03-22-2011, 06:37 PM | #976 |
VA72C10
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Here you go....
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 03-22-2011 at 06:42 PM. |
03-22-2011, 06:42 PM | #977 |
67cheby
wow...very nice guideline !!
03-22-2011, 06:43 PM | #978 |
VA72C10
It only took me 3 tries to put the right numbers on
Looking for a 67-72 swb or blazer project in or around VA. |
03-22-2011, 06:53 PM | #979 |
www.67HEAVEN.com
Drew,
Having done a complete rebuild of my '67 Corvette, I have an immense appreciation for your creativity, craftsmanship and amazing speed. That truck will be a real beauty and a wonderful "family" vehicle. Well done hardly seems to be adequate praise.
www.67HEAVEN.com 2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme) 1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme) 1967 Belair 2-door-post (project) 1967 Corvette 427/435 coupe (now 502/502 red road warrior) |
03-22-2011, 07:45 PM | #980 |
03-22-2011, 07:55 PM | #981 |
I think it may be the patented cross draft spray booth
I have the same one, and its perfect for what I do, and no complaints from any neighbours yet, knock on wood. Looking good. Darren
67- 72 Parts collecter |
03-22-2011, 07:59 PM | #982 |
PROJECT 7DEUCE
How far is ar from tn hahhahahha Paint looks killer and reminds me of kevins low buk build..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-22-2011, 08:14 PM | #983 |
Life, Be In It.....
I have seen this thread many times but never opened it till now. That is quite a build and will be a sweet ride. Nice work
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
03-22-2011, 08:41 PM | #984 |
Lucky Teter at the wheel
DANG, I'm gone to the soccer fields for 2 hours and there are 10 posts!
Thanks so much for the diagram!!! Next time though, could you color code each screw hole for me?????? I just checked another door and my bed front and both are 13.5 inches from the center of the upper trim hole down to the body line (a 13.5 inch white stripe). Is this correct too? I think this works out the same also on the rear of the fender. I don't want to paint it twice!!!
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
03-22-2011, 10:19 PM | #985 |
I got the hood done tonight, and all was going well until I had a couple of critters decide to join in the fun. I got one out with the tweezers, but the other was just a little guy. He got painted over on the 4th coat, but that one I laid on a little too heavy and created a signature on the front edge. Friday I will wet sand the run and my little friend's paw prints and shoot one last heavy - but run free- coat and call it done. While I am wet sanding with 400 grit I will use my block and knock down the orange peel so the last coat will turn out really flat. My goal all over will be like the 4th pic where you can almost read the writing on the fluorescent bulbs. If I can't get there by painting I can always buff it there.
03-22-2011, 10:30 PM | #986 |
Wow man, you got that last coat pretty flat.You can almost read the lettering on the light bulb.After seeing this build,it has severely diminished my fear of doing my own paint.Not only would it save me truck loads of cash, but the satisfaction of doing it yourself and doing it well has a lot more value than paying some one to do it.I think you deserve truck of the year even before its done.Nice work Drew.Yall be good
03-22-2011, 10:33 PM | #987 |
VA72C10
I have 16" between center of the holes on the rear of my cab. And same between the paint on my fenders.
Not sure of the paint line as mine is all white Maybe someone else will know where the break should be (center of holes or top of trim)
03-22-2011, 10:37 PM | #988 | |
Truck of the month would be awesome (not so sure about year), but the category would have to be "in process".
03-22-2011, 10:39 PM | #989 |
I got 13.5 to the body line, I don't have any parts with trim holes top and bottom to measure between the holes.
03-23-2011, 12:49 PM | #990 |
I have wanted to do one of these for years, not enough knowledge or time, great attention to detail
i ended up with this as my project, still workin on it it started out as a 1 ton long bed dually, i should be gettin from paint shop today ( stayed with factory white) Last edited by Rumble; 03-23-2011 at 12:50 PM. |
03-23-2011, 01:06 PM | #991 |
Lookin' good Drewski. What are you going to do for a dash now that you crammed that full AC into it?
03-23-2011, 01:43 PM | #992 | |
Junk Yartist
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
03-23-2011, 04:38 PM | #993 |
Can I get a referral discount on my membership???
03-24-2011, 12:33 AM | #994 |
Funny you should ask, mrchrishill, I have a few ideas up my sleeve but I haven't fully worked them out yet.
03-24-2011, 07:40 AM | #995 |
Still Learning
Drew, did you already say in here what kind of paint you're shooting? Is that single stage acrylic enamel, urethane enamel, or polyurethane? It looks great, btw, I know first hand about critters in the paint (still have one or two I need to buff out of my son's paint). I have had another fun problem with sweat building up on me and dripping on the paint. If you wear coveralls hood and resporator it gets HOT. keep the pics rolling!
03-24-2011, 09:32 AM | #996 |
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Post #855 shows he is using Nason acrylic enamel
03-24-2011, 09:37 AM | #997 |
'67 C-10 LWB Driver
i doubt it, but i'll let ya paint my truck for free!
67Cheby probably take you up on that offer, in fact we'll pay next years member ship fee for you for painting our rigs! JT
'67 C-10 LWB - My Build Thread '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
03-24-2011, 09:40 AM | #998 |
67cheby
thats for sure
03-24-2011, 10:16 AM | #999 | |
03-24-2011, 10:27 AM | #1000 |
WOW, 1000 posts and 66,000 views !!! Thanks everyone, couldn't have done it without you.
