Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-10-2020, 08:32 AM   #76
twp1
Re: 1972 Blazer undecided!!
Picked up 5.3 direct injected engine and 6-speed trans! Wish I would have go the 6.2(short on cash). Just reaching out to see if anyone has done this in the blazers? Looking to keep the vacuum pump and add power steering on the passenger side and use a reservoir.
twp1 is offline   Reply With Quote
Old 03-10-2020, 04:04 PM   #77
mortoyz
Active Member
I am currently putting a l83/8l90 in a 72 2wd Jimmy. I went with the Holley front drive accessories and put a LT1 intake on it. The LT1 intake has the vacuum port in the rear of the intake. Not sure if any of it works yet, but that's where I'm at so far.
mortoyz is offline   Reply With Quote
Old 03-11-2020, 08:03 AM   #78
twp1
Thanks!
Old 03-11-2020, 08:07 AM   #79
twp1
Old 03-11-2020, 08:08 AM   #80
twp1
Any pictures?
Old 03-11-2020, 10:00 AM   #81
mortoyz
Active Member
Old 03-11-2020, 10:12 AM   #82
mortoyz
Active Member
BTW...Very nice work on your blazer.
Old 03-11-2020, 12:22 PM   #83
twp1
I will say the same to you!
What did the intake come off of? and what water pump did you go with?
Old 03-11-2020, 12:23 PM   #84
twp1
Also what headers did you use?
Old 03-11-2020, 02:59 PM   #85
mortoyz
Active Member
The kit from Holley is very similar to the kit I put on the ls motor in my 4wd blazer. Looks to me like it uses the same water pump as the ls. The kit for the LT motor uses spacers behind everything to bring the pulleys in line with the crank pulley. The water jackets on the LT are machined different than the LS, therefore spacers have different machining on both sides as well as threaded hole for temp sensor. Holley LT accessory drive part number 20-170. The intake was a new replacement intake for a Camaro/Corvette LT1. The headers are speed engineering shorties. They make a long tube header also.
Old 03-11-2020, 03:23 PM   #86
mortoyz
Active Member
Here’s a picture of the Holley setup on the ls motor in my blazer.
Old 03-16-2020, 08:44 PM   #87
harrisoncole4
harrisoncole4's Avatar
The bodywork looks great. Everything looks to be fitting really well.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 03-17-2020, 03:06 PM   #88
twp1
Yes I have been impressed with all the panels!
