Old 01-11-2019, 01:26 AM   #76
Oldironracing
Oldironracing's Avatar
Re: GM connect and cruise engine package
Guess no one uses mufflers? Stainless or?
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 01-11-2019, 11:18 AM   #77
MIKESAD50
On my LS connect and cruise in the 50 I used 2 1/2" pipe with and x pipe and Stainless Works turbo chambered and it dumps in front of rear tires. Mello when cruising with no drone and gets louder more you step on it. very happy with my set up.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 01-27-2019, 02:02 PM   #78
Oldironracing
Has anyone used a electric push button e brake?
OLDIRONRACING
Old 02-04-2019, 09:14 AM   #79
Oldironracing
Worked on the exhaust this weekend.
OLDIRONRACING
Old 02-04-2019, 09:15 AM   #80
Oldironracing
Exhaust
OLDIRONRACING
Old 02-05-2019, 03:54 PM   #81
Big Moose
Fancy exhaust work, nice!
Big Moose is offline   Reply With Quote
Old 02-12-2019, 11:54 PM   #82
Oldironracing
Thanks. Hope to make hangers this weekend
OLDIRONRACING
Old 02-13-2019, 08:33 PM   #83
bigmoe
bigmoe's Avatar
Is there enough room that the trailing arms won’t come up and hit the mufflers? I was considering tipping my mufflers on their sides to get beside the driveshaft and avoid the trailing arms.
bigmoe is offline   Reply With Quote
Old 02-14-2019, 09:48 AM   #84
Oldironracing
With the rear suspension bottomed out there is a 1.5 inc of clearance. Bottomed out means rear end touching the frame.
OLDIRONRACING
Old 02-14-2019, 09:50 AM   #85
Oldironracing
Has anyone run in to problems with running the exhaust under the trans crossmember with a 4-6 drop?
OLDIRONRACING
Old 02-16-2019, 11:20 AM   #86
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, you will drag it, or worst case, it looks ugly hanging down under the cab. Try an Early Classic, CPP, or similar type and route over it, or weld in humps using steel pipe
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-16-2019, 12:08 PM   #87
bigmoe
bigmoe's Avatar
I bought a straight across crossmember before realizing it would be a problem with exhaust routing. I modified it with the half pipes that are raised up with some flat pieces. I have the same kind of pipe pass throughs at the trailing arm crossmember as you.
