Old 12-28-2020, 11:57 PM   #1051
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
It has begun. Last piece of the metal puzzle.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-29-2020, 12:02 AM   #1052
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Found a bad spot that had to be fixed. This makes both sides same amount of repair done. This hood was in bad shape...
"It's only money".
Old 12-29-2020, 10:33 AM   #1053
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: TA_C10: Stage 1
My arms are tired just looking at that...
Home stretch though. Keep going with the jello arms.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-29-2020, 10:40 AM   #1054
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
I'm having nightmares looking at all that filler. But you're on the home stretch now!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 12-29-2020, 11:42 AM   #1055
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
LOL. That's what your supposed to do right? Put a skim coat on everything no matter what? Pfff, I have no idea what I'm doing, I just go for it...
I started with 36g on a long block and quickly realized this was no small task. Finished that and went with 80g on a DA. Now I'm back to 80g on a long block to finish it off. Each day I get hood out and throw it on horses out in the driveway. Then I have to put it away again. I can't wait for a real shop....
After 2 days of sanding.
"It's only money".
Old 12-29-2020, 11:59 AM   #1056
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Quick reminder of how bad the hood was. This was one of my first welding jobs ever... I guess I gave up on it a year ago because I found the other side was just as bad....
"It's only money".
Old 12-30-2020, 02:37 AM   #1057
Scurry67
Re: TA_C10: Stage 1
Hood is looking great! I feel your pain with the sanding... but it’ll all be worth it! You’re definitely on the home stretch
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 01-04-2021, 04:27 PM   #1058
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks!
"It's only money".
Old 01-04-2021, 04:33 PM   #1059
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Small update.
Took truck to alignment shop, they were no good, couldn't do caster/camber, only toe. So I won't be going back to them. But in the process I found out I put my control arm bushing seals on backwards... So I ordered new ones and they finally arrived for me to install. I pulled it apart a while back when I got back from shop but was unable to just turn them around and reinstall because the bolts for shaft snipped them so they were ruined. Well I installed them this weekend, and I was not paying attention but I did the same thing to the lowers as well. WTH.... Lowers are not ruined however, will have to tear down again to fix those...
Wrong ......
Right ....
"It's only money".
Old 01-04-2021, 06:11 PM   #1060
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Ah man what a bummer. Good thing the suspension on these trucks is so simple and easy to work on!
Old 01-04-2021, 08:48 PM   #1061
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
You got that right, simple is the word.
"It's only money".
Old 01-06-2021, 02:49 PM   #1062
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Flush Mount License Plate Box with Hidden Hitch
Well I have a rough mock-up of it. Still need to clean up my cuts around the trailer hitch hole. But it works. I'm happy with it. I will need an extended hitch receiver. And I am still deciding whether to use the stock style license plate light or go with the lights that came with kit(lights you see in my pics). It works great. There is plenty of room for plate to flip up and see/access the hitch to install the receiver.
One thing I am disappointed in however, is HartFab sells this box and I never found it when searching for a "license plate box for 67-72" on the web. He is selling same box with very little difference. And it's only $75 compared to the $99 at brotherstrucks. I would rather buy from a local member on here to support them.
https://hart-fab.com/products/67-72-...ense-plate-box
3 main steps I did to modify this box:
#1 = Drilled new holes for flip bracket. They are a little wider than stock holes for license plate.
#2 = Cut access hole in box for hitch receiver to insert.
#3 = Had to cut the 2 top mount bumper license box holes off so the flip kit would swing up far enough for access.
If you wanted to modify a stock box you probably only need to add material to the sides of box to raise it up behind bumper and drill 2 side holes for mounting. You can keep your OE license plate light assembly. Rest of my steps would still apply unless your not doing the hidden hitch.
My angle with camera is bad here, not centered, but again I do need to finalize these cuts and spray a little paint to complete. I was cutting small amounts at a time till I get it where I want it. OH, and the box does not lose any stability with this cut. Not enough to make any difference anyway. The box doesn't do anything but hold the license plate anyway.
Not sure if I am going to use these lights from the kit, but they are just tucked under the plate for now. Later pics show them working.
Here you can see the tabs I have cut off of bumper so the plate swings out far enough. It still locks out for ease of use too which is awesome.
Here is a short receiver installed. The plate will fold down completely with receiver installed I just didn't take a pic of this. With an extended receiver I will be able to flip the receiver upside down since the truck is so low. Keep the trailer up high enough.
Back of box view. You can tell here how the stock light lamp would still work on top if you want to go that route.
Few extra pics. Some I took as it started to get dark so lighting was temporarily installed to see how the kit lights work.
"It's only money".
Old 01-07-2021, 01:53 AM   #1063
First c10
First c10's Avatar
Re: TA_C10: Stage 1
Looking good. I like the hidden hitch. I should be getting the rear of my truck completed soon.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-07-2021, 05:16 PM   #1064
chewychevy67
Re: TA_C10: Stage 1
That flush license area does look much clean and smoother.
chewychevy67 is offline   Reply With Quote
Old 01-18-2021, 12:58 PM   #1065
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
It's supposed be 67* today. This might happen... See how far I get.
"It's only money".
Old 01-19-2021, 11:44 AM   #1066
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Backup Camera
Everything has been hardwired and routed for a while, been working with siggy on 3D parts. Ended up using the customized original metal part from OE style mirror for now. It works really well from what I can tell, haven't had a lot of time to play with it yet. But right now it's working without the antennae connected to transmitter under the truck(It's 2.4Ghz wireless from camera to rear view mirror) so I expect the image quality to enhance and be a little quicker turning on/off, but it's already really good. It's hard wired to the reverse lights switch on column. Between the reverse lights and camera LED's it's got a ton of light at night.
a note on pics and video below, I still have the screen protector on so it's not very clear looking.
Here you can see my wire routed out of the roof panel is hidden by the mount, all you see is the wire next to arm.
And here is a quick video I did showing it coming on and off putting the transmission in reverse and back to park.
https://youtu.be/OU8VIBPTGZI
"It's only money".
Old 01-19-2021, 12:11 PM   #1067
1971Stepside
Almost Satisfied
Re: TA_C10: Stage 1
Put that lawn mower away! It's January
Old 01-19-2021, 12:39 PM   #1068
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
That came out very clean - nice work.
Old 01-19-2021, 05:08 PM   #1069
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
LOL, I have grass in the backyard that is year round man(tall fescue blend). It's pretty, but it sucks cuz Texas doesn't get cold enough for it to go dormant.
But really, it was just out cuz of my small garage and it comes out everyday so I can work on truck....
Thanks man. I just hope for longevity it lasts for a long time. Otherwise I hopefully have it setup in such a way I can pull new wire for newer "replacement" if required.
"It's only money".
Old 01-20-2021, 12:07 AM   #1070
First c10
First c10's Avatar
Re: TA_C10: Stage 1
Nice work. I like that mirror ����
GO GO!!!
Old 01-22-2021, 11:31 AM   #1071
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: TA_C10: Stage 1
Good work. That mirror is pretty cool.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-22-2021, 02:40 PM   #1072
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks guys, hope it is a good one and lasts long time!
I will leave these here for fun. Bragging rights goes to the first person who guesses which hand I am holding up(left or right) LOL.
"It's only money".
Old 01-23-2021, 05:05 AM   #1073
siggyfreud
siggyfreud's Avatar
Re: TA_C10: Stage 1
Should be the left, right?
siggyfreud is offline   Reply With Quote
Old 01-23-2021, 06:25 AM   #1074
SIXTY9
Re: TA_C10: Stage 1
I guess the right, reason being the lettering is backwards on the tailgate.
SIXTY9 is offline   Reply With Quote
Old 01-24-2021, 12:16 PM   #1075
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Sixty9, winner winner, c10 dinner. It took me a while looking at it myself before I realized what was off. They did the software right in the camera so it's exactly right for a rear view look backing up. You never know when it comes to aftermarket, those little things make or break the product.
I got the hood primed last weekend too, glove box door, tailgate hinges and handle. It took forever for that primer to dry sitting outside in driveway at 65* for about 2 hours, then temp dropped to around 55* by the time I put it away around 8pm.
So finishing up in sealer and final paint I need at least 75* so when it drops in temp it will dry properly. Might have to rent a booth. And I really don't want to spend the money on that...
"It's only money".
