Closed Thread
Old 08-03-2014, 10:39 PM   #976
BADAZ chevy guy
BADAZ chevy guy's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Econman View Post
Installed the new(est) water pump, put on the fan with a new fan clutch and put 2 hole-plugs in the intake. Then I pulled out the grimy, old P/S pump and brackets - sprayed, scraped, sprayed, wire-wheeled and cleaned some more... Then primed, painted and bolted them on.. along with new motor mounts. Filled my oil filter with oil and screwed it on...
Attachment 1285350
Just curious. How much did you pay for the Vortec heads? Local junk yard here has them for $65.00 ea. But I'd have to have a machine shop rework them.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline
Old 08-04-2014, 12:41 AM   #977
Econman
Econman's Avatar
I pulled 8 heads at the junkyard and only one wasn't cracked. I bought it for $45, but had to completely rebuild it. I bought a new one also and had the guides machined down and screw-in studs put in. I've probably got $650-700 in the pair.
Econman is offline
Old 08-04-2014, 01:31 PM   #978
ole dollor
ole dollor's Avatar
Originally Posted by jacob822 View Post
I bought it! 1972. changed plugs, wires, cap, rotor, points, and coil. so stoked! its my new driving project.
looks like a great place to start....welcome to the forum from Texas , a little spit and polish and your ready to go have fun.
ole dollor is offline
Old 08-04-2014, 07:59 PM   #979
MONTE
MONTE's Avatar
Trying to get this cleaned up and looking nice.
Working on the A/C and getting my seat changed to black.Name:  IMG_3757.jpg
MONTE is offline
Old 08-04-2014, 08:38 PM   #980
jmorri34
jmorri34's Avatar
Changed some parts on the top of the motor to shiny it up a little!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline
Old 08-06-2014, 02:04 PM   #981
Econman
Econman's Avatar
Well, so far today, I've installed a new spacer between the balancer and crank pulleys, mounted the right side motor mount, installed a new stainless heater hose fitting into the water pump, painted the short head bolts, cleaned up my carb and installed it with a new heat insulator gasket.
Later, I'll probably clean up the ram horns and brush Por-15 gray manifold coating on them.
Econman is offline
Old 08-06-2014, 02:37 PM   #982
ole dollor
ole dollor's Avatar
well the west Texas heat ,sun, and not much rain has taken a toll on old dollor's wood bed ....time to do something different . started sanding last night and will try and finish the prep work today , decided to go with a spray or roll in bed liner and see if that will last longer, living outside is hard on pickups. pic's will come later...Don
Old 08-06-2014, 03:53 PM   #983
colgad
colgad's Avatar
I charged up the Vintage Air in the 67 today!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 08-06-2014, 07:56 PM   #984
texjake
texjake's Avatar
I figured it was time to repair the holes in the tailgate left by the PO. I heard that he backed up too far while attempting to hook to up his 5th wheel trailer & punched two identical holes in the tailgate. Believe it or not this was my first time to ever do any sheet metal repair in my lifetime. Not too bad for a rookie huh?
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 08-06-2014, 09:45 PM   #985
texjake
texjake's Avatar
I feel your pain Don! My wood bed is still in dire need of repair. It's just so expensive and labor intensive to do. I think I'm going to start on it when the 100 degree days start cooling off.
texjake is offline
Old 08-06-2014, 10:05 PM   #986
Motoxrrar
Why is it labor instensive?
And why expensive ?
Just some simple tongue and groove
Motoxrrar is offline
Old 08-06-2014, 10:25 PM   #987
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
And why expensive ?
Probably because he's contemplating doing it right.
Not like my $50 surplus wood floor job.....Which actually seems to be holding its own...for now.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-06-2014, 10:26 PM   #988
Motoxrrar
For 50$ that looks damn good, and different I like it! Great job
Old 08-06-2014, 10:31 PM   #989
ole dollor
ole dollor's Avatar
its not to bad if you build your own bed kit, that's what I did ,but the clear coat went first and the stain was looking real bad , ole dollor is not a show truck so its time to put roll in bed liner and hope the west Texas sun leaves it alone....hey your tail gate is looking good. looks like a pro. repair ..
Old 08-07-2014, 01:09 AM   #990
texjake
texjake's Avatar
And why expensive ?
Yea, it's labor intensive for me. I had a spinal cord injury 30 yrs ago due to a rodeo accident, so I don't get around like I use to, but I still get stuff done and can dang sure work on classic cars & trucks - it's my passion. For my situation I am going to remove the bed to make it easier to remove all the 72 bolts and not have to deal with the driveshaft & dual exhaust, etc.. being in the way. It can be expensive if I was going to buy a bed kit, I've seen some costing as much as $500 or more. But luckily my neighbor (that has a wood shop) has generously offered to cut & tongue/grove & stain the boards for me, so that's the route I am taking for my wood bed. And just buy the strips & bolts from classicparts.com.
texjake is offline
Old 08-07-2014, 01:11 AM   #991
texjake
texjake's Avatar
Thanks Don! Hopefully soon it will be headed to the paint booth once I get the wood bed done.
texjake is offline
Old 08-07-2014, 01:20 AM   #992
texjake
texjake's Avatar
Wow! That looks nice! Very different & I like that, something you don't see everyday. I'm not sure a wood bed like that would survive out in the extreme weather conditions here. Since mine is parked out the elements 24/7, its a go truck - not a show truck.
texjake is offline
Old 08-07-2014, 01:31 AM   #993
UNEASYRIDER
UNEASYRIDER's Avatar
Put my cab paint dividers on
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 08-07-2014, 01:43 AM   #994
magwakeenercew2jh
Yeah. I hear ya.
It has been around 105 or so for a couple of weeks up here by Yosemite. It only gets cold....like around 20 or so for any kind of "stretch"
a couple of times a winter. We get different amounts of snow. But sometimes, we get snow in April...Here's some light stuff:
RAT has to live outside 24/7, too. And, she gets used like a truck. Maybe not as heavily as some....Sits at a few shows as a "driver" against
some real pretty $$$ up show-rides. I'm not there to win, though. Just to jawbone.
But, I have to admit that when I put something in the bed, either the mats or a tarp go down. I have to figure out some sliders for this floor.
So far, that hasn't kept me from using her like a truck. And, oh, I have to admit that RAT has a cover on her. And during the rain/snow months
has a water-tight snap on rails tonneau.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-07-2014, 01:54 AM   #995
texjake
texjake's Avatar
Yeah. I hear ya.
Did yours come with a wood bed floor or did you put down that wood floor on top of a steel bed floor? It seems that the floor is holding up nicely & keeping it covered really helps a lot too.
texjake is offline
Old 08-07-2014, 02:22 AM   #996
magwakeenercew2jh
The bed's steel.
Two sheet metal screws thru the two last pieces of wood at the far right,
and five screws thru each of the two aluminum strips at the front and rear
of the bed.
It's just t and g (real wood) flooring we had left over from the house
(I actually made sure they left an extra box).
The whole floor comes out in less than five minutes. I numbered them
and put an arrow to the front on each piece. If I need to (only one time so far),
I can put it back in under fifteen minutes.
It's not for everyone. But I had the stuff.
And, for about fifty bucks.......
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-07-2014, 12:34 PM   #997
kneesnthebreeze
pretty much sums it up
kneesnthebreeze is offline
Old 08-07-2014, 01:49 PM   #998
MercRising
Oh god that funny^^^^^^^^^^^^^
Anyway, I painted my cab white and pulled the front bumper to do the same.
MercRising is offline
Old 08-08-2014, 04:39 PM   #999
Econman
Econman's Avatar
Finally got my exhaust manifolds stripped/cleaned and painted with Por-15 factory gray manifold paint.
Econman is offline
Old 08-08-2014, 05:06 PM   #1000
texasld
texasld's Avatar
So very well said!
More clean, prep, paint/coat..repeat. But it's looking better.
Got the front-end minus the sway bar and gear box done. I need to take the sway bar to the blaster. Whats the best method of cleaning the gear box before I do a rebuild on it?
Here are some more pictures. I really am liking how the red and black is turning out. My HF powder coat system is working out alright.
Name:  Shock Mount.jpg
Please excuse my fat finger in that last shot.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline
Closed Thread
