Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-15-2009, 01:59 PM   #1076
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by Chevyman63 View Post
I sure hope so. It's about time!
Glad to hear your weekend went great!
I'm not sure if I'm going to go with the SS or plain steel. And I see that In-Line offers a 1/4" front to rear fuel return line, but I didn't have one on my Blazer?
Are you sure on the 1/4" fuel line? I had 3 lines, brake, 5/16" fuel, charcoal canister. Got rid of the charcoal cannister
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-16-2009, 03:52 PM   #1077
RustyParts
RustyParts's Avatar
Re: PO has me PO'd
Originally Posted by jaros44sr View Post
Also, I found out that if you use assembly lube on the fuel pump drive shaft it will keep it up in the block while you install the fuel pump
Make sure your engine is at the proper rotation, so the shaft is as far up in the block as it will go, makes it easier to assemble the fuel pump
Another little neat trick with the fuel pump rod is to remove the 3/8" bolt on the front of the engine just to right of the fuel pump, you can see the rod when the bolt is removed, and install a longer bolt but just tighten it finger tight against the pump rod that will hold her for sure.
Good lookin' work trooper.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 06-17-2009, 10:45 AM   #1078
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Holy crap! Voices from the past Nice idea on the bolt, didn't know that. I started to take that bolt out, but heard weird noices(crunching and crackling), so I tightened it back up. We should start a tip of the month thread
How's things with the Jimmy?
SAFETY FIRST
AS usual, off topic
Jim
Old 06-18-2009, 04:30 PM   #1079
RustyParts
RustyParts's Avatar
Re: PO has me PO'd
Coat of paint, exhaust, and tires and I'm finished. Also need seat covered, carpet, Weatherstripping.
Old 07-11-2009, 01:10 AM   #1080
1949gmc
Re: PO has me PO'd
After all the 'small parts' comments in the other thread, it got me to wondering how you've been doing with this project. Anything new to report? I can't tell you how much the pictures have helped me figure my truck out. Thanks for being so detailed!
1949gmc is offline   Reply With Quote
Old 07-11-2009, 11:12 AM   #1081
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
You're welcome, and thanks for watching! Jon's a funny guy, and thanks for having a sense of humor
I'm off to my Mothers 90th birthday, so I don't have much time, don't think she would understand my delay...
I'll try to post up in the next couple days, old and new problems arose, but progress continues
Gotta love having the edit button back
SAFETY FIRST
AS usual, off topic
Jim
Old 07-11-2009, 08:24 PM   #1082
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
J/K
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 07-11-2009, 09:29 PM   #1083
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
J/K
dayum, I knew I would get one of them sooner or later
SAFETY FIRST
AS usual, off topic
Jim
Old 07-13-2009, 01:39 PM   #1084
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Here's some pics. of what I'm into...
Alum. fuel line. Found out that -6 and -8 AN sizes are uni-flare, meaning a 45° flare tool will work. After seeing what happened to AJ's engine, I left a piece of rubber fuel line after the fuel filter that can be clamped off to run the engine out of fuel and work on the carb. Still waiting on the last of the fittings after the fuel filter, it is a 150° bend so the rubber hose doesn't hit the cross member
After alot of help, including diagrams, from the electrical guys( thanks VetteVet) I decided to send the harnesses back to M&H for the mods. Still under warranty, should be back in a couple weeks. Got the mechanical side of the water pump plumbed, so that is a plus
Interior is still pending, samples arrived, exactly as original. But they included a green color, and that threw a monkey wrench in the works
Clocked my alternator, another problem, since the armature came outta the brushes. Realized there is a hole thru the brush holder and rear half of housing to insert a rod to retain the brushes and allow you to reassemble the armature. DO NOT separate the field windings and rear half of the alternator, bad things will happen! You only have to pivot the front half to get the wire locations correct
SAFETY FIRST
AS usual, off topic
Jim
Old 07-14-2009, 10:48 PM   #1085
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
Looking good Jim!
low'n slow is offline   Reply With Quote
Old 07-15-2009, 12:19 AM   #1086
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by low'n slow View Post
Looking good Jim!
Thanks Doug, bad news today, M&H said 6 - 8 weeks to modify my harness! So, I'll be on the sidelines watching all the other builds, but there are alot of interesting builds to watch...These guys on this forum have the best trucks anywhere
How's things down your way, PM me.
SAFETY FIRST
AS usual, off topic
Jim
Old 07-15-2009, 06:52 AM   #1087
msgross
msgross's Avatar
Re: PO has me PO'd
sounds like you need to come hang out with us at Carlisle truck show then!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-15-2009, 07:55 PM   #1088
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Oh man, I should bring all my years of parts gathering parts down there, sure would like to sell em off.
It's all good stuff but it's only good stuff to us poor folk lookin' for it...
vtblazer is offline   Reply With Quote
Old 07-15-2009, 08:13 PM   #1089
msgross
msgross's Avatar
Re: PO has me PO'd
only $75 for a 10x30 spot with passes to get in and out with your driver. I might bring the RV up there for a little party..
The Garage:
Old 07-15-2009, 08:16 PM   #1090
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Minor hi-jack Jim but it's my turn anyway...
So Mike, when is it?
I really do have a lot of stuff I could bring down, my trailer would be full.
You offering me a bunk in the RV?
Old 07-15-2009, 08:47 PM   #1091
msgross
msgross's Avatar
Re: PO has me PO'd
hijack...
7-9 Aug
www.carsatcarlisle.com Special-K (Tim Hicks) has three spots near the truck shop (california) and usually has a cot in his area. IF I bring the RV then you are more than welcome to crash. I will probably only be there on Friday and Sat (fri night) since I live 45 minutes away and sunday is kinda dead.
The Garage:
Old 07-15-2009, 10:23 PM   #1092
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
Glad to see somebody got some benefit out of my little fire.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-16-2009, 11:02 AM   #1093
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I'll see what I can do for Saturday
, you're probably still aleast 5 up. BTW, good luck with the surgery
Yeah, sorry that it worked out that way, but it got me to thinking how can I prevent this from happening again
SAFETY FIRST
AS usual, off topic
Jim
Old 07-16-2009, 12:58 PM   #1094
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
I could try and make arrangements to deliver the blue blazer then and come down and hang out possibly
Thanks, I go under the knife first thing in the motning.
I was also remembering AJ while I was cutting the flush mount gas door out of the quarter.
Old 07-16-2009, 01:15 PM   #1095
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
How about using electric shears, anything without sparks
You know my house is always open to you...candle burning in the window for guests. I get done work at 00:00 friday nite/saturday morning. I'd be honored to pull your fat arse around in a wagon at Carlisle
SAFETY FIRST
AS usual, off topic
Jim
Old 07-16-2009, 01:26 PM   #1096
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
If it looks like I can have the blazer completed in time, I'm all for it.
Old 07-16-2009, 01:43 PM   #1097
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Man...you beat me to it.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 07-21-2009, 12:25 PM   #1098
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Couldn't stand it any longer! Had to mount up my new fenders...couple shims here and there, also have to file lower fender mount hole, but not a bad fit for OEM to Repop. Nice work Tri-Pro!!! Gotta wait on mounting the grille and core support, need access to engine compartment
SAFETY FIRST
AS usual, off topic
Jim
Old 07-21-2009, 02:22 PM   #1099
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Looking good Jim.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 07-22-2009, 10:47 PM   #1100
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: PO has me PO'd
Lookin' slick with the fenders on there.
BAZINGA!
My Build
Big J is offline   Reply With Quote
