Old 03-10-2016, 02:51 PM   #1001
99 to Life
99 to Life's Avatar
Re: 1949 Chevy 3600 into a daily driver
that may work too, just have to make sure the Aarm isn't going to hit it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-10-2016, 03:00 PM   #1002
Elder Rogue
Elder Rogue's Avatar
Originally Posted by 99 to Life View Post
I'd opt for some speedway tubular uppers ($100 can beat that),
I was looking at the speedway uppers until I read this on the speedway site;these a arms are a steel on steel pivot and you will notice that they are somewhat noisy and transfer a lot of vibration into the car as compared to a typical street tubular control arm. Also due to the fact that they are steel on steel they will wear out and need to be replaced fairly frequently.
Since I want a daily driver when finished, I am reconsidering these as a choice.
Just my 0.02 worth.
Elder Rogue is offline   Reply With Quote
Old 03-10-2016, 08:52 PM   #1003
99 to Life
99 to Life's Avatar
I have about 1k miles on mine and smooth as can be. You should grease them every few thousand miles. tons of s10 guys run them. They are a needle bearing design, nothing different from a wheel bearing really. If you have the money to spend 3-4's time as much right off the gate, I'd say yah go that route, get some poly bushed uppers.
Old 03-11-2016, 01:01 AM   #1004
Coach529
Coach529's Avatar
Super busy day.
We now have a roller. Such a great feeling.
My Knuckles showed up from IRS Machining today. They look great!! That allowed me to assemble the rear suspension.
I am about 1/2" to 3/4" higher in the rear than during mockup, which I found out to be the difference in the stock T-bird wheels and my Cragars and WW. Looks like I could easily take 3/4" out of my lower cups to get lower. Now sure if I will or not. The only part that really bothers me is the running boards are not parallel with the ground at air out. Kind of a pet peeve of mine. The back either needs to come down, or I need a bumpstop to raise the front 1/2" at air out.
The front is all loose mocked up. Just enough to roll.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-11-2016, 01:34 AM   #1005
lower50's
lower50's's Avatar
Nice, such a good feeling to get it rolling. I agree with the running board almost level aired out, never looks intentional.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-11-2016, 11:08 AM   #1006
reaper71
reaper71's Avatar
Just went through your build, very cool.
Mark...
reaper71 is offline   Reply With Quote
Old 03-11-2016, 12:05 PM   #1007
Elder Rogue
Looking Good!
Old 03-11-2016, 12:13 PM   #1008
mikec4193
mikec4193's Avatar
Oh my gosh....you are doing a great job on this truck...
Congrats on getting it rolling...
MikeC
mikec4193 is offline   Reply With Quote
Old 03-11-2016, 03:02 PM   #1009
Coach529
Coach529's Avatar
Thanks guys!!
Pulled him out of the garage and am cleaning the shop now.........
1949 Chevy 3600
Old 03-11-2016, 11:33 PM   #1010
youngrodder
youngrodder's Avatar
Looking good.....Its always nice to get it back to roller status.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-12-2016, 01:24 AM   #1011
Coach529
Coach529's Avatar
Happy to get him rolled out of the garage and get it all cleaned up.
I spun spun him around and put the 350/350 combo in to the rack and pinion mocked up.
1949 Chevy 3600
Old 03-14-2016, 11:41 AM   #1012
Coach529
Coach529's Avatar
Still plugging away on this install.
Threw the motor in to mock up the rack and pinion set up.
The mounting on this rack was offset to the drivers side which makes mounting a bit more troublesome. I picked up some 4" x 4" x 3/16" tubing to make some mounts out of.
Scott suggests a 3" notch to clear the rack. This WILL NOT work with a Ford rack. I had to open up my notch to almost 6" to clear the Ford rack. Frustrating to cut apart something that was finished.
I had to remove some material on the passenger side of the crossmember to clear the rack. I got a little overzealous with the skinny wheel and sawzall.
mock up
Making brackets
Tacked in
Fit test. I did end up opening up the notch after this.
Both side welded in and the relief boxed in. I just need to rebox the bottom of the notch!!
1949 Chevy 3600
Old 03-14-2016, 12:15 PM   #1013
99 to Life
99 to Life's Avatar
great job, I feel yah on cutting up finished stuff. but that's the name of the game. you handled it well.
Old 03-14-2016, 05:00 PM   #1014
Coach529
Coach529's Avatar
Thanks!!
1949 Chevy 3600
Old 04-03-2016, 09:49 AM   #1015
Coach529
Coach529's Avatar
Still pluggin away. Motor is now buttoned up. New set of reworked 601 heads installed.
I threw a fresh coat of Chevy Orange on the motor and tossed it back in the chassis. First thing on the agenda is steering.
1949 Chevy 3600
Old 04-03-2016, 01:48 PM   #1016
99 to Life
99 to Life's Avatar
coming along. steering is always a treat on these.
Old 04-03-2016, 07:46 PM   #1017
Advanced Design
Advanced Design's Avatar
Saw on FB you sorted it out. Nice job.
Advanced Design is offline   Reply With Quote
Old 04-03-2016, 11:30 PM   #1018
youngrodder
Nice work....Getting closer to hitting the road.
Marc
Old 04-04-2016, 01:12 AM   #1019
joedoh
joedoh's Avatar
what a great look your truck has!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 04-04-2016, 10:06 AM   #1020
Coach529
Coach529's Avatar
Busy weekend with family and kid obligations, but I did manage a couple hours in the garage.
I was pretty nervous about the steering set up before I even started. The input shaft of the rack was aimed right at my drivers side motor mount.
The headers I am running gave me a couple good sized openings to get through.
When it was all said and done it was not as big of a deal as I had dreaded in the first place. I modified the motor mount a bit so the bolt hole was closer to the block. This required extending the mount a couple inches and cutting the biscuit. Once I did this it allowed the clearance I needed.
I mocked it up with a piece of dowl rod and it works great. Now I am going to pull the motor and weld up the modified motor mount and paint the area. Once that is done hopefully the motor will go in to stay.
New parts are arriving daily.
New rear calipers for the Ford 8.8.
CPP Firewall mounted Brake Booster.
1949 Chevy 3600
Old 04-04-2016, 10:08 AM   #1021
Coach529
Coach529's Avatar
Thanks..........
1949 Chevy 3600
Old 04-04-2016, 10:09 AM   #1022
Coach529
Coach529's Avatar
Marc
I had a goal of driver by Memorial Day weekend, but I am not sure how realistic that is.
Plugging away as time allows.
1949 Chevy 3600
Old 04-04-2016, 10:14 AM   #1023
Coach529
Coach529's Avatar
Thanks, I sure do love it!!
1949 Chevy 3600
Old 04-04-2016, 05:02 PM   #1024
Coach529
Coach529's Avatar
Below is a great thread on the HAMB about grinding your stock steering shaft to a DD.
http://www.jalopyjournal.com/forum/t...-tools.798515/
1949 Chevy 3600
Old 04-04-2016, 06:42 PM   #1025
lower50's
lower50's's Avatar
The pic from the front with it aired out looks so good. Steering check, nice new brake parts check.
1951 MG TD
