03-17-2023, 04:31 PM | #1051 |
Re: 67 GMC super custom build
And I mounted my Bruce Roe turbo 400 switch pitch controller right here above the ac housing where it can be accessed easily once the glove box is out I also mounted grommets over the holes used for the wiring harness for the vacuum lines for the door locks so the hoses don't run thru as they pass into the pillar. The door boots are pushed In like a grommet so they shouldn't see any metal edges at all.
03-18-2023, 05:06 PM | #1052 |
I modified the harness for the accessories this afternoon. I added a breaker to the 10 gauge wire that will feed the power windows and seats. They will be left unfused. The breaker ensures that if the windows do shut down they will return to operation when the breaker cools off. That way I can't be cought in the rain with the windows down and a blown fuse. They will have power all the time as they will get power from the distribution block by the battery. That is how the factory 67 gm vehicles were wired. The other side of the block for the heated seats, and other accessories will be run to an unused in the fuse block and will only have power when the ignition is on. Everything that runs out of the accessory block from that side will have a inline fuse of its own. Again that is how I believe the factory would have done this in cars. I also added the vaccum Combo valve behind the gauges for the vacuum door lock. I think everything is pretty much figured out under the dash. Now on to fine tuning everything under the hood.
03-18-2023, 06:27 PM | #1053 |
A switch pitch 400 ? I haven't even heard that in awhile. I like the idea of reset style breakers. Kinda like working on an old Harley, if you wait a few minutes it will work again. Heated seats? This thing is going to be cool.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
03-19-2023, 08:25 PM | #1054 |
Well i decided to do a full mock up of the under dash and i sure am glad i am. Under the dash is really full with all the options added. Lots more wiring. On 67 cabs only the ash tray slide bracket is welded into the dash. I drilled the spot welds and made it soit can be removed. I had to do this as the wonderbar radio would not go in with that bracket in place like the am did.
03-19-2023, 09:16 PM | #1055 |
I'm trying....
Email notifications seem to be hit and miss for me (at best). So I swung over to the thread to check on any progress...boy was I surprised. Lots of great updates I'd missed. Gotta admit it is a little more satisfying to come for a slice and find a whole cake.
Amazing as always. Keep it up! Excited for more.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
03-19-2023, 09:26 PM | #1056 |
Yeah I've been trying to keep this one going. I used my speedometer cable as a tachometer cable so I can measure it out as a mechanical tachometer was not stock. I'm running it thru the washer hose grommet since I mover the washer pump. This keeps it clean and short. Really tight under the dash for this though but it works!
03-25-2023, 07:07 PM | #1057 |
So I got the tach cable measured and made up. I used the original grommet from my truck that had the oil pressure line and manual choke in it. I just removed the choke and added the tach cable. And below it since I moved the washer pump I will use that grommet for my power locks, pitch converter signal and vacuum gauge hose. Should clean up nice
03-26-2023, 04:09 PM | #1058 |
Started a bit of mock up under the hod. So far so good!
03-27-2023, 02:40 PM | #1059 |
Driver side is pretty much done. It's going to be full Under here. Passenger side will be easy . Not much on that side because of the air conditioning.
03-28-2023, 04:07 PM | #1060 |
I unrolled my carpet for the 1st time since I bought it in 2015. Layer the old rug on it to make sure I had enough and then some vinyl on top to see how they look together. I'm happy.
03-28-2023, 10:40 PM | #1061 |
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-02-2023, 03:31 PM | #1062 |
Starting my passenger fender. I added a under hood light that is on a reel that is vintage like modern trucks have. I used a water tight switch and altered a choke plaquard to the word "LIGHT" for it like the gauges have. It's threaded so a choke knob is what I'll be using to control it.
04-02-2023, 06:31 PM | #1063 |
So is it magnetic on the back so you can just place it wherever needed?
04-02-2023, 06:44 PM | #1064 |
No it isn't but that would be a good idea
04-02-2023, 07:09 PM | #1065 |
Yeah that would be cool. Better look into it
04-03-2023, 06:06 AM | #1066 |
Well thought out additions!
71 C10 72 K20 72 K10 Super Kirk |
04-03-2023, 11:49 AM | #1067 |
So I am thinking about using my factory overdrive switch to turn the gear vendors on and off. Here is the only place I can mount it .
04-03-2023, 10:46 PM | #1068 |
I adapted the overdrive switch to a electric 2 position switch. I added the button for the liquid tire chain to this area in the hole the factory left for line up as well
04-04-2023, 09:24 PM | #1069 |
Rebuilt my engine harness and added my transistor ignition harness to it . I removed the resistance wire from the bulkhead and added a pink one for the electronic ignition. I bought some of the original style loom for the temp wire and the ones that run to the transmission and a/c too.
04-06-2023, 10:22 PM | #1070 |
Laid out my nos floor mat in my cab. Looks like it will fit just fine and will color match nicely. The only bowties in my gmc will be these. I hate it but no other options here.
04-07-2023, 11:38 AM | #1071 |
What about putting GMC logos over the bowties? Might have to get creative but that would fit the build…
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
04-07-2023, 05:07 PM | #1072 |
This whole build is really amazing. Incredible.
04-07-2023, 06:06 PM | #1073 |
04-07-2023, 08:04 PM | #1074 |
I got the air cleaner setup on the engine. Rpo k46. It's a oil bath air pre cleaner. Pretty unique. Kind of works like a cold air intake as well from the cowl. I'll have to find/get period correct hoses for it which will be hard to find. Nice thing is the air cleaner has a door on it that seals when it idles so you don't get a fuel smell in the cab back from the cowl in the vents. I assume the air pressure opens this door when the truck starts to move and closes at idle and sucks air out of the bottom .
04-08-2023, 05:57 PM | #1075 |
I never saw this post till now. Rubber is hard to work with. Mabey I could get something machined out of metal or 3d printed in plastic/rubber and press it into the circle around the bowtie. That may be an idea.
