Old 12-22-2017, 12:44 AM   #976
solidaxel
solidaxel's Avatar
Re: How about some pics of bagged 47-59
Good looking green G M C !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-26-2017, 04:19 PM   #977
Slowy-gonzalez
Was able to get a better pic of the 57, aired up and down
2017 king ranch power stroke
57 chevy big rear window, camaro front clip, rear is notched
57 chevy truck, air ride, ls swapped.
52 chevy truck waiting its turn.
Slowy-gonzalez is offline   Reply With Quote
Old 01-03-2018, 09:08 AM   #978
lower50's
lower50's's Avatar
Love the GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-04-2018, 10:51 PM   #979
mud.man.rj
mud.man.rj's Avatar
Nasty looking.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-05-2018, 10:12 PM   #980
gigamanx
That's sick man! Odd question...did you go with hard lines or soft lines? What size?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 01-06-2018, 09:41 AM   #981
e015475
e015475's Avatar
Gigamanx, I think I have the same question.
Getting ready to plumb my airbag system and would like to hear experiences with either hard or soft line too.
DOT approved push-in fittings are kinda expensive and I hear a lot of guys complain about chasing down leaks.
My plan is to plumb the airbags in -4 AN fittings (1/4" tube) with aluminum line. Stainless might be a better option, but it is difficult to flare without cracking and the fatigue resistance of the aluminum should be ok if it is fastened to the chassis correctly. To keep the cost of down for the AN fittings, I'm using steel JIC fittings, nuts and sleeves.
I have a Parker Rolo-flair tool to make the flares in the aluminum and have had good luck making leak free connections with it. For the threaded connections, the plan is to use a anaerobic thread seal (Locktite 565) instead of teflon tape or pipe dope.
Any other suggestions from guys with bagged trucks?
e015475 is offline   Reply With Quote
Old 01-06-2018, 12:29 PM   #982
99 to Life
99 to Life's Avatar
there isn't much difference in either setup, more aesthetics rather than function. I had no problems with soft line and PTC fittings. I used blue monster tape on threads. I used 1/2 lines on my last bagged truck with accuair manifold. Current one Im using 3/8 with manual valves. I'm sure you may read plenty of debate out there, but I'm just giving my take with it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-07-2018, 11:26 AM   #983
DeeJayNOLA
DeeJayNOLA's Avatar
What's your ride height aired up?
Representing for the 504.
DeeJayNOLA is offline   Reply With Quote
Old 01-07-2018, 09:49 PM   #984
Slowy-gonzalez
I recently bought this truck, will measure ride high tomorrow,
Old 01-09-2018, 09:25 AM   #985
lower50's
lower50's's Avatar
I am using 3/8" lines Accuair valve. I ran rubber air line up front and have PTC nylon line out back. So far 10,000 mi all good. My truck is 5000lb.
1951 MG TD
Old 01-09-2018, 04:33 PM   #986
Mains52
Originally Posted by e015475 View Post
'49 GMC on bags....running boards will be on next week
From the back...pls ignore all the parts in the back.
From the front.....
Did you C notch your frame? If not do you have a picture of just the rear end bag set up on the frame? Thanks Great looking truck.
Mains52 is offline   Reply With Quote
Old 01-09-2018, 08:13 PM   #987
e015475
e015475's Avatar
Sorry I didn't mention that is was a Jag IRS - and there's no C notch. It was narrowed about 3" side to side and tube steel half shafts replace the Jag's forged half shafts.
The ladder truss supports the differential and is mounted on urethane bushings. The bolt that hang the diff in the truss are about even with the bottom of the wood boards in a stock bed.
This bracket assembly holds the differential assembly in position and keeps the pinion angle constant
The airbags ride on a trailing arm that connects to the Jag's LCA. It is a 5" Slam bag that does the same job as the Jag's coil-over springs.
Another photo
The front of the airbag trailing arm - it has the same roll center as the LCA of the Jag IRS
And yes. a four link and a c-notch would have been a lot easier. But it's all about the nostalgia of the Jag rear end
Old 01-09-2018, 08:17 PM   #988
e015475
e015475's Avatar
Oh, and here's a photo of the truck with the running boards on sitting on the bump stops. There's about three inches from the running boards to the concrete floor.
Old 01-09-2018, 08:19 PM   #989
mud.man.rj
mud.man.rj's Avatar
The jag rear is well worth it, top notch job.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 01-09-2018, 08:27 PM   #990
e015475
e015475's Avatar
When I was a kid in the 60's, a lot of the plastic model kits of hot rods had Jag rear ends - I'm sure there's better solutions out there, but it is all about the nostalgia and childhood memories.
Thanks for the compliment, Mudman!
Old 01-09-2018, 08:30 PM   #991
mud.man.rj
mud.man.rj's Avatar
Well you know many won't see it or even know what it is but...you do and I think of that on my own builds, it's about what we want and like right, but cool when others appreciate what we've built too. Keep at it, very nice build.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 01-10-2018, 03:09 PM   #992
Mains52
Thank you for the pictures and explaination. Very nice work.
Old 01-12-2018, 12:44 AM   #993
cwoodling1
Originally Posted by Coach529 View Post
Looking good man! You have done a great job on the build!
cwoodling1 is offline   Reply With Quote
Old 01-12-2018, 07:33 PM   #994
Fiftee3
Fiftee3's Avatar
Very nice GMC man,
Make sure you get a couple of linear actuators so you can flip a switch and make your wood bed open, Be a shame for others not to see your work. Very very nice. To me, its always whats on the inside...
"All the best, Phil"
My 53 IFS air bagged Upgrade Here
One of my threads for this build...
http://67-72chevytrucks.com/vboard/s...12#post7662512
Fiftee3 is offline   Reply With Quote
Old 01-12-2018, 08:27 PM   #995
e015475
e015475's Avatar
Thanks for the nice words!
At this point, I just want to drive it! No more 'enhancements'/science projects.
Old 02-15-2018, 09:41 PM   #996
Beartrap
[attach]Name:  2-15-17.jpg
Size:  43.5 KB[/attach] 1951 looooong bed
Beartrap is offline   Reply With Quote
Old 02-15-2018, 11:29 PM   #997
cwoodling1
Originally Posted by Beartrap View Post
[attach]Attachment 1753100[/attach] 1951 looooong bed
Very Nice man! I’m building a 50 Gmc longbed myself
Old 02-16-2018, 09:05 AM   #998
lower50's
lower50's's Avatar
New wheels.
1951 MG TD
Old 02-18-2018, 06:54 PM   #999
gigamanx
Heck yeah that is awesome!
Originally Posted by lower50's
New wheels.
Artillery style. Nice to see a bit of a spin on the ole smoothies.
Old 03-01-2018, 01:16 AM   #1000
ChevyJay
Originally Posted by bombclub View Post
Does anybody know where to pick up these dog dish caps, Thanks Fellas
I LOVE the look on these.
ChevyJay is offline   Reply With Quote
