07-17-2014, 04:48 PM | #1026 |
Re: What did you do to your truck today part II.
PorterBuilt front x member back from powdercoat. Candy Blue Metallic.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
07-17-2014, 04:51 PM | #1027 |
I hear you there. Was in the same boat over the 4th of July holiday. Milestone tonight as we get the engine and trans set in.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-17-2014, 04:52 PM | #1028 |
Nice.....will be a great addition to your truck.
07-17-2014, 04:52 PM | #1029 |
07-17-2014, 09:31 PM | #1030 |
trying to figure out why rear tire is rubbing front edge of bed on drivers side, im pretty sure rear gets pushed to right when lowered, discovered trailing arm bent upwards.
07-17-2014, 09:47 PM | #1031 |
I found out the lower you go the farther the axle arcs forward. Now I got PorterBuilt trailing arms to correct that.
07-17-2014, 10:35 PM | #1032 |
07-18-2014, 09:02 AM | #1033 |
I am getting ready to install a HEI distributor so I swapped out my OEM alternator and regulator for a 63amp 10SI internally regulated alternator (AC Delco 3342114). I chose the 10SI because it looks almost identical to the OEM unit. I considered swapping the pulley and fan from the original alternator to the new one but didn't to avoid damage. I had to machine the bottom mount on the case of the new alternator to make the pulleys line up as well as re-bend the upper bracket. This is well documented by Sharps40 in the John Lee Alternator thread.
One surprise in the process is that I was able to re-use the original wiring harness wrap tape after removing the unused wires related to the external regulator. I am very happy that the wiring looks harness looks untouched after a couple of re-wraps to get things right. ...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
07-18-2014, 09:15 AM | #1034 |
Finally got the big block and trans set in last night. More pics on the build thread.
07-18-2014, 11:18 AM | #1035 |
Picked up a factory stereo for free the other night. Dunno if it works but I plan on sending it in for a conversion to new tech in the future.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie. |
07-18-2014, 11:41 AM | #1036 |
Have you used new tech before? I have an oem radio for my 63 that I'd like to have converted. Just wondering about cost.
07-18-2014, 12:07 PM | #1037 |
Nah but I've heard of it. There was slated thread on it. I'll look for it on my lunch break.
07-19-2014, 08:23 PM | #1038 |
Today was the busiest day that I have had. Installed a 2.5 drop and disk brakes on the front, lowered the back about 2-3 inches and installed new water pump and brake lights. Will try to upload the pics tomorrow.
07-19-2014, 11:52 PM | #1039 |
Post Whore
Took the head off one of my 292's to take to the machine shop. Gonna be taking it in late this coming week!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-20-2014, 12:06 AM | #1040 |
How's that engines top end looking?
07-20-2014, 08:34 PM | #1041 |
Shot the last two coats of paint on the interior of the '65 C10 project this morning, and unwrapped the cab this afternoon. After all the time and effort, it sure is nice seeing the ideas become reality. It will get a repro black firewall insulation pad and a black vinyl full floor covering.
Closeup of the "hammered" silver finish overlooking the satin black. |
07-20-2014, 08:56 PM | #1042 |
My son Ray and I framed out the sills then pulled the bed to set it up on stands so we could install the bed wood, tubs, etc.
Figured out some filler panels for the wheel tubs since we raised the floor 3" we had a gap to close with the bed sides. The chunk of scrap wood is a piece of the old yellow pine we started with to make these boards. rg & ray~ ray |
07-20-2014, 09:38 PM | #1043 |
Looks good robber grin. How did you attach the end piece?
07-20-2014, 09:38 PM | #1044 |
Drove down to San Jose (about 50 miles one way) and picked up my sons bedroom furniture.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
07-21-2014, 03:39 AM | #1045 |
Thanks derail!
I made up a frame using angle iron that takes up the difference in height since the rear sill stayed put when the floor came up 3". Gives me solid mounting for the strips, boards, and end piece. rg |
07-21-2014, 08:27 AM | #1046 |
Friday I finally put the first set of new tires on my truck that it's had in more than 20 years! Hankook Optimo (235/75/15) from Wal-Mart--$75 each. I even replaced the spare.
Saturday, I entered it in the Southeastern Truck Nationals show that they've been talking about here, and won this really cool trophy for "best shop truck." Then, on my way home from the show, I lost one of my hubcaps, so the search is on. |
07-21-2014, 09:51 AM | #1047 |
Pass side header on, started driver side.....will need some fab work done on cyl 1
07-21-2014, 09:52 AM | #1048 | |
07-21-2014, 09:57 AM | #1049 |
Senior Enthusiast
Yes, congrats on the win!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
07-21-2014, 10:16 AM | #1050 | |
Thanks! |
