Old 03-05-2015, 11:48 PM   #1051
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Sounds like it might be sucking air. I would verify all the clamps are tight and make sure there are no cracks in any of the lines.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-06-2015, 12:00 AM   #1052
Titomars
Titomars's Avatar
Re: Restoring Rusty
does it have dual tanks? Mine did the same thing when I first got it. I drove it around for a few days no problems. Then the switch over valve got stuck between RH and LH sucking from both tanks when one tank went dry she stopped running even though the other tank had a full tank. I never seen that happen before either.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-06-2015, 01:46 AM   #1053
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
wife gave me a ride home and we left Rusty parked at the gas station, young man at the register helped me even push him into a parking spot and away from the pumps, kid appreciates old iron, God bless him
came home had pizza fer dinner and drove back out to check on Rusty about an hour later with my tools
Rusty fired right up on the first try and I drove him home
... to be continued
Gregski is offline   Reply With Quote
Old 03-06-2015, 01:52 AM   #1054
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thanks, good tip, came home and did just that, removed the rubber line under the fuel pump that connects to the hard line and stuck it in a clean empty see through plastic water bottle, crawled under truck and removed the rubber line from the hard line that comes from the gas tank, attached a long black fuel line and clamped it down to the hard line, stuck the other end in my mouth and blew my 3 PSI into it, clean fuel came out the other end into the plastic catch all water bottle
lines are good
I installed a plastic see through fuel filter in the middle of a new black fuel rubber line between the hard line and the fuel pump
I also unscrewed the hard line from the fuel pump that goes to the carb and cleaned the threads with a wire brush and brake cleaner, there was some left over teflon tape on the threads that was all shreded and what not so I cleaned it up read good and dabbed a tiny bit of orange RTV gasket maker on the threads and screwed it back in nice and proper with a proper pipe wrench
... to be continued ...
Old 03-06-2015, 01:53 AM   #1055
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Nope just one
Old 03-06-2015, 02:00 AM   #1056
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
let's take a quick break from the troubleshootin' and talk about some fun stuff
came home and found this:
FYI: The quality is horrible, the top lid came already bent in one place, but I just used my thumbs to bend it back, since the top is made out of a single recycled 12 oz beer can, I kid you not
Old 03-06-2015, 02:03 AM   #1057
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Mr. Gasket Air Cleaner
Well let's see it on the truck.
So what do you all think? Better or worse than that Darth Vader helmet?
which by the way is for sale for only $50 plus shipping, best part is NEVER BEEN RACED, lol, pm me
and yes now I need a shorter stick to clamp this thing down with a wing nut, god forbid my three air cleaners were all the same height, jk
Old 03-06-2015, 02:06 AM   #1058
Titomars
Titomars's Avatar
Re: Restoring Rusty
Now, I like that air cleaner assembly.
Old 03-06-2015, 02:11 AM   #1059
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Painted the Kick Panels
it was a nice day so I painted [ahem] stained them kick panels
three light coats, you know the drill
Old 03-06-2015, 02:16 AM   #1060
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
whilst the paint was drying it was time to drill out the rivets and separate those air vent valves so that we can clean, prep and paint the metal and sandwich new rubber fillings in them eventually
Old 03-06-2015, 02:19 AM   #1061
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I buy you new shinny things, I clean and paint your bits, and this is how you thank me Rusty?
There is literally oil drizzlin' out of the top bolt hole behind the fuel pump?
Is that supposed to be a blind hole?
Do I have a crack in my block gentlemen? What gives? Please advise?
Old 03-06-2015, 02:22 AM   #1062
craig113
Re: Restoring Rusty
That is the fuel pump retaining bolt hole. Put a bit of teflon tape on a short bolt and tighten to stop the leak.
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles
91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles
96 K15 Sub 350/4L60/243c/10 bolt 333k miles
craig113 is offline   Reply With Quote
Old 03-06-2015, 02:31 AM   #1063
jetmech85
Re: Restoring Rusty
The hole is open to the fuel pump push rod. Install a 3/8 bolt about a half inch long with a lock washer and thread sealer and that should fix you up. When changing a fuel pump you can snug a longer bolt in that hole to hold the fuel pump push rod in place so it wont slide out against the adapter plate and cause you grief and anguish.
jetmech85 is offline   Reply With Quote
Old 03-06-2015, 02:34 AM   #1064
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thanks, here's a look how we got here
Old 03-06-2015, 02:37 AM   #1065
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Smart people...
Chaplain is offline   Reply With Quote
Old 03-06-2015, 04:10 AM   #1066
y5mgisi
y5mgisi's Avatar
Re: Restoring Rusty
Exactly.
Old 03-06-2015, 05:56 PM   #1067
rusty76
rusty76's Avatar
Re: Restoring Rusty
Vent not clogged up or maybe hung up somehow and preventing it from allowing the gas to be sucked out of the gas tank? If the pump is working then there's a air leak some where I would suspect..... Hope you get it fixed soon.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-06-2015, 06:29 PM   #1068
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
Or no vent line, and unvented gas cap? That will do it.
So, you got two lines to the tank, or three?
If no vent line, all you have to do is drill a 1/16" hole in the gas cap.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 03-06-2015, 06:59 PM   #1069
greg64
greg64's Avatar
Re: Restoring Rusty
I totally agree with the physics of this Rich, but I wonder about whether that will fly in California or not. The emissions police in BC would fail a cap like that.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-06-2015, 07:27 PM   #1070
brakenit
Active Member
Re: Restoring Rusty
If I remember right his truck is a '74 which would make it emissions exempt in California.
brakenit is offline   Reply With Quote
Old 03-06-2015, 08:01 PM   #1071
rich weyand
Re: Restoring Rusty
Yeah, I think it depends on how it was equipped when new. No vent line means vented cap.
Of course you can check it by driving it till it stops, then open the gas cap. Sucking sound, then runs fine means no vent line.
Rich Weyand
1978 K10 RCSB DD.
Old 03-06-2015, 08:23 PM   #1072
rusty76
rusty76's Avatar
Re: Restoring Rusty
I feel for sure we are looking at a venting issue. It makes some what sense in what he is saying is happening with his truck. Hopefully we will find out.
My build thread
Crossmembers CC
Old 03-07-2015, 12:20 AM   #1073
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thank you all for helping me with the fuel issue
my tank has a vent that goes to the filler neck and then two hoses run to the engine bay one for fuel the other for evap to the charcoal canister
let me give you some updates
today I plugged that bolt hole that was leaking oil, I am sure I caused this issue when I deleted the A.I.R. pump as it looks like the bracket was attached to those holes, so I took one of the original bolts, cleaned it, put a little RTV on the threads and screwed it in
here's a pic of the Air Pump bracket
Old 03-07-2015, 12:24 AM   #1074
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I decided to get started on the brakes since I didn't want to trouble shoot a truck that won't run when it also may not wanna stop
so this is the situation the darn brake master cylinder looks like this after a short drive, all wet
Old 03-07-2015, 12:36 AM   #1075
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Brake Master Cylinder
so time to remove the brake master cylinder
I just had to take a peak inside, since part of me considered rebuilding it myself, like my daddy and I used to do back in the 80s when parts were fixable not replaceable
I was able to remove the first valve but I do not have needle nose pliers or the special pliers to get the other snap ring out which is half way down the cylinder
