Old 02-06-2017, 11:37 AM   #76
87max
87max's Avatar
Re: 1988 Crew Cab shortbed overhaul
please keep pics of the crossover coming, considering that myself.
87max is offline   Reply With Quote
Old 02-06-2017, 01:46 PM   #77
daddyjeep
daddyjeep's Avatar
Originally Posted by daddyjeep View Post
The only difference between the 35 and 31 is the height.
Oops...I meant 25. The 25 and 31 gallon tanks have the same footprint, but the 31 is taller. The 40 gallon is longer and I think is the same height as the 31.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-07-2017, 07:17 AM   #78
lt1wrangler
Will do, Im using 7075 links and should have them done next week.
lt1wrangler is offline   Reply With Quote
Old 02-07-2017, 07:18 AM   #79
lt1wrangler
I thought thats what you meant lol
Old 10-27-2017, 06:40 PM   #80
lt1wrangler
So I got so busy building my truck, I forgot to post ! I found a second 2wd truck in southern California that was one owner, 42k miles and zero rust. I decided to use it on my frame. With regular cab mounts, it clears drivetrain with 2wd tunnel fine.
Old 10-27-2017, 06:42 PM   #81
lt1wrangler
Here's cab sitting on frame
Old 10-27-2017, 06:45 PM   #82
lt1wrangler
Steering pics with 2wd box, 7075 links, Bilstein stabilizer
Old 10-27-2017, 06:50 PM   #83
lt1wrangler
Cab mounts and AC lines I made. It was easier to buy my own crimper and line.
Old 10-27-2017, 06:59 PM   #84
lt1wrangler
Here's trans lines to 4l80e, I used AN fittings then put heat shield over them. Also got headers lined out and jet coated. I cut flanges and welded v band flanges on them.
Old 11-01-2017, 08:50 AM   #85
LT7A
You said you wanted a very clean driver. This is VERY CLEAN. Cool to watch your progress.
Old 11-02-2017, 03:06 PM   #86
NorCalAnthony
Wow your truck is looking killer!
NorCalAnthony is offline   Reply With Quote
Old 11-02-2017, 08:26 PM   #87
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks sweet! So clean and shiny. I love it. Is you RH spring plate a stock cast piece? I can't remember if mine has that threaded hole where you have the steering stabilizer shock mounted. I hope mine has that. I like how yours is.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-07-2017, 07:56 AM   #88
lt1wrangler
It's a stock plate, I drilled and tapped it for 1/2" bolt. I couldn't figure out where else to put it lol.
Old 11-07-2017, 08:02 AM   #89
lt1wrangler
I did the green EBC brakes to try and add some extra braking. It's rear disc with a small residual valve in rear and 82 Corvette master with modified hydraboost. I reworked prop valve and just bent all new stainless lines everywhere.
Old 11-07-2017, 08:04 AM   #90
lt1wrangler
Engine bay, still gotta clean it up and paint a few things. I've had three different exhaust on truck and I still don't like sound. Thinking about going back to manifolds
Old 11-07-2017, 12:15 PM   #91
MTCK
MTCK's Avatar
Truck is looking great! What exhausts have you tried? Just a thought but adding a crossover pipe might be easier than swapping to manifolds.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-07-2017, 09:59 PM   #92
lt1wrangler
magnaflows, flowmasters, stock with resonators, all with 2.5" pipe. I don't like all the noise up front from the headers.
Old 11-07-2017, 11:06 PM   #93
jhama78
jhama78's Avatar
Clean build Rusty. Do you think more sound proofing on the firewall would solve the noise problem?
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 11-07-2017, 11:12 PM   #94
Dieselwrencher
Marcus nailed it. A cross over can really change the tone of the exhaust for sure.
Ryan
Old 11-18-2017, 07:36 AM   #95
lt1wrangler
Ill try the crossover pipe for sure. I have the truck down right now redoing the interior with second row honda odyssey seats in grey leather. Im also dynamiting the floor and roof.
Old 11-18-2017, 09:48 AM   #96
jhama78
jhama78's Avatar
Might make the wind noise overpower the exhaust noise...
-j-rod
Old 11-19-2017, 03:24 AM   #97
Dieselwrencher
I didn't believe an H pipe made a difference in tone until I put one on a ls swapped nova we did. I had to eat crow on that. Haha
Ryan
