Old 07-09-2016, 11:28 PM   #1051
Captainfab
60-66 Nut
Re: My '67 Fleetside C10 renew
Good.....I thought it was just me that couldn't see anything but bubble wrap.
Originally Posted by Vic1947 View Post
All I see is bubble wrap, but what you're describing sounds awesome, John!
Looks good John . Yeah those are some good sized domes. Even with the cam you're running, you'll likely need to mill some off of them like you said, to get your dynamic compression down to a pump gas friendly ratio.
Originally Posted by jlsanborn View Post
Weird...
Old 07-10-2016, 12:32 PM   #1052
jlsanborn
jlsanborn's Avatar
Yep, target has been 11.0:1 static, which I think will be fine with the cam, a tight squish, manual trans and the right gear. We'll see! I ordered a better burette so I can more accurately cc the chambers. I'll also check the advertised -6.3cc piston tops. The trick is going to be figuring out how much to machine off to get to my target. My thought is making an imprint with clay, use the burette to fill the mold with the volume I want gone, then trying to measure the depth of that liquid. Any other ideas? We'll measure all four corners with one piston/rod assembly for an accurate zero deck and then use a standard composition gasket (0.041") for squish.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-10-2016, 01:44 PM   #1053
Vic1947
Vic1947's Avatar
The way I've done it in the past is to:
1. Put together a rod/piston/ring assembly and install it in its bore with a thin coat of grease on the top ring with an extra dab at the ring end gap.
2. Rotate the crank and bring up the piston top to exact TDC with a dial indicator.
3. Bolt on and torque the head with a gasket like what you plan to use. (I usually just torque the five bolts around the cylinder I'm checking.)
4. Rotate the block/head assembly on the engine stand to where the spark plug hole is looking straight up.
5. Use your burette to quickly fill the void space up to the bottom most spark plug thread.
6. Use the volume to calculate the exact static CR. (SV+CV)/CV=CR
7. Substitute the CR you want into the formula and solve for CV.
8. The difference is the volume you want to remove from the dome.
9. Your idea of using the clay and making an impression of the dome should work just fine. I'd probably use a pancake of clay with Saran Wrap over it and press the dome down until it was flat and level against the table. Then use the burette to fill the impression with the volume you calculated above. Measure the depth with a depth gauge or vernier caliper and you have your number.
10. Another way is to carefully trace the outline of the dome onto a piece of graph paper. Count the number of squares to determine the area, then divide the area into the desired volume to get the height. This may be slightly less accurate depending on your tracing and counting technique. I scan the trace and import it into my CAD program and use the irregular, continuous, splined shape tool to calculate the area. But if you don't have something like that, graph paper gets you pretty close.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 07-10-2016, 02:07 PM   #1054
Bomp
Bomp's Avatar
Sweet looking pieces.
Motor is going to be a monster.
Bomp is offline   Reply With Quote
Old 07-11-2016, 10:10 AM   #1055
JG67
Nice looking rig. Done with pride and patience...
JG67 is offline   Reply With Quote
Old 07-12-2016, 12:12 PM   #1056
Low Elco
Rumpity-rumpity!
Low Elco is offline   Reply With Quote
Old 07-12-2016, 01:26 PM   #1057
Stuntmonkey
Favourite build on the forum!
What are the tire/wheel specs/brand?
Stuntmonkey is offline   Reply With Quote
Old 07-12-2016, 06:59 PM   #1058
swamp rat
swamp rat's Avatar
Cant help but say it, but a lot of us are sure glad your hanging around this forum!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-12-2016, 07:30 PM   #1059
jlsanborn
jlsanborn's Avatar
I'll definitely do the final CR check that way Vic. Great thinking!
It's beginning to pile up. Need more bux!
Thanks JG, it's becoming a test of my patience!
Originally Posted by Low Elco View Post
Rumpity-rumpity!
That's what I'm hoping for. Boy thinks I wasted my time on all that exhaust and it's going to be vroom-vroooooom. We'll see!
Thanks Stuntmonkey, mine too! Wheels are from Wheel Vintiques, series 62, 15x8 and 15x10 with their standard back spacing (4-1/4" I believe). Tires are BFG Radial T/A, 295/50-15 and 235/60-15. Hub caps are something I found on Craigslist.
I totally agree! Vic has a lot of experience and is one smart feller. Always takes the high road, never half-azzed. I dream of a shop as clean as his one day too.
My fancy burrette showed up today. Gotta find a place to keep that sucker where it won't get busted!
Old 07-28-2016, 02:10 AM   #1060
808_67C10
808_67C10's Avatar
jason!!! what's up bro? Looks like the truck is coming along. when are u gonna freshen Crummy up? i hope all is well!
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 08-05-2016, 01:51 PM   #1061
jlsanborn
jlsanborn's Avatar
No more wife, new life.
Had to pull the plug boys and loaded her into a storage shed. I'll still be plunking along with this motor in the meantime but it'll likely be next year before I can build a new shop. To be continued...
Old 08-05-2016, 02:04 PM   #1062
Low Elco
Old 08-05-2016, 02:05 PM   #1063
Low Elco
Stupid phone. I'm sorry to hear this, John. Hope all are well. You moving in with Knuckles?
Old 08-05-2016, 10:26 PM   #1064
Vic1947
Vic1947's Avatar
As a guy who took 25 years to finish a project, I for one will be patiently waiting for your thread to resume. My personal philosophy is that when it comes to my hotrods, the only person I have to make happy is myself.
Victor
Old 08-06-2016, 12:47 AM   #1065
Captainfab
60-66 Nut
Sorry to hear that John. Been there myself.....been about 28 years though.
Don't be a stranger here just because you aren't working on your truck.
Old 08-06-2016, 02:06 AM   #1066
Bomp
Bomp's Avatar
whoa, take care brother
Old 08-06-2016, 02:24 AM   #1067
swamp rat
swamp rat's Avatar
Glad you could find a storage shed to take the rig, around here not as easy, hang in there and get back to it when ya can!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-06-2016, 10:51 PM   #1068
jlsanborn
jlsanborn's Avatar
Thanks all. Things will be better. Knuckles, his little sister and I are shacked up at Gramma and Grandpa's. Two tries are enough for me, so I think I'm going to build a shop out here stick around. I'll have more time and money to devote to the project too. No hard feelings with Wifey really. Mutual decision, just terribly sad. I'm not far from getting back on that 327. Brought my heads to another shop and they found more issues.
Old 08-07-2016, 11:31 PM   #1069
sduckworth13
sduckworth13's Avatar
Dang John, I feel for you man. Keep your head up, your a good man.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-08-2016, 08:17 AM   #1070
Bennett68C10
Bennett68C10's Avatar
Sorry to hear that! I went through the same thing last year. I can tell you that things will turn around for you and definitely get better.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-08-2017, 12:56 PM   #1071
808_67C10
808_67C10's Avatar
Aloha bro, hope all is well. Time heals all! Except rust... Time makes that worse! Lol
Old 01-09-2017, 01:53 PM   #1072
Low Elco
Yeah, what's up Johnny?
Old 01-09-2017, 02:36 PM   #1073
jlsanborn
jlsanborn's Avatar
Still here guys! House didn't sell before winter, so looks like I'll have to put a little more work into that this spring and get it back on the block. Wifey and I have been trying to maybe patch things up but it's been a lot of the same-o.
I did FINALLY get my heads done but it was a lot of drama, a lot of moolah and my "replacement" cores aren't as nice as the ones I had. The port job on the second set is nice but I don't think he took as much time as he did on the first. I had to wait a spell for the replacement spring but they're done. Chambers measured out at 65cc, intake runners are 165cc and the exhausts are 63cc.
Gotta save sheckles for con-rods next. Might have something in the works that'll help that situation! Stay tuned.
Old 01-09-2017, 04:24 PM   #1074
Vic1947
Vic1947's Avatar
Heads look great, John. The cutters they have nowadays make quick work of tasks that were done by hand years ago. Did your porter also use them in the pocket areas to get the basic shape? Intakes look unshrouded enough to run on a bigger bore engine. You got plans you're not sharing?
Victor
Old 01-10-2017, 01:52 PM   #1075
Low Elco
Nice stuff! How's Knuckles?
295/50-15, 327, butternut yellow, dog dish, muncie m20
