Old 11-22-2020, 04:23 PM   #76
mikentosh
mikentosh's Avatar
Re: Mikey's 77 shortbox - Greenie
...also finished out the front Silverado appearance with the (V22) deluxe grille.
Luckily Jeff (azpartslocators) had a set of the grille trim still, so he polished them up and sent them over. I masked them up and sprayed the centers trim black.
It's a subtle detail but I like the layered stainless/chrome look.
mikentosh is offline   Reply With Quote
Old 12-27-2020, 05:10 PM   #77
cheyenne402
I love this truck. I'm kinda odd tho, I like the straight six in it
cheyenne402 is offline   Reply With Quote
Old 01-01-2021, 12:11 PM   #78
Corts60
Just here to tinker
Corts60's Avatar
You still continue to blow me away with your details and quality. Great job on the cruise control! Where did you get your tachometer? It looks perfect.
Old 01-23-2021, 06:53 PM   #79
mikentosh
mikentosh's Avatar
Thanks! I ended up putting together two tach clusters mixed from OE parts and new stuff from LMC. Not sure what to do with the second one yet...perhaps for the next project 😊
Old 01-23-2021, 07:16 PM   #80
mikentosh
mikentosh's Avatar
Well over the holidays I had the truck back apart again to put in a new steering rack I got from Flaming River. The reasoning behind this was an attempt to get more turning angle with a longer travel rack. These 79-93 racks that Flaming River builds in-house have about one inch of additional travel over a standard Fox-body rack. They also use the better o-ring style fittings from the newer cars, and come pressure tested.
I was hoping to keep this a bolt-in swap, but the one downside to these racks IMO is they feature Flaming River's "power" connection input shaft, instead of a standard 3/4 36-spline shaft. This meant a minimum of a new lower u-joint...but once the new rack was in the truck I found there to be more interference problems with my steering shaft setup. I ended up redoing most of the steering linkage, and also clearancing the frame some more.
While I was in there I also swapped the generic power steering hoses with some new ones that I made up from Earls pressure hose and fittings. The generic ones were far too long for this application and I had concerns about stress from the severe bends to get it lined up, so the fresh hose was an added bonus.
The end result was well worth the effort, as I've regained most of the original turning radius. No more 3-point manoeuvres just to get into a parking spot. An added bonus is the new rack is significantly smoother than the reman unit that I had in prior.
Old 01-24-2021, 02:58 AM   #81
mikentosh
mikentosh's Avatar
The wide tire/wheel setup is subtle until you’ve got the fronts angled out.
Old 01-25-2021, 03:26 PM   #82
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks killer!
--Josh
Old 01-25-2021, 04:55 PM   #83
SCOTI
SCOTI's Avatar
Agreed. Nice that the steering rack change yielded increased turning ability.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-17-2021, 04:16 PM   #84
Richard D
Richard D's Avatar
Just found this thread, WOW! I never thought I would like those style hubcaps on ANYTHING, I have changed my mind.
Richard D is offline   Reply With Quote
Old 06-17-2021, 06:05 PM   #85
Richard D
Richard D's Avatar
P.S. Ho did you attach the side trim?
