Old 06-30-2020, 03:05 PM   #76
GerhardH
GerhardH's Avatar
Re: My 1968 C-20 Golden Anniversary Project
Cylinder head hole indentification
Best regards GerhardH!
Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20
1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400
http://67-72chevytrucks.com/vboard/s...d.php?t=760400
GerhardH is offline   Reply With Quote
Old 06-30-2020, 09:41 PM   #77
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Heads look great! Tell me about the beer in post #70 please
Old 07-01-2020, 01:46 AM   #78
GerhardH
GerhardH's Avatar
Smile Re: My 1968 C-20 Golden Anniversary Project
https://www.google.com/url?q=https:/...8FbdZmDlXE48RB
Augustiner Hell ( means not Hell means bright)
My favorite if I'm not in US and drinking IPA
Old 07-01-2020, 02:45 PM   #79
GerhardH
GerhardH's Avatar
Measurement of the hole for the temperature sending unit, guessing 1/2 NPT, will show evidence later.
Old 07-01-2020, 02:49 PM   #80
GerhardH
GerhardH's Avatar
Insvestigation where to measure the valve shaft ( Approx, 1.5" of the shaft is in the chamber and the valve guide is round about 2" long. Differences between several instruments. Use the micrometer therefore (3 Positions all 0.3414")
Old 07-01-2020, 02:52 PM   #81
GerhardH
GerhardH's Avatar
Valve head 2.02 " and 1.60"
Preparation for measurment chamber volume.
Old 07-01-2020, 02:57 PM   #82
GerhardH
GerhardH's Avatar
Forget to screw in the spark plug = Leak & again
Chamber volume 63 cc
Intake runner 164 cc
Exhaust runner 52 cc
Small block 64cc: Amount to reduce chamber volume by 1 cc (milling): 0.0055"
Remember: In the outer area cylinder heads up to 0.3 mm (0.011811") removed, means more or less matching.
Old 07-03-2020, 08:56 AM   #83
GerhardH
GerhardH's Avatar
So next steps:
1) Evidence for thread temperature sending unit in cylinder head driver side: NPTF 1/2 x 14. Remember NPTF is similiar to NPT but not identically.
2) Thinking on tomorrow: Piston stop tool already bought.
Old 07-03-2020, 09:03 AM   #84
GerhardH
GerhardH's Avatar
Load test on the rocker stud threads: 60 ft-lbs (without oil, sealer or antisizing)- ok and ready for go (production is 50 ft-lbs). Nut: deep-well wrench 11/16".
Rocker studs are 3/8 fine thread x 7/16" course thread, length overall 2.475".
Earlier pressure test done and investigation: no guide plates needed (as in the original engine in my car).
Old 07-03-2020, 09:27 AM   #85
GerhardH
GerhardH's Avatar
To measure the gap of the valve guides is not so easy for beginners. In my opinion you need a couple of hours to get a feeling what can be true and what not.
First cleaning of the guides. I used two measurement tools. First digital inside calipper. You have 5 digits thats could be a litte bit confusing because even if you make the identically measurement twice, you dont get the same last digit.
But on the end is easier than expected.
Let say a new valve has 0.341" shaft diameter (and this is over the complete shaft lenght. Than the maximum stem clearance can be inlet 0.0027" + 0.001" and exhaust 0.0027" +0.002". So that means the guide must be less than 0.3447" inlet and 0.3457" outlet. In practice I was measure all inlets and exhausts and was looking that I have no 0.35" at all. I get all guides below the limit. Than I asked an expert, he don't measured the system, only moved a new valve in the guides and told me: "Good for go"! Guide job will only burn additional money and is not necessary yet.
Second I used an inside feeler and micro, was also very suitable and delivered the same results.
Further I measured a brand new bronze insert: 0.342, ok bether than my existing with 0.344 but will do without guide job.
Old 07-03-2020, 09:32 AM   #86
GerhardH
GerhardH's Avatar
Last for today: Looking for warped heads, but the heads are already resurfaced:
By the way my orientation is a good book: "How to rebuild your Small-Block.CHEVY by David Vizard". Example given, there you will find that the limit of warpage schould be 0.003" (a compound gasket will take up far more warpage up to 0.005" according David.
Result: Less than 0.0025"
Monday shopping:
16 pcs Rocker stud (because I lend)
16 pcs Rocker arm
16 pcs Ball seat (Pivot ball)
16 pcs Rocker clearance adjusting nut
08 pcs Inlet Valves
08 pcs Outlet Valves
16 pcs Valve Springs (use always new one)
16 pcs Valve spring retainer (I got already with the heads)
32 pcs Keeper (use always new one)
16 pcs Oil seal
To fire on the 50 years old short block:
01 pc Oil pump
01 pc Oil pump securing bolt
01 pc Oil pump pickup pipe
01 pc Oil pump drive shaft
01 pc Oil pump drive shaft adapter
01 pc Oil pan
01 pc Oil pan gasket
14 pcs Oil pan bolts (small) (1/4"-20UNC x 1/2"long)
01 pc Oil pressure switch
10 ltr. Breake in oil
04 pcs oil pan bolts (large) (5/16"-18UNC x5/8" long)
14 pcs oil pan bolts star washer (1/4" diameter)
01 pc Oil filter pressure relief valve housing
02 pc oil filter pressure relief valve housing bolts
01 pc Oil filter spin on cartridge
01 scew set small block
01 gasket set small block
Last edited by GerhardH; 07-27-2020 at 01:27 PM. Reason: Parameter changed to 0.0025"
Old 07-05-2020, 05:50 AM   #87
GerhardH
GerhardH's Avatar
And preparation for the new valves:
looking for stock similiar but stainless steel.
At the moment I believe that the contact area (Seat width) shut be:
.060 to .080 inch for the exhaust and .040 inch for the inlet. (Exhaust must transpoprt more head)
.060 to .080 inch = 1.524-2.032 mm = 1.5-2 mm
.040 inch = 1.016 mm = 1 mm
Apply the paste to 3-4 points on the underside of the valve.
Rotate the valve in the seating with the valve grinding tool, lifting occasionally.
You can tread the paste with a litte bit oil.
Good cleaning after is mandatory.
Old 07-05-2020, 10:12 AM   #88
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Your going to have a nice set of heads
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-10-2020, 09:20 AM   #89
DeadheadNM
Carpe manana
DeadheadNM's Avatar
German engineering - love it!
Old 07-13-2020, 04:36 AM   #90
GerhardH
GerhardH's Avatar
Width of valve seats are to big 0.125" = 3.175 mm That means:
VALVE SEAT JOB BY MACHINE SHOP
Heads are already there.
In the meantime two other side jobs:
Left door glas is shaking.
Railing is rusty.
Old 07-13-2020, 04:39 AM   #91
GerhardH
GerhardH's Avatar
Talking Re: My 1968 C-20 Golden Anniversary Project
White side covers produced by SMS Auto Fabrics.
Tool for removing the securing brackets door handle.
Old 07-13-2020, 04:42 AM   #92
GerhardH
GerhardH's Avatar
:-) Little bit rusty but below strong american steel. I'm happy.
Several paints and rost lockers are not allowed in Germany by law, therefore my favorite:
1. Owatrol oil (Rost stopper)
2. Brantho Korrux nitrofest (under coat)
3. Sealer Korroflex
4. Minimum 2 layers Brantho Korrux nitrofest
5. Alkydharzlack (Alkyd resin varnish)
6. Klarlack (clear varnish)
In the last picture Owatrol already done.
Old 07-15-2020, 04:38 PM   #93
GerhardH
GerhardH's Avatar
Next layer done.
Old 07-17-2020, 08:32 PM   #94
cornerstone
cornerstone's Avatar
Wow Gerhard! You've been working hard at it! Looks fantastic my friend.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 07-19-2020, 08:43 AM   #95
GerhardH
GerhardH's Avatar
Angry Re: My 1968 C-20 Golden Anniversary Project
Hi my Friend, thank you for the compliment. On the end it is heavier than expected. It was my first paint job and the roof railing and pillars are the most complicated places I think. As the spray can for the under coat was empty I used a paint roller- THAT WAS A HUGHE FAILURE! The surface is than not smooth enough for the final coating. I was removing everything again by grinding. A couple of days. But now it comes to an aceptable surface.
Have seen your project has done a great step forward too and your shop -GREAT!!!
Old 07-21-2020, 01:09 PM   #96
GerhardH
GerhardH's Avatar
Ready for final Cameo white, already tested on one place.
Old 07-21-2020, 01:30 PM   #97
Ol Blue K20
Looking good, don't forget to post a picture after paint.
Dale
Old 07-26-2020, 08:52 AM   #98
GerhardH
GerhardH's Avatar
Clear vanish added, paint preparation (taping) was not precise enough- that means time saved on the beginning and lost by factor 3 on the end, a lot of work. Will do more accurate next time.
For spray and first job the result looks good.
Color is 526 Ivory (also of-white and Cameo white)
Old 07-26-2020, 10:32 AM   #99
GerhardH
GerhardH's Avatar
Was starting to make some measurements on my motor, found out that I need a gauge with thread not rubber as it is not enough comfortable for me.
Spark plug #4 is oily, all others good bud maybe a little bit to lean (more white than brown color).
GAP is 0.035".
Compression between 11-13 bar, but measurment will be done again with different gauge (with thread).
Old 07-27-2020, 10:18 AM   #100
cornerstone
The hard work of preparation has paid off. Congratulations on a job well done! The roof paint really looks great.
Brian
327, c-20, golden anniversary, th400, truck
