Closed Thread
Old 02-23-2018, 09:41 PM   #76
jocko
jocko's Avatar
Re: Pictures of 1967-72 motorhomes
Originally Posted by StevePark View Post
should I do overdrive or is changing the gears enough?
Great looking rig, congrats. I'd leave the rear gears as they are. If you want an automatic, TH400 was available in those. As for overdrive, I would lean toward accomplishing that by inserting a Gear Vendors over/underdrive behind either your current trans or a TH400, I wouldn't mess with an o/d trans personally.
jocko is offline
Old 02-23-2018, 10:53 PM   #77
Joesjunk
Joesjunk's Avatar
That truck should have a 4:57 gear in it
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline
Old 02-23-2018, 11:35 PM   #78
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Mine will be getting a 6.0/4L80E and a 3:73 14 Bolt. I have a 350/400 in it now, probably original only has about 79000 on the Odometer and looks to be correct. Even if you buy these from the west coast I would inspect the heck out of it for water damage. Mine spent all its life in the Zona and the side wall with the door was rotted to the core. I am doing a complete revamp and it will get a whole new box and redesign of the living area. Once you tear one of these apart you will see how simple they are built to the point of being scary. Staples everywhere and very thin material.
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline
Old 02-24-2018, 12:00 AM   #79
Steeveedee
Who Changed This?
Steeveedee's Avatar
Enough glue, plywood, staples and nails, it's plenty strong. It's called aggregate strength, in the building industry. Though I will have to agree that it isn't all that strong in a crash.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 02-24-2018, 12:26 AM   #80
71meangreenc10
Exactly,
When it is new, but after 40 years of neglect and water damage you could probably push through the wall on mine with the rot. The vents on the roof did a lot of damage to mine as they were not sealed at all. Some wood supports on mine crumbled in my hand. The siding on these are stapled to the sides. You can pull them off easy. If it is original I would hesitate to drive in an area with high winds. Could blow it apart. Mine will get Filon siding and more support in the walls for strength.
My floors were still pretty solid for being original.
Smitty
71 C30 Wrecker
Old 02-24-2018, 12:41 AM   #81
StevePark
Hey guys, bunch of great info, thanks. Ya it doesn’t have a tach in it now, but at what the speedo said was 50, the engine was a screaming, Lol. I really like the 4 speed, but maybe a T400 would be the way to go? I just sold an extra one I had, damn. There is a couple small wet spots, but I can’t find any rot. Thanks.
StevePark is offline
Old 02-24-2018, 07:47 AM   #82
Advanced Design
Advanced Design's Avatar
Originally Posted by 01chevduramax View Post
Attachment 1643848
Attachment 1643849
Surprisingly, once my wife saw this in person I think she wanted it more than I did. When we didn't get it the first time we saw it, I caught her searching craigslist for another one! We've got 6 camping trips in it so far. Averaged 11 mpg over Mt. Hood to eastern Oregon for a raft trip.
Awesome camper rig! Do you have any interior pics?
Advanced Design is offline
Old 02-24-2018, 09:49 AM   #83
jocko
jocko's Avatar
If you like the 4-speed, keep it. I only mentioned the TH400 in case you actually wanted an automatic. Your current 4-speed and a TH400 both have a 1:1 high gear, so they will scream at the same rpm on the highway. If your rear gears have been changed or you aren't sure what they are, your speedo is likely incorrect - use a GPS to see what your actual speed is. As Joe mentioned, 4.57 rear would've been stock for your truck. If you like the 4-speed and are itching for overdrive, the Gear Vendors unit allows you to keep it and have a significant reduction in highway rpm - it also allows you to split each gear in half, essentially gives you an 8-speed (that you don't have to use) with a top gear that is overdriven. It's a very good option for a motor home. Not cheap though, plan on ~$3K new, $1-1.5K used.
jocko is offline
Old 02-24-2018, 12:59 PM   #84
StevePark
Hey Guys,
Ya Jocko, I didn't even think of the gps app. on my phone on the way home, but car were passing me like crazy, Lol. Maybe I will have to go the gear vendors route, I have been looking at them. But first things first, get it cleaned and remodel the in side, someone had a great idea to spray the entire inside white, ugh. they painted over the stained class on the cuboard doors.
Old 02-25-2018, 01:39 PM   #85
Deej-79
https://www.instagram.com/p/BfcK0xplK1B/
Rtech fabrication is building a nice one right now. I'm pretty sure he has posted on here but I can't remember his screen name
Deej-79 is offline
Old 02-25-2018, 01:47 PM   #86
jocko
jocko's Avatar
Hey Guys,
Ha, yeah, all white inside sounds horrible... I like your plan, just get the inside redone and make the rest reliable and drivable, you can always add a GV later if you like.
jocko is offline
Old 02-25-2018, 01:57 PM   #87
Coley
Coley's Avatar
Keep an eye out for some cool 60's vintage/period correct stuff and put it in there.....that really brings attention.
I found and added a bunch of stuff into our little trailer...stuff like extra 12V lights, magazine rack, chrome table trims, etc.
My wife helped out with redoing the upholstery on the cushions, etc.
..they are a lot of fun and way more interesting than the modern rigs...which, like the cars...are pretty much identical.
all good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline
Old 02-25-2018, 02:01 PM   #88
jocko
jocko's Avatar
Yes, that is member atvpro. I hadn't seen the one you posted in the Instagram link yet - thanks for sharing, it looks great, I gotta see more! They do build some killer stuff.
Rtech has a website also - https://www.rtechfabrications.com/
jocko is offline
Old 02-25-2018, 03:01 PM   #89
ortegamotor
ortegamotor's Avatar
here are a few pics, the travelette was mine. the copper one is one a saw on line.
ORTEGAMOTOR
ortegamotor is offline
Old 02-25-2018, 03:03 PM   #90
ortegamotor
Size:  51.4 KBhere are a few pics, the travelette was mine. the copper one is one a saw on line.
ORTEGAMOTOR
Old 02-25-2018, 03:09 PM   #91
ortegamotor
here are some more pics.
ORTEGAMOTOR
Old 02-25-2018, 08:19 PM   #92
Boog
laying low
Boog's Avatar
flips
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 02-25-2018, 09:14 PM   #93
custom10nut
custom10nut's Avatar
Wouldn't I love to have one of these Motorhomes, but I think someone else could get much more use out of it. I see most of these that are in good shape are from the Southwest.
One day I might get a vintage trailer and paint it to match the paint color/scheme of my truck, like I'm doing with my Gooseneck Flatbed/Cattle hauler to match my Dually.
custom10nut is offline
Old 02-26-2018, 12:57 AM   #94
StevePark
all good
Coley
Ya Coley, love that truck. I have a 69 custom camper, 396, all original. are you on any of the 67-72 facebook pages?
Old 02-27-2018, 06:20 PM   #95
WorkinLonghorn
WorkinLonghorn's Avatar
Wow, I grew up right there in El Cerrito. Used to ride my bike along there. That place is now the site of a Denny's restaurant.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline
Old 02-04-2019, 04:18 PM   #96
klunker_restorations
Here are a few pictures of my 67 gmc I picked up this fall. That is if I attached them correctly. Lots of neat motorhomes on here!
klunker_restorations is offline
Old 02-04-2019, 10:12 PM   #97
jocko
jocko's Avatar
Very cool rig - mo pics please Would love to see the interior of the camper.
jocko is offline
Old 02-05-2019, 07:44 AM   #98
Awesome awesome awesome! Did I mention your camper is awesome?? Welcome to the site. That is the best of the best and looks to be in great shape. '67 GMC Super Custom, what motor, 327? That rounded top is a savior. Tinted window even matches interior. When do you see blue tint these days? So about the era it ain't funny. Enjoy that thing, you lucky son of a.................
special-K is offline
Old 02-05-2019, 11:23 AM   #99
Thanks Guys! Here are a few I had of the interior, little water damage up front but not too bad. The blue tinted Plexiglas I thought was neat too! It has the 305 v6 in it, trying to decide if I should keep it since they are kind of neat or go to a big block or LS...
Old 02-11-2019, 09:05 PM   #100
yote1234
yote1234's Avatar
Originally Posted by Joesjunk View Post
Livrat, I still have that red one
hey joe... wanna sell that red 1???
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline
Closed Thread
