fast shipping. Bushings in front, not in rear. Much less expensive.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
