Old 09-29-2021, 08:10 AM   #76
Gregski
Post Whore
Gregski's Avatar
Re: My Dusty 71 GMC a Mother & Son Project
so then we spent 9 hours figuring out exactly precisely which fan spacer to run in order to get the best air flow (pronounced protect our fingers from getting sliced off by the fan)
Gregski is offline   Reply With Quote
Old 09-29-2021, 08:11 AM   #77
Gregski
Post Whore
Gregski's Avatar
mandatory stare and compare if you dare
Old 09-29-2021, 08:12 AM   #78
Gregski
Post Whore
Gregski's Avatar
Originally Posted by Blue GMC View Post
May be a little more help on this one as Your in my era now.
Awesome, lay it on me brother, any help is greatly appreciated, stick around for the door fitment episode!? ha ha
Old 09-30-2021, 08:27 AM   #79
Gregski
Post Whore
Gregski's Avatar
cool, so you replaced the water pump and the radiator and fixed the cooling issue, what's next?
not so fast Tiger - it wasn't until we fixed and dialed in our distributor that the overheating problem went away
I believe we discovered that the old vacuum can was not vacuuming therefor not advancing the timing with manifold vacuum (highest at idle type of thing)
Old 09-30-2021, 08:28 AM   #80
Gregski
Post Whore
Gregski's Avatar
mandatory stare and compare of the old not working/non adjustable vacuum canister and the new adjustable one
Old 09-30-2021, 08:31 AM   #81
Gregski
Post Whore
Gregski's Avatar
Re: My Dusty 71 GMCe Electruck
then we Geeked out and replaced the weights and springs in our dizzy to really dial it in
and let me tell you she runs cold with only holy water in the rad now
Old 09-30-2021, 08:34 AM   #82
Gregski
Post Whore
Gregski's Avatar
bruh, this is boring, don't you have some other bright ideas?
Me: "hold my beer!"
got the cargo light working
Old 09-30-2021, 08:36 AM   #83
Gregski
Post Whore
Gregski's Avatar
also got the dome light working, sometimes ladies and gentlemen you gotstoo take the small victories, am I right or am I right?
Old 09-30-2021, 08:38 AM   #84
Gregski
Post Whore
Gregski's Avatar
energized by my electrical prowls I decided to take it up a notch
[yes this is from my "In love with cheap digital gauges - era!"] (no idea why I'm quoting myself?)
Old 09-30-2021, 08:41 AM   #85
Gregski
Post Whore
Gregski's Avatar
Warning: if you think my gauge bazel cluster thingie has seen better days you should have seen it wrapped in upholstery and full of glue before i cleaned it up
Old 09-30-2021, 08:44 AM   #86
Gregski
Post Whore
Gregski's Avatar
yes one of the bottom four holes is crooked and no I did not cut it out like that, the PO must have done it, I would never hole saw a crooked hole (ha ha)
Old 09-30-2021, 08:47 AM   #87
Gregski
Post Whore
Gregski's Avatar
OMG, this gauge cluster is Fugly, how do we tell him?
hold on there Sparky it's about to get a whole lot worse
it was a temporary solution so that we could take Dusty camping later on and not overheat or under charge the battery or God forbid go 97 in a 35 MPH zone type a thing
Old 09-30-2021, 09:39 AM   #88
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
What's your addy? I will send you a better bezel. Man turn that beaver loose out of your garage.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-30-2021, 09:51 AM   #89
Gregski
Post Whore
Gregski's Avatar
that's friggen hilarious, no doubt huh, I soooo appreciate the offer, but hold off for the separate follow up Dusty Build Thread II (aka the sequel - coming soon) you may not like the direction we are going, ha ha
Old 09-30-2021, 10:46 PM   #90
dagnabbitt
dagnabbitt's Avatar
Enjoying the build, and glad to get in on the ground floor at the beginning of a build thread of yours!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-01-2021, 12:22 AM   #91
Gregski
Post Whore
Gregski's Avatar
I'm glad, and welcome, you won't be disappointed things are about to get exciting
Old 10-01-2021, 05:58 AM   #92
Dieselwrencher
I'm in. Just don't say you're 2JZ swapping it.
Ryan
Old 10-01-2021, 08:16 AM   #93
Gregski
Post Whore
Gregski's Avatar
Bwhaaa haa ha (that's the most underrated comment on here)
Old 10-01-2021, 08:18 AM   #94
Gregski
Post Whore
Gregski's Avatar
so what is he going to do, the [ahem] suspense is killing me
did somebody say suspension?
Old 10-01-2021, 08:40 AM   #95
Blue GMC
Blue GMC's Avatar
Now that doesn’t look too crazy not like it’s a set of switches to make Dusty jump
Blue GMC is offline   Reply With Quote
Old 10-01-2021, 08:56 AM   #96
Dieselwrencher
Is the C notch and dropped spindles coming this afternoon?
Ryan
Old 10-01-2021, 09:35 AM   #97
Gregski
Post Whore
Gregski's Avatar
ha ha there will be no C notching on this thread, I swear any time I see yet another C notch welded in a part of me cries like a baby nobody wants their truck in the weeds (and there goes half the readers)
Old 10-01-2021, 11:50 AM   #98
Gregski
Post Whore
Gregski's Avatar
now before we did anything first we had the truck laser scanned for precise and exact measurements and rendered this to scale drawing
Note: if your truck does not match these specs exactly, check your truck, there must be something wrong with your truck
Old 10-01-2021, 12:01 PM   #99
Gregski
Post Whore
Gregski's Avatar
so if I recall correctly (mind you we did this 3 years ago) but lost the pics and only recently found some of them, we done did the rear coils first, by the way I love the trailing arm rear suspension on these trucks, so unique
Old 10-01-2021, 12:02 PM   #100
Gregski
Post Whore
Gregski's Avatar
alright, mandatory stare and compare
folks, does the stock rear coil spring look normal to you or does it look like it's been heated up and collapsed some? I ask because I don't know what they are supposed to look like, so any feedback is greatly appreciated
