09-17-2014, 08:51 PM | #1001 |
Re: My 57 Pro Street
This is an awsome build. great job
2000 Chevrolet Silverado Z71 1965 Chevy C-10 on '61 Apache Frame [90s Build] 1997 3500 Chevrolet Custom Mega Cab Project My son's '92/'93/'94 GMC K2500 Conversion Project |
09-18-2014, 12:33 AM | #1002 |
09-18-2014, 08:41 AM | #1003 |
I can appreciate the work you have done so far on the cab. I'm at the same stage with smoothing seams. Great build.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
09-19-2014, 03:56 PM | #1004 |
Spent a few hours reading back your whole build...did someone allready said you are a true Craftsman???
I learned a lot only from looking at your pics! It's like a book you must have when you have a TF truck!! So, keep building, so I can read it with pleasure!! Great truck!!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
09-19-2014, 04:01 PM | #1005 | ||
I wish I was better at body work. What takes me hours I'm sure a pro could do in no time. Quote:
When I go back and look at what I have done I can't believe it sometimes myself. There's no way I could do it again. Kim |
10-06-2014, 08:10 PM | #1006 | |
Magic happens with a welder and a grinder. My custom tubular c10 laying rockers. http://67-72chevytrucks.com/vboard/s...78#post5970778 |
10-06-2014, 11:14 PM | #1007 |
Thanks.
Kim |
11-04-2014, 10:56 PM | #1008 |
A little up-date.
Been getting into the body work. I have the cab tilted on its back so it's a little easier to work on the roof. I welded up the over hang and filled it in. Then to the roof itself. It was in pretty decent shape. A couple pics after epoxy and a little sanding. You can see it needs a little work. Kim |
11-04-2014, 11:03 PM | #1009 |
I got some Slick Sand.
This stuff is really thick but makes it easy to get the whole surface covered. I hit with some 80 grit and then used dry guide coat. This stuff went on real easy and gets into the finest of scratches. A lot more sanding and then another couple coats of epoxy and it looks pretty good. Will have do do a final sanding and then seal before paint. Kim |
11-05-2014, 12:20 AM | #1010 |
Really taking shape, nice work. Who makes slick sand..Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-05-2014, 12:21 AM | #1011 |
Ahhh, I remember those days, priming, sanding, priming, sanding........
Looking good, carry on. Jim
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
11-05-2014, 07:43 AM | #1012 |
Looking really good Kim. Just a question because I'm at a similar state on my build, but why more epoxy over the slick sand rather than go straight to sealer? Jim - I'd hope you remember those days, you've been living them for quite some time now haven't you
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
11-05-2014, 08:29 AM | #1013 |
Right on!
Good to see an update again Kim! Hope all goes well now?
11-05-2014, 09:33 AM | #1014 | |||
It's made by Evercoat.
I found it on Amazon for $60.00 a gallon with the hardener. Quote:
Even though this part of the build can be tedious I'm motivated to stay with it. Kim |
11-05-2014, 09:37 AM | #1015 |
Good looking progress on your roof. I love SlickSand - I'm just a couple of years away from needing it on my project! Have you decided on a paint color?
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
11-05-2014, 04:36 PM | #1016 |
I have been using Urofill, not as thick a build up as Slickcoat, but thicker than regular primer, and compatible with 2K sealer.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
11-05-2014, 08:04 PM | #1017 | ||
Right now I'm leaning toward a light metalic blue that chevelle's were painted in the mid 60s although that may change. Quote:
Kim |
11-06-2014, 12:16 PM | #1018 |
Glad to see you are back at it. Looking good.
11-20-2014, 12:16 PM | #1019 |
Wow.....you do some amazing work man!!
11-20-2014, 01:19 PM | #1020 |
kim
looking real good !!! |
11-20-2014, 03:14 PM | #1021 |
Thanks guys.
Not much to report other than just trying my best at body work. Kim |
01-04-2015, 02:08 AM | #1022 |
Kim, I am glade to see you are making progress, thank you for your comments on my project. I see you are using a dry guide coat are you wet or dry sanding and can you do both?
01-04-2015, 10:47 AM | #1023 |
Looking good I hate body work!
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
01-04-2015, 11:54 AM | #1024 | |
Not sure how wet sanding would work with the dry guide coat. It may just rinse it off. As you can tell I'm new at this part of the build. It isn't the most fun part of the build but it keeps me out of trouble. Waiting for the weather to get a little warmer so I can get back at it. Kim |
01-06-2015, 12:49 PM | #1025 | |
Certified Car Nut
Another point about block sanding that can lead to mistakes is this. Let the sand paper do the work. In other words don't muscle and push down hard while sanding. Just let the black guide across the panel in an x pattern. Applying pressure will lead to problems. Last edited by Kabwe; 01-06-2015 at 12:58 PM. |
