Old 03-31-2017, 08:34 PM   #1001
rustytruck50
rustytruck50's Avatar
Re: 85 GMC Sierra "Scarlett"
Whoa, that's pretty slick....like your fabrication job on the plate & mounting!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 04-01-2017, 07:52 AM   #1002
N2TRUX
Happy to be here
N2TRUX's Avatar
Last night I made some adjustments to the outer pair of @kickeraudio 3.5" #coaxial speakers. Based on you guys input I felt they were positioned to high in the mount. I repositioned them below the mount to allow more airspace. I will verify clearance when I reinstall the dash pad.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
"Refining Sierra"
Old 04-01-2017, 07:59 AM   #1003
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks. I made the plate to fit an older bezel I used for mock up. I "assumed" the new bezel would be identical. After fine tuning the fit I discovered there were some minute variances. Most won't notice, but it bugs me. I'm going to adjust the final fit before I attach it to the new bezel. Hopefully I won't have to make a new one.
Articles-
"Refining Sierra"
Old 04-01-2017, 02:25 PM   #1004
rustytruck50
I totally understand that....the Pro Streeted stepside I told you about previously had some graphics and colors put on that I never thought looked right, guy wouldn't go back and change it, yet, alot of people told me how good it looked, which I appreciated, but it was something akin to a giant overbite on a swimsuit model...kinda turned me off whenever I saw it!
-Doug
'05 RCSB Sierra 2WD
Old 04-01-2017, 07:11 PM   #1005
LT7A
I'm not sure how much weight it saves over cast iron, but I do like that it has mid rise runners. I feel it gives a bit more low end pull.
The good Qjet manifolds seem to be known for their low end torque. Not designed for high RPM use. But neither were the trucks originally.
Wait to you see how I am mounting the KMC20 controller. I was able to come up with a method that doesn't require cutting the dash or the stock bezel.
Well integrated is the approach I like. It doesn't always have to mean cut in, flush. But done purposefully and with good craftsmanship, pretty much any mod can look sharp. Even if it shows some seams and fasteners. The Kicker assemblage is coming together nicely. Good that the bass gain can go all the way to eleven.
Old 04-01-2017, 10:44 PM   #1006
rideair
N2TRUX,
The original dash speakers had a fabric covering over them to help keep dirt/dust/crap out of them, are you planning to do the same and if so, how?
Getting ready to install mine, I've bought the fabric, just got to figure out the best glue to use to hold it in place.
Enjoy,
RIDEAIR
rideair is offline   Reply With Quote
Old 04-02-2017, 08:25 AM   #1007
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by rideair View Post
N2TRUX,
Enjoy,
RIDEAIR
The way the speaker is designed it would be difficult to do. I don't plan to utilize a dust cover on the speaker. If anything I may add something to the bottom of the dash pad.
Articles-
"Refining Sierra"
Old 04-03-2017, 11:33 AM   #1008
N2TRUX
Happy to be here
N2TRUX's Avatar
Crazy busy weekend, with not much to report on Scarlett. I spent a lot of time Saturday prepping and planting beds in front of my house. After lunch I pulled the Raceline Static5 off of my 77 Cheyenne and put the Coys on for rollers. The Racelines will get a thorough polish and then put on the market. Sunday we hosted a birthday party for my niece.
After spending time with family, Chris and I got to work in the shop. He mapped out wire routing and laid it in place. With a display, speakers in the dash, a data port in the glovebox, a processor under the seat, and a powered sub and 6x9s behind the seat, routing all the wires is a complicated process. The channels along the door sills are shallow and do not accommodate enough wires so we had to run them along the edge of the various humps in the floor. We used duct tape to cover the wires and keep them flat and in place.
While Chris worked on wiring I focused on the control panel I had mounted inside the glovebox. I had previously mounted the bass gain control in a panel and decided to ad a USB charging and data port. This turned in to a much bigger challenge than anticipated.
After locating the smallest combo port I could find, I still encountered issues getting it to fit properly. Once that hurdle was overcome, the port stuck out to much to allow the door to close. It took a lot of trial and errors attempts, but I finally managed to get everything to align and the door to close correctly.
Now I have to determine why the door latch wants to rotate.
Articles-
"Refining Sierra"
Old 04-03-2017, 11:42 AM   #1009
TKCR
TKCR's Avatar
Yep, that will help with the clearance. Exactly what I did.
Old 04-03-2017, 12:10 PM   #1010
UKNOWME
UKNOWME's Avatar
In all the posts I've seen of your 77 I don't believe I've ever seen raceline wheels on. Do you have a pic to post? What side are the racelines and do you have an asking price in mind?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 04-03-2017, 12:30 PM   #1011
ztk123
I also looked back through the 77 Cheyenne thread and didn't see any racelines. Curious about size, price and what you're upgrading to?
Mike
ztk123 is offline   Reply With Quote
Old 04-03-2017, 01:14 PM   #1012
N2TRUX
Happy to be here
N2TRUX's Avatar
I think its going to be adequate, but I will double check when I put the pad on.
Articles-
"Refining Sierra"
Old 04-03-2017, 01:18 PM   #1013
N2TRUX
Happy to be here
N2TRUX's Avatar
Mike
I didnt mean to throw a teaser out there, so heres the scoop.
The Raceline wheels I have are 22" Static 5 that came off of the 84 Sierra that I sold last year. The man that bought the truck wanted my 20" VinTecs rather than 22s. They are in new condition. The titties are gone but the bumpies are still showing on the tires. No curb rash or damage of any kind. I will be asking 3800.00 for them. I prefer local pick up.
Articles-
"Refining Sierra"
Old 04-03-2017, 04:44 PM   #1014
54inches
Just spent 3 hours reading from beginning to end. Very Nice!
How well is your HF blasting reclaimer holding up?
I am running a Quincy Compressor over to a good sized TpTools blast cabinet that can do Soda as well and then a 10 gallon Craftsman Vac, but I like this reclaimer, just read quite a few bad reviews........
2005 CTSV T3 61/65 Precisions on Meth., DV8S Shifter, Strut Tower Brace, 8.8 brackets; 179 mph @ Texas Mile. 11.4 @ 127
2007 Tahoe LTZ
2003 Ford Ranger DD
54inches is offline   Reply With Quote
Old 04-04-2017, 12:06 PM   #1015
N2TRUX
Happy to be here
N2TRUX's Avatar
How well is your HF blasting reclaimer holding up? I am running a Quincy Compressor over to a good sized TpTools blast cabinet that can do Soda as well and then a 10 gallon Craftsman Vac, but I like this reclaimer, just read quite a few bad reviews........
Thank you so much for following along.
The HF re-claimer is a beast. Its honestly too much for the cabinet with out a vent. We sealed every seam with a bead of silicon and the vacuum sucks the sides in to a point they broke the seal on the silicone in places. I plan to add an adjustable vent to relieve some pressure.
Articles-
"Refining Sierra"
Old 04-04-2017, 07:47 PM   #1016
bbbc10
Diggin The SquareLife
great work!!! hmmm ima keep the racelines in mind!
bbbc10 is offline   Reply With Quote
Old 04-05-2017, 08:50 AM   #1017
N2TRUX
Happy to be here
N2TRUX's Avatar
Already sold. Didn't get a chance to advertise and a guy jumped on them .
Articles-
"Refining Sierra"
Old 04-05-2017, 09:37 AM   #1018
UKNOWME
UKNOWME's Avatar
Well dangit! I'll quit rolling my pennies now
1964 Chevy c10
Old 04-05-2017, 11:44 AM   #1019
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah I had several messages right away and hadnt even set a price. The first guy that asked my price said "Sold!" so it was a done deal before I knew it.
Articles-
"Refining Sierra"
Old 04-05-2017, 11:55 AM   #1020
UKNOWME
UKNOWME's Avatar
Do you have any pictures of them on the 77? The white truck just sits too high to get an idea how they looked tucking the fenders
1964 Chevy c10
Old 04-05-2017, 09:16 PM   #1021
N2TRUX
Happy to be here
N2TRUX's Avatar
Unfortunately I do not. I took some but some how they got deleted when I got a new phone.
Articles-
"Refining Sierra"
Old 04-06-2017, 11:30 AM   #1022
N2TRUX
Happy to be here
N2TRUX's Avatar
I found one pic. Take a look here.. LINK
Articles-
"Refining Sierra"
Old 04-06-2017, 11:43 AM   #1023
UKNOWME
UKNOWME's Avatar
Thank you very much!
1964 Chevy c10
Old 04-07-2017, 07:37 AM   #1024
N2TRUX
Happy to be here
N2TRUX's Avatar
We are at our peak season at work, which means start early and finish late. I hate to start a job I can't finish so I'm not touching the dash or wiring till Chris and I have adequate time to wrap it up. While waiting for an opportunity to finish the dash install, I started on design and mock up of the box behind the seat.
This box will house two Kicker Audio 6x9 #coaxial enclosures, a compartment for the Kicker Hideaway powered sub, and some storage.
I started on the design phase to determine location and angle of the 6x9 enclosure. I want the speaker to be exposed as much as possible for appearance as well as sound clarity. I was able to accomplish my goal with cardboard. These pieces will be used as a template to mark my MDF for cutting.
Articles-
"Refining Sierra"
Old 04-08-2017, 07:32 AM   #1025
N2TRUX
Happy to be here
N2TRUX's Avatar
Friday night I spent some time on the @kickeraudio Hideaway portion of the rear enclosure. I designed an area where we will mount the powered sub and route the wiring.
I dialed in the height, depth, and angle by stacking blocks till it was where I wanted. With the sub location determined I can work on mounting pads to hold it in place.
Once secure I can create a cover that will hide the wiring and expose the face of the Hideaway.
Articles-
"Refining Sierra"
