Old 08-11-2012, 12:51 PM   #1051
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by JPalmer81 View Post
You are doing some great work man, that is going to be a beast!
Thanks!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-12-2012, 11:01 AM   #1052
onebadbowtie
onebadbowtie's Avatar
looking good Ryan
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 08-13-2012, 12:08 AM   #1053
Dieselwrencher
Ok, got a lot more done. The engine is getting really close. The turbos are on, ac comp is on, front accessories are on, injection pump is ready to go on, injectors are built and installed, valve train is installed, exhaust is hooked up, starter is installed, dipstick is installed, and I installed a new thermostat. Quite a bit of work done. It's getting closer.
Ryan
Old 08-13-2012, 12:26 AM   #1054
6lcummins
Don't forget the transmission and clutch are in along with part of the coolant bypass.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 08-13-2012, 01:12 AM   #1055
Dieselwrencher
Yep, that was on the previous page. Now I have to figure out where I hid the front wiring harness.
Ryan
Old 08-13-2012, 01:33 AM   #1056
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man that thing is looking good. I am impressed.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 08-13-2012, 01:55 AM   #1057
Dieselwrencher
Thanks man!
Ryan
Old 08-13-2012, 11:07 AM   #1058
watahyahknow
watahyahknow's Avatar
time to clean the shed i recon
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-13-2012, 12:02 PM   #1059
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Man everything looks awesome!
Any plans on getting that piping ceramic coated?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 08-13-2012, 02:50 PM   #1060
Dieselwrencher
Thanks. For now I'm just going to paint the piping with poof can. I want to get the truck mobile and hen maybe spend extra money on pretty'ing up certain parts. I know there will be some things hiding that I'll need to get it going. There always is it seems.
Ryan
Old 08-14-2012, 01:43 PM   #1061
Str8-6-68
Str8-6-68's Avatar
Wow, Nice progress Ryan! The truck should be burning rubber in no time! IMO i would put a set of 191 dv's in the pump while its out and you have the time to work on it. That pump is gonna be bad arse tho. I have a 175hp ppump that i still need to collect parts for before it sees the conversion. what size injector lines are you going with?
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 08-14-2012, 03:03 PM   #1062
6lcummins
It has 0.084" lines on it and for now I put in 0.022" DV's before I take the ones out of my truck for it.
"STOCK"
ASSEMBLY THREAD
Old 08-14-2012, 04:25 PM   #1063
Dieselwrencher
More progress. Got the turbo piping done and painted. I found my weldments and welded a bung in the cold pipe for a boost gauge, and 2 in the hot pipe at the engine. One for a boost reference to the AFC housing, and the other for a boost gauge. Nick got the injection pump put on, he timed it to 26* I believe, vac/ps pump is on, and I got the oil feed line for the ip and vac pump on. I got the intake plate put on with a new gasket, and cleaned and painted the grid heater. I ended up swapping my ps pump for one we had laying around that is for hydraboost so I didn't have to monkey with a T in the return line for both of them. Next thing to do is paint my heater housing, and get a throttle bracket set up.
Ryan
Old 08-14-2012, 08:56 PM   #1064
mcbassin
Still Learning
mcbassin's Avatar
Way to go Ryan! You are knocking that pipe out. Bout ready to fire it up yet?
mcbassin is offline   Reply With Quote
Old 08-15-2012, 12:43 AM   #1065
Dieselwrencher
Thanks. Hopefully soon. I have to get the wiring sorted out now that I found a front harness.
Ryan
Old 08-20-2012, 01:57 AM   #1066
Dieselwrencher
I've made more progress. I got the clutch hydros installed. Hopefully the clutch engages and disengages like it's supposed to. I won't know until I have it ready to start. I have the fuel shut off solenoid wired, starter wired, coolant temp sensor wired, finished the mount for the hydra boost, got the drive shaft at the drive line shop, Nick got the injection lines on for the last time, and I painted the hydra boost unit. It's getting closer. I also picked up this spare cluster from a friend.
Ryan
Old 08-20-2012, 08:53 AM   #1067
Mattman2010
Mattman2010's Avatar
I can not wait to see this thing in person. It's going to be bad ass!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 08-20-2012, 03:01 PM   #1068
Dieselwrencher
Bring cash. I'm going to have to charge admission to ride in it.
Ryan
Old 08-20-2012, 03:12 PM   #1069
Mattman2010
Your just trying to get more money out of me!
Build Thread
Build Thread
Thread
Old 08-20-2012, 09:23 PM   #1070
Dieselwrencher
No, you take for ever cause you can't ride a quad to save your life. By the way, you need more gaskets sparky.
Ryan
Old 08-20-2012, 11:51 PM   #1071
Mattman2010
Yeah I can, it was just that one incedent haha. Oh great... What now?
Build Thread
Build Thread
Thread
Old 08-22-2012, 02:21 AM   #1072
Dieselwrencher
More progress but I swear 3 steps forward, 2 back! My brother started installing the DIY4X shackle flip, not a bolt on unit. Here it is with no lift blocks, just the shackle flip kit.
I ended up removing 2 1/4" from the shackle bars and got it to this.
It still sits higher in the rear than I want, I might have to bring the front up so it doesn't look like a drag car. I got my spring perches installed and installed some U-bolt retaining plates off of a freightliner truck since I didn't have any for this thing.
Here is the hydra boost mount finished, and the clutch hydros mounted.
I also got my drive shaft back and will check to see how it fits in the morning.
Ryan
Old 08-22-2012, 02:52 AM   #1073
watahyahknow
airpressure on that dash , it must come out of a heavier commercial truck with airbrakes
Old 08-22-2012, 03:02 AM   #1074
Dieselwrencher
Yep, a C60 of some configuration.
Ryan
Old 08-22-2012, 10:09 AM   #1075
obijuan
Scoot the shackle flip forward to make the shackle.full lenght at 45 degrees.
obijuan is offline   Reply With Quote
