Old 07-08-2020, 11:19 AM   #1051
Gregski
Post Whore
Gregski's Avatar
Re: A '54 named Busty
Originally Posted by 8man View Post
Yep, hook up that multimeter and you have a winner...or a looser and you re-do it.
I've not done the thinning of the PCM like you did, and I hooked it up with with all the connectors attached to the wires, but it does looks interesting. Where/how did you learn to thin the harness?
from Brandon aka the "Godfather" of LS Swap wiring - he has a *****in' website lt1swap.com that has all the detail of the pin outs and does a three part video series on You Tube on how to do it wire by wire, I watched the videos a dozen times there is a lot going on in them and he does not edit anything out, please give it a go
2003 Vortec 5.3L Wiring Harness Rework Part 1
Gregski is offline   Reply With Quote
Old 07-08-2020, 12:23 PM   #1052
8man
Aren't you the same guy who was posting temps because it was so hot?
Also, why is a tilt an old guy accessory?
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-08-2020, 01:31 PM   #1053
Gregski
Post Whore
Gregski's Avatar
yes too hot to wrench not too hot to Hot Rod, ha ha
AC, tilt, cruise control, power windows, power seats, not necessarily old man accessories just don't belong on a Hot Rod, those who do miss the point - less is more (and I'm right and everyone else is wrong, ha ha)
Old 07-08-2020, 01:54 PM   #1054
8man
Had not seen his video. I will be watching it, thanks. I'm thinking LS for the 54. I mean what old guy needs more than one carb'd truck?
8man-aka Robert
Old 07-08-2020, 02:01 PM   #1055
Gregski
Post Whore
Gregski's Avatar
LOL, careful an LS Swap is a gateway drug to Turbo!!!
Old 07-08-2020, 04:33 PM   #1056
8man
Turbo? Hmmmmm
8man-aka Robert
Old 07-08-2020, 05:58 PM   #1057
joedoh
joedoh's Avatar
nice wire monkeying!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-08-2020, 06:14 PM   #1058
Gregski
Post Whore
Gregski's Avatar
thank you, the Struggle Is Real!
Old 07-08-2020, 06:55 PM   #1059
LT7A
Originally Posted by Gregski View Post
um, thank you?!
says the evil man who stood proud in my driveway couple years ago and planted the seed of LS swapping using the reverse Jedi mind trick - all I wanted was to live a simple carburated SBC life and chase endless oil leaks and tangle yet another timing light cord in my radiator fan whilst timing the arcane distributor, ha ha
Hahaha!
I'm just getting caught up here. I didn't mean for you to really do it...
Twice...
So far...
Old 07-08-2020, 06:59 PM   #1060
LT7A
Originally Posted by notsolo View Post
As usual I overlook the obvious, I was thinking more like wife standing in doorway with hands on hips...."What Now"....😲
He hasn't mentioned her to me in a while. Maybe she's adapted to his antics. I'm a little concerned he may have swapped her for an LS.
Old 07-08-2020, 07:06 PM   #1061
LT7A
Re: A '54 named Busty - Setting The Engine Pinion Angle
so picked up one of these protractor gauges and checking what I guess may be called engine pinion angle, for years I relied on my eyecrometer for engine placement and my trusty butt-o-meter for driveline wobble, but trying to graduate to the next level, so any insight is appreciated, the first page i Googled said 3° on the enjin so shooting for that
Just checking. I'm not familiar with that device. Does it give you a measurement relative to the truck, or is it degrees off of level, so you need to take vehicle rake and slope of your garage slab into account?
Old 07-08-2020, 07:56 PM   #1062
LT7A
Option A - Long and Strong nothing Wrong just some air flowing Along...
Now who's the poet...
Old 07-08-2020, 10:17 PM   #1063
Gregski
Post Whore
Gregski's Avatar
Originally Posted by LT7A View Post
Hahaha!
Twice...
So far...
you out of all people should know you can't leave me unsupervised for any extended period of time!!!
Old 07-08-2020, 10:20 PM   #1064
Gregski
Post Whore
Gregski's Avatar
the latter and I know my garage slopes forward (as evident by a pile of sockets in the two front corners of the garage at the end of each project, ha ha) however when I set that dial gauge on my garage floor the rise over run was negligible so I called that a zero and shot for 3° of engine slope downess towards the rudder
Old 07-08-2020, 10:24 PM   #1065
Gregski
Post Whore
Gregski's Avatar
we observed a couple days of no spoken word after she gently moved my thinned out and perfectly laid out wiring harness in the middle of the wiring [ahem] living room to my office
Old 07-09-2020, 01:32 PM   #1066
Gregski
Post Whore
Gregski's Avatar
gonna roll my own fuse block
simple design, two relays, a main power relay and one for the fuel pump
Old 07-09-2020, 06:12 PM   #1067
Wide Open
Cool. I have a similar setup for headlights, fuel pump, etc. I like it a lot.
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 07-09-2020, 11:00 PM   #1068
Gregski
Post Whore
Gregski's Avatar
cool, mind sharing a pic, I would love to see the brake lights, reverse lights, turn signal break down you done did please?
Old 07-09-2020, 11:08 PM   #1069
Gregski
Post Whore
Gregski's Avatar
cutting, taping, thinning
extending, soldering, untaping, zip tieing, doing it again
shortening, lengthening, arranging, rearanging, doing, undoing,
removing, adding, heat shrinking,
wrapping, unwrapping... doing it again!
live to swap
swap to live
do or die
revving high
Old 07-10-2020, 03:47 PM   #1070
Wide Open
I should be able to get you one next week. I’ve moved beyond the wiring room living phase (at least for now) and she at the body shop getting an estimate.
1972 K10
2002 Z06
2007 Escalade
Old 07-10-2020, 03:59 PM   #1071
Gregski
Post Whore
Gregski's Avatar
oh boy, exciting times, let us know what your Go Fund Me link is?
Old 07-10-2020, 08:44 PM   #1072
Gregski
Post Whore
Gregski's Avatar
scored a PCM tray out of a '97 S10 - I really like these as installation is a snap! ha ha literally
Old 07-11-2020, 09:04 AM   #1073
Gregski
Post Whore
Gregski's Avatar
just waiting on more parts to finish up the fuel lines and the wiring harness, was hoping to fire her up this weekend but that may not happen now
Old 07-11-2020, 09:22 AM   #1074
8man
That sucks! A perfectly good weekend and waiting on parts. I'm sure you can find something to work on, so it will still be a good weekend.
8man-aka Robert
Old 07-11-2020, 01:03 PM   #1075
Gregski
Post Whore
Gregski's Avatar
Ah yup, progress not perfection
