Closed Thread
Old 07-26-2011, 09:05 PM   #1001
bguild
bguild's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
anybody running 305/35/20 tires in the rear? I just bought a used set of Pirelli and I am going to try it. Granted i have my fenderwells and bed floor out so I am not worried about rubbing there. I am worried a little stretching that wide of a tire on a 10in rim. We will see. I hope they work because it should look pretty cool.
Now i just need to buy some rims.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline
Old 07-26-2011, 09:16 PM   #1002
Strut
Strut's Avatar
I have 315/35/20 on my rear... Its a 72, I mini tubed the back 1 3/4inchs.
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline
Old 07-26-2011, 09:21 PM   #1003
bguild
bguild's Avatar
whats the width of your wheel? Looks great
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline
Old 07-26-2011, 09:23 PM   #1004
Strut
Strut's Avatar
They are 20X10 on the rear and 20X8.5 on the front. Thanks!
1972 Chevy C10 SWB
2008 Yamaha R1
Strut is offline
Old 07-26-2011, 09:36 PM   #1005
wildrib
I have 305/35/20 on 10 inch coys they work fine
wildrib is offline
Old 07-27-2011, 01:35 PM   #1006
72SWBURG
I have already talked to him,... and he's waiting for a good part number to order two more 20x8.5's. I will be returning my old ones. Also,... for the 67-72 guys,... the rear 20x10's will require a spacer. I believe the 6.25" BS will be too much.
I'm going to try to fit these on my '69 (with the narrow '69 rearend and 5-lug conversion axles) I will probably run a 1" or 1-1/4" spacer.
(After I do some measuring)
I am going to run Boss 338's. 18x8 with 4.5 BS on the front (4.5 BS is all they offer) and 18x9.5 with just over 5" BS (this is also all they offer).... Will I need spacers or anything special for my 72 SWB....
72SWBURG is offline
Old 07-27-2011, 02:05 PM   #1007
72SWBURG
Originally Posted by djracer View Post
I hope I don't have these issues on a mustang II rotor. I bought these in a 18x8 and a 18x9.5 for my brothers 59 truck. We have the rears on and haven't done the fronts yet.
What size Rubber did you go with??
72SWBURG is offline
Old 07-27-2011, 06:17 PM   #1008
Hickup pickup
Hickup pickup's Avatar
Mine fit like a glove!
2-20, 2-21 whatever it takes!
Hickup pickup is offline
Old 07-27-2011, 10:13 PM   #1009
hotrodhomi
hotrodhomi's Avatar
Nice looking glove.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline
Old 09-03-2011, 06:27 PM   #1010
Andy4639
Old member
Andy4639's Avatar
Question Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
The wheels will fit fine. The tires are what hits. That doesn't mean the wheel company is at fault because we pick tires bigger than what we should! My wheels had only a small issue. That was fixed in about 10 minutes. The center cap would go on but I was affaid it may pop off during the ride home so we shaved just enough off each spindale to satisfy me they wouldn't and they didn't.
The wheels fit fine. Why everyone is making this into something it isn't I don't understand. If you don't want the tires to scrub buy orignal wheels and narrow tires issue solved.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 09-03-2011, 07:10 PM   #1011
VA72C10
VA72C10
VA72C10's Avatar
You must have 1" rotors...not 1 1/4" like most have...they don't fit the standard rotors...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline
Old 09-03-2011, 07:19 PM   #1012
Andy4639
Old member
Andy4639's Avatar
I haven't ever measured mine. What do I measure to get this?
Here is a picture of the drivers side.
Andy4639 is offline
Old 09-03-2011, 09:44 PM   #1013
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by Andy4639 View Post
The wheels will fit fine. The tires are what hits. That doesn't mean the wheel company is at fault because we pick tires bigger than what we should! If you don't want the tires to scrub buy orignal wheels and narrow tires issue solved.
The earlier versions of the these wheels WILL NOT work the 1.250" wide rotor without modifying the nose of the rotor. The center cap still wouldn't fit on some even after making the wheels fit. They do fit the light duty 1" wide rotor/spindle combination. Also the backspacing is an issue on the rear.
mcbassin is offline
Old 09-03-2011, 09:52 PM   #1014
mcbassin
Still Learning
mcbassin's Avatar
Measure the thickness across the diameter.
mcbassin is offline
Old 09-03-2011, 10:16 PM   #1015
Andy4639
Old member
Andy4639's Avatar
Wink Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
OK,
thanks.
I had to put a 1/4" spacer on the back but that was because of the tire I chose not the wheel it self. I like the wheels. In the picture you can see where the hub was grinded just enough to fit.
Andy4639 is offline
Old 09-15-2011, 02:27 AM   #1016
funkytechmonkey
funkytechmonkey's Avatar
Holy 41 pages.... my eyes hurt. Glad I found this one. Good info here
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline
Old 09-15-2011, 11:48 AM   #1017
lolife99
67-72 parts collector,…
lolife99's Avatar
Don't you mean 51 pages?
Ha.
The fact is,... these wheels were designed for the 88-98 Chevy/GMC trucks.
We as consumers tried to make them fit on our 60-87 designed suspensions/trucks.
Boss Wheels was so close to hitting a "home run",... and they didn't even know it.
At least Coys Wheels added a few more backspacing choices to their wheels.
It's a shame an AMERICAN made wheel company (like AE/Boss) can't listen to the consumer.
Keith
Convert to disc brakes.
lolife99 is offline
Old 09-15-2011, 11:51 AM   #1018
brossow
Amateur Rust Fighter
brossow's Avatar
Ha.
41 pages in my view. Probably depends on how many posts per page you have set in your preferences.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 09-15-2011, 12:46 PM   #1019
Ackattack
Ackattack's Avatar
I got a set too, 20x8.5s all around with 255/45/20. I ground the front rotor nose and used 1" spacers in the back. I may not have needed the spacers in the back, but with the narrower track width of the rear compared to the front, it looks better with the spacers anyways.
Ackattack is offline
Old 09-15-2011, 01:08 PM   #1020
lolife99
lolife99's Avatar
I think you are correct!
Keith
lolife99 is offline
Old 09-15-2011, 02:40 PM   #1021
funkytechmonkey
For those of you looking for these wheels. Here is a pretty good deal from an ebay store (NOT MINE)
Boss Motorsports Wheele
Style 338, 20x8.5 front + 20x10 rear
5x5" CHEVY C10
$793.62 with FREE SHIPPING.
Here is the link.
Thats not bad for a bad price for a staggerd set.
Old 09-15-2011, 02:51 PM   #1022
funkytechmonkey
BTW... Are these the new ones or old ones? 3AA... Do you still have the machine the 1.25" rotors for these?
Boss Motorsports Wheels (made by American Eagle)
Style 338
Finish: Gray spokes with polished lip
Bolt Pattern: 5-lug, 5 x 5" (5x127mm)
Front: 20" x 8.5"
Offset: +14mm, Backspace: 5.25"
AEWC part# 3387-2850-3AA
Rear: 20" x 10"
Offset: +0mm, Backspace: 5.5"
AEWC part# 3387-2085-3AA
Old 09-15-2011, 02:54 PM   #1023
brossow
brossow's Avatar
3AA = latest revision ... that still doesn't fit right, so yes, you still have to machine the HD rotors.
Brent
brossow is offline
Old 09-15-2011, 02:59 PM   #1024
lolife99
lolife99's Avatar
Style 338
Front: 20" x 8.5"
Rear: 20" x 10"
I wonder if that rear offset is correct?
The only available backspace on their website for 20x10's is 6.225" (5x5 bolt pattern) and 6.698" (5x120mm bolt pattern).
http://www.bossmotorsports.com/wheel...ecs.cfm?id=408
Keith
lolife99 is offline
Old 09-15-2011, 03:34 PM   #1025
brossow
brossow's Avatar
Rear: 20" x 10"
After further consideration, something's weird with the part number on the second. The PN for 20x10 338s in grey has always been 3387-2050-3-AA and the offset is +20mm. Maybe they've come out with a new revision?? With zero offset, that would move the wheel outward roughly 3/4" and make them fit about perfectly. If that's the case, then all they need to do is fix the hub bore issue up front and these could be near-perfect bolt-ons for our older trucks.
Brent
brossow is offline
Closed Thread
