Old 06-29-2020, 11:10 AM   #1001
layinrocker65
layinrocker65's Avatar
Re: A '54 named Busty
Yes you need a regulator, the PCM will not control your fuel pressure. Late model vehicles with FPCM will control fuel pressure using PWM but you don’t have that. Best way for you to go is using a corvette fuel filter regulator. It has 2 fittings on one side that go to the sending unit(3/8 feed, 5/16 return) and one fitting on the other side that goes to the rail. It regulates the pressure to 58psi. Which is standard LS pressure.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 06-29-2020, 11:13 AM   #1002
layinrocker65
This is the setup. I suggest getting a WIX or ACDelco one of you go that route. It can be mounted to the frame near your tank so you still only have one line running to your engine from the regulator.
https://www.speedwaymotors.com/Speed...PSI,41791.html
‘53 GMC COE stock
Old 06-29-2020, 11:15 AM   #1003
Gregski
Post Whore
Gregski's Avatar
thanks, I researched the Corvette one like a year ago when I first got the engine, but honestly been so distracted with other projects and forgot all of my research, thank you all for your help, Speedway makes this nice unit that integrated -6AN fittings on to it so no need for adapters, I ordered one today off of Amazon, but I still can't find what the stock one looks like on our trucks for 2004 5.3L
Gregski is offline   Reply With Quote
Old 06-29-2020, 11:28 AM   #1004
Wide Open
Originally Posted by texxxan View Post
I'm certainly no one qualified to give advice here, but I believe you need the Corvette regulator ( 2 lines in and one line out) for this set up. Someone qualified please verify this because I will be doing this set up very soon.
It might be the easiest option. I’ve used it on a couple of different swaps and it worked fine.
Since The Greg is running a nonOEM pump and housing I’m not sure how easy it will be to use the 04+ setup.
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 06-29-2020, 11:29 AM   #1005
Wide Open
Well I guess I need to refresh before I post when I get distracted. That looks like an even better option than the stupid little plastic clips that holds it together stock.
1972 K10
2002 Z06
2007 Escalade
Old 06-29-2020, 11:32 AM   #1006
Wide Open
I believe it’s all in the pump housing.
1972 K10
2002 Z06
2007 Escalade
Old 06-29-2020, 11:46 AM   #1007
Gregski
Post Whore
Gregski's Avatar
thank you, thank you, thank you, it was driving me crazy trying to find the darn thing, I thought it was mounted on the firewall similar to the air pump, and since I did not own the donor vehicle I couldn't just go and hunt for it
soooooooooooooo appreciate it!!!!
Old 06-29-2020, 11:48 AM   #1008
Gregski
Post Whore
Gregski's Avatar
yeah they are called quick connect for a reason (not quick disconnect, LOL) the factory is all about making it easier and faster to crank out these trucks ie build them for their less and less skilled workers, I hate all of the GM fittings and connectors they are insanely difficult to disconnect and reuse without damage, some electronic plugs you seriously need a third arm to get off, that or maybe I'm just a moron?! ha ha
Old 06-29-2020, 11:50 AM   #1009
Gregski
Post Whore
Gregski's Avatar
so while we wait on the little fuel pressure regulator (pronounced: "expensive") to show up might as well fandangle the drive by electricity throttle pedal
Options:
1. shorten the pedal
2. amputate my right leg directly below the knee
Old 06-29-2020, 12:11 PM   #1010
texxxan
texxxan's Avatar
Options:
[/QUOTE]
Hmmmmm. Decisions decisions...
texxxan is offline   Reply With Quote
Old 06-29-2020, 12:41 PM   #1011
Wide Open
Angry Re: A '54 named Busty
Yep I hate them too I had a quick connect quickly disconnect on me once. (Well twice actually). I swapped an L92 into a 00 RCSB that originally had a 5.3. I used the Corvette regulator plugged into the factory fuel lines at the rest of the engine since they were already there and in working order. I connected the single feed line to the L92 returnless fuel rail. Good to go. Until one day driving home the truck stalled and I smelled gas. Popped the hood to find the connector at the file rail had quickly disconnected and sprayed the engine bay with highly flammable liquid. Thankfully no fire. I reconnected it and drove the rest of the way home. I figured I must have not fully snapped it into place on installation. A few weeks later same thing happened but this time I couldn’t keep it connected. It would partially dislodge and leak fuel at the connection so I ended up buying Russell fittings to replace the factory stuff.
1972 K10
2002 Z06
2007 Escalade
Old 06-29-2020, 12:46 PM   #1012
Wide Open
With the covid going on it’s probably quicker and easier to modify the pedal.
Just my two cents.
1972 K10
2002 Z06
2007 Escalade
Old 06-29-2020, 10:15 PM   #1013
Gregski
Post Whore
Gregski's Avatar
Just my two cents.
right you are ... hold my beer!
Old 06-29-2020, 10:18 PM   #1014
Gregski
Post Whore
Gregski's Avatar
... and Robert is your father's brother!
presented with or without the plastic cover I made from a piece of plastic that fell off a Jeep on the side of the road - you're welcome (ha ha) someday I plan to fab something smart out of metal
yes I ended up putting a "speed" hole in the plastic pedal because I'm an idiot and didn't realize you can tilt it forward more (so the metal won't make contact with the plastic) when taking the torch to it to bend it into submission a little bit
Old 06-29-2020, 10:26 PM   #1015
Gregski
Post Whore
Gregski's Avatar
a really lame and flimsy SPECTRA (pronounced: "cheap junk") 45° rubber elbow showed up today so I decided to moch up the cold air intake
we have two options, long and strong or short and stubby?
please let me know which you prefer Option A or Option B
Old 06-29-2020, 10:29 PM   #1016
Gregski
Post Whore
Gregski's Avatar
Option A - Long and Strong nothing Wrong just some air flowing Along...
Old 06-29-2020, 10:33 PM   #1017
Gregski
Post Whore
Gregski's Avatar
Option B - Stubby Bobby
Old 06-29-2020, 10:33 PM   #1018
Gregski
Post Whore
Gregski's Avatar
and here's how either option will be supported at least in this spot
Old 06-30-2020, 07:59 AM   #1019
8man
I like B, it seems to fit better. Of course that is only worth what you paid for it though.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-30-2020, 08:48 AM   #1020
texxxan
texxxan's Avatar
I'm with you, I like B better.
Old 06-30-2020, 09:48 AM   #1021
Gregski
Post Whore
Gregski's Avatar
yup guys I like B better as well though that Spectra 45 elbow is junk, may get a new one thats also a 4" to 3.5" reducer
Old 06-30-2020, 09:59 PM   #1022
Wide Open
Dude you seriously did not need to share. I would have been perfectly fine if you would have kept this all for yourself.
1972 K10
2002 Z06
2007 Escalade
Old 06-30-2020, 10:57 PM   #1023
Gregski
Post Whore
Gregski's Avatar
ha, if you can't share with your friends who can you share with?
Old 07-01-2020, 09:40 AM   #1024
Gregski
Post Whore
Gregski's Avatar
Me: "so babe, are we gonna have fun camping this weekend?"
Wife: "I donno, is Busty gonna be fine without you for a couple of days?"
Old 07-01-2020, 10:40 AM   #1025
texxxan
texxxan's Avatar
I'm not a smart man, but I'm pretty sure that was a rhetorical question.
