Old 04-11-2017, 05:13 PM   #76
theastronaut
theastronaut's Avatar
Re: 1963 VW Convertible Build
Originally Posted by Clyde65 View Post
That is slick!
Originally Posted by flashed View Post
Looks great ,cant believe how fast you are getting it done .
Thanks guys!
Originally Posted by goldenburb View Post
How much the Fuchs go for this days ? I still have 4.5x15s & 6x15s just asking. Cool ride.
Haven't kept up in awhile but around 1k each on genuine 4.5's, and $1200 for a pair of early/deep 6's.
theastronaut is offline   Reply With Quote
Old 04-12-2017, 02:11 PM   #77
67ChevyRedneck
67ChevyRedneck's Avatar
Wow, it's like a car already!
They're literally like a giant go-cart.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-12-2017, 04:45 PM   #78
goldenburb
goldenburb's Avatar
Another Q for ya..
in the corner of my garage, I got a 56 bug that is over shadow by my 62 bus that has no paint on it.... how can I protect It I don't want to paint it.... Thanks just asking...
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 04-18-2017, 11:15 PM   #79
theastronaut
Yeah that's why they're so popular to turn into dune buggies and kit cars.
Another Q for ya..
If you want to leave it in bare metal then look into Ospho or Gibbs oil, I haven't tried either myself for long term storage but others claim that they work well. Either will need to be **completely** removed before you can shoot epoxy. Or if your metal is clean now you could go ahead and shoot epoxy to seal it up.
Old 04-18-2017, 11:39 PM   #80
theastronaut
Still don't have this thing finished. I'm waiting on the cylinder heads still, they ended up being a mess and needing way more work than expected. The brakes are adjusted and bled, gas tank has been flushed/detailed/installed, radio is in, and a lot of the small/time consuming details are finished. I need to add some sound deadening and padding under the floor mats, finish covering one front seat, do a four wheel alignment, and finish building the engine once the hesdscare done.
I finally located a rear backrest, it arrived and I covered/installed it on Saturday.
The original distributors were cast iron, painted black, with a brown Bakelite cap. I wanted to run a modern distributor for reliability and the adjustable advance curve but the polished billet housing and grey cap looked out of place. I dug through our leftover SEM dye and found a color that was close and tinted it for a fairly close match. I also light sandblasted the cap for better adhesion and to give it a slightly textured surface to match the original caps better. The body of the distributor was shot with satin black.
Old 04-19-2017, 06:26 AM   #81
rusty76
rusty76's Avatar
Looks cool.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-21-2017, 09:49 AM   #82
LBJ
That chassis is beautiful! Nice job. Body on frame looks great. Wish I had that one.
LBJ is offline   Reply With Quote
Old 05-12-2017, 01:12 PM   #83
theastronaut
I finally got the heads back from the machine shop this week. I did a little bit of port work and had to open up the chambers a few cc's to drop the compression down to 9.4 to 1 (was at 10:1).
Before/After.
Windows, frames, and weatherstripping cleaned up nicely. Before/after shots.
Rolled it out to clean the shop.
Old 05-14-2017, 10:18 PM   #84
plainred65
plainred65's Avatar
Very nice!
plainred65 is offline   Reply With Quote
Old 05-15-2017, 06:14 AM   #85
dug224
dug224's Avatar
Great project. The wheels and the stance are perfect.
dug224 is offline   Reply With Quote
Old 05-15-2017, 06:56 AM   #86
flashed
Turned out great .
flashed is offline   Reply With Quote
Old 06-01-2017, 10:00 PM   #87
theastronaut
Thanks guys!
Been working on the engine. Once I finished porting and cc'ing the heads and went to mount them I found out that the upper row of head studs were too short. The '65 only head I'm using use matching one year only upper heads studs which took a couple of weeks to find. I finally got a set last Friday and I'm done with the longblock now.
The engine was missing the thermostat (most are) so I pulled one out of my parts stash and cleaned it up.
I used a solid rocker shaft kit from CB Performance to get rid of the old wavy washers and clips that retained and located the rockers. Had to shim each rocker to .005" side to side clearance, which required lapping some of the rocker stands and end caps to end up at the final tolerence. Way more work than slapping together stock parts but it'll last longer and work better. I also used later 1600 1.1:1 ratio rockers instead of the original 1:1 rockers.
I also found out that the pistons didn't clear the webs in the block at bdc. I had to grind away a bit of the skirt to gain enough clearance. Once I had ground enough away that the engine would make a full revolution I used clay to check the final clearance.
Old 06-04-2017, 09:56 PM   #88
goldenburb
goldenburb's Avatar
I've been out of the Volkswagen since for a while it stinks especially after they legalized marijuana in Colorado....
can you tell me who sells red carpet??
You're thread motivated me to pulled it out of the garage for an overdue wash
67 c10 2wd sb truck
67 c10 4wd lb truck
Old 06-08-2017, 04:09 PM   #89
theastronaut
Wolfsburg West sells original style squareweave carpet, and you can special order it in red.
Old 06-08-2017, 04:19 PM   #90
theastronaut
Got a little bit more done. Started a new project at the shop so I haven't had as much time to work on it, and I'm still wating on a couple of engine parts to finish it up.
Old 06-08-2017, 10:09 PM   #91
duallyjams
duallyjams's Avatar
It's been awhile just seeing what you've been up too.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 06-09-2017, 11:08 PM   #92
theastronaut
I started on a '51 GMC a few weeks ago for a local business. It was one of their original shop trucks and is still logo'd. Going with a 5.3/4L60e, Mustang 2 front suspension, TCI rear leaf/shock kit, rear mount Tanks tank, Vintage Air... basically making a mild reliable cruiser out of a stock truck. Good to hear from you, been keeping up with you on Instagram.
Old 06-09-2017, 11:09 PM   #93
theastronaut
Cut up a NOS Ernst muffler tonight and gutted it. Made a smooth face for it on the english wheel and welded it back together. I have four feet of polished 1.25" stainless tubing on the way for tips to replicate an Abarth four tip. I also removed the pre-heater boxes on the upper pipes. The intake heat pipe will have to be relocated to clear the filter pump.
Fan shroud is on, flaps hooked up to the thermostat. I restored an old Bosch Super Coil and hung it with the original bracket.
Old 06-12-2017, 02:26 PM   #94
NONHOG
NONHOG's Avatar
anxious to see the exhaust (and hear?) finished.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 06-15-2017, 11:53 AM   #95
theastronaut
I'll post a video of if it running!
Old 06-15-2017, 12:12 PM   #96
theastronaut
Bought a NOS regulator last night, drilled and tapped an extra hole in the generator body so I could mount it, and detailed/installed it just now.
The stainless tubing came in yesterday so I laid out the spacing on the muffler. I'll install the engine to double check the alignment with the apron before drilling any holes.
Old 06-16-2017, 08:13 PM   #97
theastronaut
Got the engine together and in the car, muffler finished, and running today. The straight cut gears are noticeable too!
Old 06-17-2017, 04:27 PM   #98
theastronaut
I took the car to the local downtown Father's Day car show today, along with the '66 F100 we restored.
Old 06-17-2017, 06:00 PM   #99
duallyjams
duallyjams's Avatar
Another job well done.
James
IG duallyjams
Old 06-18-2017, 08:11 AM   #100
flashed
Very nice and it sounds great too.
