Old 07-10-2022, 07:16 PM   #76
NoNeck
NoNeck's Avatar
Re: Another one underway! Meet project Savannah
Some progress yesterday. We dropped the 6.0 ls engine in the frame and bolted it up using BRP motor mounts. Nice fit and it looks right at home.
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 07-10-2022, 07:49 PM   #77
CC69Rat
CC69Rat's Avatar
I found the bellhousing bolts Pop, well get the transmission detailed and bolted up maybe this coming weekend. Thank you for all your help, it looks great.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-13-2022, 11:18 PM   #78
NoNeck
NoNeck's Avatar
The Boyd's EFI gas tank is in the frame and it looks right at home.
POP
Old 07-17-2022, 10:47 PM   #79
NoNeck
NoNeck's Avatar
We installed a set of CPP tubular trailing arms today and detailed the axle tube U-Bolts and drop blocks. It's coming along.
POP
Old 07-18-2022, 08:34 PM   #80
Stickman
Stickman's Avatar
Looking good.
Stickman is offline   Reply With Quote
Old 07-22-2022, 07:26 PM   #81
NoNeck
NoNeck's Avatar
We installed the QA1 Rear Sway Bar and trick adjusters today. This is a nice set up and should help the old C10 handle great.
POP
Old 07-23-2022, 08:08 AM   #82
CC69Rat
CC69Rat's Avatar
Looks great Pop. Once we get the weight on it we can center everything up and torque it down. It should really help it in the corners !
Chad
Old 07-24-2022, 12:26 AM   #83
nlped
nlped's Avatar
Top notch, as expected!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-12-2022, 11:06 PM   #84
NoNeck
NoNeck's Avatar
We have the 4L80e transmission ready to install. Before we bolt it up we are replacing the rear main seal and cover gasket just for a little peace of mind. Much easier to do now than after everything is buttoned up.
Doug's Headers should be here the first of the week.
POP
Old 08-31-2022, 05:20 PM   #85
NoNeck
NoNeck's Avatar
Nothing like an awesome set of Doug's 1-7/8" Full Length Headers bolted to those Gibbons Motorsports Heads. That 6.0 will like all that extra air flow.
POP
Old 08-31-2022, 05:30 PM   #86
NoNeck
NoNeck's Avatar
POP
Old 09-18-2022, 01:30 PM   #87
NoNeck
NoNeck's Avatar
We worked on the rear of the engine yesterday and installed a new performance billet "barbell", new rear main seal and cover and GM Performance Flex Plate.
Chad added a quart of transmission fluid to the CircleD Performance Torque Convertor and we slipped it in place. This convertor was special ordered to give the stall we needed with the modifications that have been done.
The 4L80e is bolted up and we mocked up the location of the BRP Hot Rods transmission crossmember. We are going to set the engine angle before we bolt the crossmember in place.
It's starting to come together!
POP
Old 10-10-2022, 12:15 AM   #88
NoNeck
NoNeck's Avatar
The braided stainless steel fuel lines and AN fittings arrived today. We will be working on the lines to connect with the Boyd Welding gas tank. The AN fittings work great and look really clean too. One more thing to cross off our list.
POP
Old 10-10-2022, 05:34 AM   #89
zicc1835
zicc1835's Avatar
Looking fantastic are you having those lines made up by someone some place?
zicc1835 is offline   Reply With Quote
Old 10-12-2022, 12:23 PM   #90
NoNeck
NoNeck's Avatar
We are putting together our own system using Russell Stainless Steel Braided Fuel Hose and assorted -6 AN fittings. An Earl's -6 ORB (O-Ring) fitting was used on the tank outlet. When everything is plumbed we will add some pictures and list some part numbers.
Thanks, and stay tuned!
POP
Old 10-12-2022, 10:22 PM   #91
zicc1835
zicc1835's Avatar
POP
Thank you
Old 10-18-2022, 10:17 AM   #92
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Great build so far...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-05-2023, 11:00 PM   #93
NoNeck
NoNeck's Avatar
It has been a while since we have posted. Time to get back on track and get this old girl finished up.
We installed an Aeromotive Fuel Filter with return line to the frame and finished up the braided hoses. Russell brackets secure the hoses up to the frame, Once the cab is painted and put back on the frame we are going to plumb in an Aeromotive Fuel Pressure Regulator to complete the package.
Stay tuned...
POP
Old 05-06-2023, 07:10 AM   #94
72 tigger
72 tigger's Avatar
Nice build- please keep us posted!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 05-08-2023, 11:54 PM   #95
NoNeck
NoNeck's Avatar
Thanks for the nice compliments guys,
We bolted the powder coated core support on the frame today. Now it's beginning to look more like a truck. It's kinda staring out of the garage.
POP
Old 08-23-2023, 11:23 PM   #96
NoNeck
NoNeck's Avatar
It's been awhile since we have been on here. Life sometimes dictates your priorities.
We installed new MSD Coils on the engine and checked the fit of the spark plug wires. We were a little concerned that they might be too short, but no problem. The length is spot on.
A new FrostBite Aluminum Radiator/Fan Assembly arrived today. Nice setup! We will be installing it soon. I will add some pictures when we get it in.
POP
Old 08-28-2023, 05:01 PM   #97
CC69Rat
CC69Rat's Avatar
Looks great Pop! Im glad we went with the black valve covers.
Maybe we can drop the radiator in this weekend. We'll see how the week goes I guess.
Chad
Old 10-01-2023, 12:04 AM   #98
NoNeck
NoNeck's Avatar
More progress this week...
We installed a Frostbite Aluminum Radiator that comes complete with Cooling Fans. These are made specifically to fit the '67-72 trucks and fit really nice. We are still looking for some trick upper brackets that work. We tried new 4-row upper brackets, but they don't fit very well.
We worked on the Radiator Hoses to get the best fit possible. For the lower hose we used a Gates 22437. We had to trim the end that slips over the radiator outlet as shown in the photo. I can get a measurement if that helps anyone. It looks factory on there.
For the Upper Hose my buddy at O'Reileys let me take my wire template behind the counter and look through all of his hoses. The closest hose that I could find is a Gates 22047 which is for a '94'97 Ranger 4 Cylinder upper hose. At the radiator inlet you have to twist the hose just slightly to get the right angle. We had to cut about 1" off of the end going to the water pump. It might need to be cut a little more but we want to wait until the final radiator brackets are on.
Just a little at a time...
POP
Old 10-01-2023, 12:10 AM   #99
NoNeck
NoNeck's Avatar
Here is a picture of the finished Lower Hose.
POP
Old 10-01-2023, 08:00 PM   #100
zicc1835
zicc1835's Avatar
nice progress
