Old 03-12-2021, 12:02 PM   #76
sirJim
Re: T-5 swap time
Originally Posted by Lugnutz65 View Post
Slepysal,
There’s a vendor (or two) on eBay that sells an EXACT repop of an S10 tail housing WITH A CABLE SPEEDO CONNECTION. I mention it because it would enable you to move the shifter position forward. It would end up just like the one in my picture.
I did the s10 tail housing swap and works really nice along with the old shifter from the granny 4
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 03-12-2021, 12:38 PM   #77
Asshat
Asshat's Avatar
Re: T-5 swap time
I wonder if it is worth the trouble of changing out the tail housing or just getting the mod for the electonic speedo.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 03-12-2021, 02:00 PM   #78
sirJim
Re: T-5 swap time
I guess it all depends on how much you want to do. I was doing a replacement mod with the counter gear stabilizer from 5speeds,com (lots of good info and youtube as well) so when I had it off might as well put the right one on. Plus I dident want cut the cab support right at the back of the hump, I like the position of the shifter too makes it look a bit more factory. The conversion for the electronic speedo I found for around 200 so I guess it all depends on what you want.
Old 03-12-2021, 02:57 PM   #79
pverge
Re: T-5 swap time
I am doing the same with my truck. I would like to cut the new hole in the hump, but my engine and transmission are out and don't know where to cut the hole. I'm taking my truck to the painter soon. How far back is the new hole from the original and what diameter? Thanks!
pverge is offline   Reply With Quote
Old 03-12-2021, 04:06 PM   #80
sirJim
Re: T-5 swap time
As I remember it was 8-8 1/2 inches back from original about 3-4" hole. Sorry burb is in winter storage. could see pretty much from the picture.
Old 03-12-2021, 08:48 PM   #81
pverge
Re: T-5 swap time
OK thanks
Old 03-14-2021, 01:06 AM   #82
slepysal
slepysal's Avatar
Re: T-5 swap time
I did a little interior clean up. I still need to install the carpet and make a console for it. Right now Im just enjoying drive her. You can see in the picture were my shifter sits. I like it .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-14-2021, 02:34 AM   #83
sirJim
Re: T-5 swap time
Attachment 2088988
Looks good!
Old 03-14-2021, 07:37 PM   #84
slepysal
slepysal's Avatar
Re: T-5 swap time
Looks good!
Thank you Sir !!!!
Old 03-15-2021, 10:05 AM   #85
88Stanger
88Stanger's Avatar
Re: T-5 swap time
This is very interesting... Lugnutz65 - great writeups!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 03-15-2021, 05:15 PM   #86
Asshat
Asshat's Avatar
Re: T-5 swap time
It finally arrived! Now I can get started.
292, 4-speed
Old 03-21-2021, 03:57 AM   #87
Asshat
Asshat's Avatar
Re: T-5 swap time
Driveshaft question:
Is a two-piece driveshaft (like the stock one I have) required for a long bed and T5 install? I read somewhere that the center carrier may be in the way when using a one piece.
Any advantages to one piece or two piece driveshaft?
Should I just have the driveline shop cut and modify my front shaft?
292, 4-speed
Old 03-21-2021, 12:17 PM   #88
slepysal
slepysal's Avatar
Re: T-5 swap time
my 60 long bed has a one piece driveshaft with no center bearing or carrier
Old 03-21-2021, 12:24 PM   #89
Asshat
Asshat's Avatar
Re: T-5 swap time
How long is it?
And, did your center carrier support get in the way?
Do you have a support for the tail shaft section?
292, 4-speed
Old 03-22-2021, 01:52 AM   #90
slepysal
slepysal's Avatar
Re: T-5 swap time
No clearance issues before the swap and none after. I had my drive shaft cut to 65" but yours may be different. I mounted the t5 like the original 3 speed n with no tail shaft support.
Old 03-22-2021, 02:05 AM   #91
Asshat
Asshat's Avatar
Re: T-5 swap time
Ok. I installed the T5, no support, yet.
I measured mine and it is 62.5”, but that’s probably because I have a GM 14 bolt rear end.
Hopefully getting the driveshaft this week.
And, I will need to remove the center support, ran a string from one end to the other and it looks like it will be in the way.
292, 4-speed
Old 03-23-2021, 11:22 AM   #92
Asshat
Asshat's Avatar
Re: T-5 swap time
Got a new driveline.
292, 4-speed
Old 03-25-2021, 09:50 PM   #93
slepysal
slepysal's Avatar
Re: T-5 swap time
right on !!!!! any updates?
Old 03-25-2021, 10:40 PM   #94
Asshat
Asshat's Avatar
Re: T-5 swap time
Yes - got the starter fixed, driveline installed, started it up on jack stands and went through the gears. All good so far. Ran out of time today, and I got a crap-load of meetings tomorrow, so probably won’t get it out of the garage till Saturday.
Also, purchased a 1x2 square tube so I could manufacture a support for the transmission.
Hoping it drives awesome!
292, 4-speed
Old 03-27-2021, 12:53 AM   #95
slepysal
slepysal's Avatar
Re: T-5 swap time
Great to hear. Post some more pics ! What type of bell housing are you running?
Old 03-27-2021, 03:30 AM   #96
Asshat
Asshat's Avatar
Re: T-5 swap time
Pretty sure it’s the stock bell housing for V8 and I6.
292, 4-speed
Old 03-27-2021, 12:07 PM   #97
slepysal
slepysal's Avatar
Re: T-5 swap time
I was asking because if you are using the stock bell housing that mounts to the crossmember you may not need to fab up a rear tranny support. The original manual transmission 4 0r 3 speed was just bolted up to the bell housing with no rear tranny mount.
Old 03-27-2021, 12:54 PM   #98
Asshat
Asshat's Avatar
Re: T-5 swap time
Yeah, I kinda figured that. I probably don’t need it, since the trans is pretty secure. It’s just a little extra support, especially for that long, heavy driveshaft.
292, 4-speed
Old 03-27-2021, 11:00 PM   #99
Asshat
Asshat's Avatar
Re: T-5 swap time
Drives good! It was a bit noisy cuz I didn’t have the cover on, but all the gears were smooth, top end much better. Not sure how fast though, no speedometer.
Now I need an e-brake, how do you guys handle this part?
Guess I’ve got some search to do.
292, 4-speed
Old 03-27-2021, 11:02 PM   #100
Lugnutz65
Lugnutz65's Avatar
Re: T-5 swap time
This. https://lugnutz65chevystepside.weebl...-1972-c10.html
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
