Old 02-26-2012, 11:00 PM   #1001
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 85 burb meets 6.0 lq4
1000? Looks like over 1600 to me?
and like WOW.....even I can weld better then that!
headers look great. looks like you had to come in from the top?
how do they fit underneath?
buy like a flowmaster universal kit in galvanized steel. or s.s., your choice. BTW...this has an "H" pipe which is good, or even better find a x-pipe version if you have the room. X -pipe cured a torque loss in my C3 after putting 2.5" true duals on it. even sounded better.
Put it together with either cheap clamps and take it to get welded later...or do it permanently with band clamps. All you need is a saw/cut off and a file or something to clean things up to slide together easier. Just choose the mufflers you'd like to run. For me, I prefer a turbo muffler type (Magnaflow vs a chambered (Flowmaster) muffler. I'd go at least 2.5" pipe for duals....or 3" if you've got the room and like a deeper tone. How far back do you plan to go, all the way out below the rear bumper? Or out the sides behind the rear tires?
Flowmaster/815937
I bought the galv. then found the s.s was only a few bucks more.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-27-2012, 12:17 AM   #1002
85burb
85burb's Avatar
The 1000 posts was on this thread. Yes they both dropped in from the top. They fit very well underneth. The would clear trans ear if i had not already halked it off to fit f-body headers. Clears trans link great. Passenger side is real close to the schakel but looks like it will clear. With old 350 my headers hit the schakels. I am not gona try a do it my self kit. It will come out bad. I just know it. Hope i can make it to the exhaust shop to get them connected with out a ticket due to blowing the hole test fit thing.....
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-27-2012, 12:37 AM   #1003
MTCK
MTCK's Avatar
How far can do you have to go? Can you make your EFI run open loop since your O2 sensor isn't installed? I can check a box with my holley system and it will just use the fuel map and not adjust for actual O2 in exhaust... If not you might have a heck of a time keeping it running if it pours the fuel to it once it warms up and tries to go into closed loop operation.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-27-2012, 12:45 AM   #1004
85burb
85burb's Avatar
They are installed but are so close to the collector they read way lean. I hope with the reducer or what ever it is called on they will read. It idled great. Sound wicked. About 12 miles or if i park it tell i have money to do the real exhast way way to far. Like 45 mins atleast. Will for sure get pulled over..
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-04-2012, 10:28 PM   #1005
85burb
85burb's Avatar
Installed collecters and o2 sensors read now some atleast. It is running way way way rich. It pounds the cheast pretty good too. One of my favorite feelings.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-04-2012, 10:48 PM   #1006
mooseknuckles
mooseknuckles's Avatar
sounds cool man!...congrats.
mooseknuckles is offline   Reply With Quote
Old 03-05-2012, 12:45 AM   #1007
85burb
85burb's Avatar
Thanks. Just watch the video and have someone slap you chest repetadly to get the full effect.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-17-2012, 12:28 AM   #1008
68 TT
Still plays with trucks
68 TT's Avatar
Sounds nice.
Reminds me of when I ran my Camaro open headers after first getting it put together. It knocked things off the wall in the neighbors place and the tools on the floor boards were bouncing 2" off the floor. Amazing sound but tough to hear anything else around you. I drove it that way to the muffler shop. You should have seen the look on peoples faces.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-01-2012, 06:44 PM   #1009
85burb
85burb's Avatar
Well not a big update but something. I wired in my duel fans properly insted of getto style. 1 fues and 1 relay per fan. Took forever cause i had to do everything. Had to crimp connecters to wire and install them in fues holder and cut all wires to length. I did not get a kit. I just ordered all the termanals i need and made it all brand new. I hope i get my exhaust done soon. My dad will be here the 28th and would like to have it ready for him. He had one when i way younger.. Then my brother had one now i have one. (mine is the coolest one i am sure) Last week the guy told me 2 weeks so next week end i hope he will come get it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2012, 11:37 PM   #1010
85burb
85burb's Avatar
Talked with the guy that is going to do my exhaust work and he says he will be ready middle of this week or early next week. I cant wait. It has been too long.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-06-2012, 02:36 PM   #1011
85burb
85burb's Avatar
Well middle of week and first thing last week came and went. Got a hold of him and the cuda he is finishing for the last 6 years has been kicking his butt and he is really consentrated on it so the guy can pay him. But he picked it up today and said it will be done this week. I cant wait. His dodge is gona get a work out today for sure.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-06-2012, 02:39 PM   #1012
85burb
85burb's Avatar
Tryed my hand at some welding today at my brothers house. It is the first time i have ever tryed it. My dad also tryed. My weld is the last 3/4 of the weld. Tryed to weld with the thing standing up at the last part that is why it looks so bad. Then my brother turned the wire speed all the way up and really screwed it up for me. Kinda fun i guess. We did ruin some nice bumper brackets tho....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-06-2012, 02:40 PM   #1013
68GMCCustom
well thats cool he comes and gets it.
Kurt -
Old 05-06-2012, 02:42 PM   #1014
85burb
85burb's Avatar
Yes it is about a 30 min drive to his shop and i didnt want to get ticket so he came and got it. I have heard his exhaust work is amazing so i am really hoping to see it soon. He is the same guy that did both my axles. Builds drag cars for a living. Wish i could work with him.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-16-2012, 03:21 PM   #1015
85burb
85burb's Avatar
Well finally got the call to come pick the old burb up. So after I get off work I will be get him. Can't wait
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-16-2012, 10:05 PM   #1016
85burb
85burb's Avatar
Well finally drove buddy with headers and new exhasut. It sounds amazing. The video is just a crap one for now. It does not have a h or x yet. The shop that did it did not have the parts to do it correct we a gread to put it in later on. But it sounds exactly how i want it to. I will be adding a h pipe tho. Sorry about the fuel pump noise. Will get better video this weekend. His work is amazing. It is beautiful. He was doing a duel 3.5 inch with x pipe in a new charger when i was there and he was finishing the x and it is amazing. VERRY happy with how it turned out.
http://www.youtube.com/watch?v=Kqs4O...ature=youtu.be
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-16-2012, 10:24 PM   #1017
Cherub
Cherub's Avatar
man im drooling over here....are those vband connectors i see ....
Cherub is offline   Reply With Quote
Old 05-16-2012, 10:48 PM   #1018
85burb
85burb's Avatar
They sure are. If I only has as much talent in my hole body as he has in one finger I would be happy.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-16-2012, 10:56 PM   #1019
68GMCCustom
that does look pretty darn good. I like that welders shield too...
Kurt -
Old 05-17-2012, 10:20 PM   #1020
85burb
85burb's Avatar
Here are a few pics and longer crappy video. Kid crying is my little girl she swan dived out of it smooth on to her face. She is ok tho. Sorry about the video quality. I will keep my day job.......
http://www.youtube.com/watch?v=Pd-bW...ature=youtu.be
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-18-2012, 12:17 AM   #1021
85burb
85burb's Avatar
Well i just had to go to my work and let a trucker swap trailers so i snaped a few pics. Also on the way home i flowtested my exhaust pretty good. Some punk kid and his lifted trash can sized exhaust dodge thought he would pick on poor old sububan. Well this night he picked the wronge one. In my town we have a section of two stop lights that are really close to gether. The first one he put his pipe close to my window and made it really loud. Second light we came to a stop and i knew he was gona try something. So i shifted my trans to 3rd so it shiftes firmer and the light turns green and i pace him untell i know he is trying to race me and i hammer down on mine. His is already at full boost so he is maybe half truck length ahead and by the time i am half way threw 2nd i am half lenght ahead of him. I stay in it tell i am sure he knows he lost wich was about 75-80 mph. I am about 1.5 lenghs ahead at this time. I am sure he was very surprised he just got spanked buy a old burb. If i would have punched it off the line i bet he would have neve even got any ahead and i would have had 2+ lenghts on him. I was very very surprised at the outcome. That makes buddy 2-0 on his race record i think.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-18-2012, 02:06 AM   #1022
MTCK
MTCK's Avatar
Exhaust looks and sounds great! Those bends are super smooth, looks like no crimping at all.
-Marcus
Project Plow Truck
Old 05-18-2012, 07:21 AM   #1023
Cherub
Cherub's Avatar
lookin real good, im diggin the stance.
Old 05-18-2012, 08:48 AM   #1024
85burb
85burb's Avatar
Thanks. They are mandrel bends. Supposed to not be crushed at all.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-26-2012, 10:48 PM   #1025
85burb
85burb's Avatar
Took the ole burb out for it first cruse in many months. Ran great. I adjusted my accel fuel setting to +2 and it seems to like it. My little girl is finally ok with riding in it agian after a few tears. She used to love it. Then she hated it now she likes it again thank goodness.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
