Old 08-22-2012, 12:26 PM   #1076
watahyahknow
watahyahknow's Avatar
Re: Finally starting my Longhorn 4x4 conversion
iether that or buy leafsprings with more of an arch in them
you might even be able to combine 2 sets by taking one set apart and use parts to put a couple of extra leaves in the 2nd set it will bounce like hell though
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-23-2012, 10:14 AM   #1077
mknittle
mknittle's Avatar
L@@ks great Ryan! I hav en't cheacked out your build for a while and I am missing out
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-23-2012, 08:37 PM   #1078
mcbassin
Still Learning
mcbassin's Avatar
Nice progress Ryan. I love watching all these builds get closer while mine just sits...
mcbassin is offline   Reply With Quote
Old 08-23-2012, 10:07 PM   #1079
ryanroo
ryanroo's Avatar
progress looks great. your engine compartment is looking really clean and spiffy. the picture looks like it is miserably humid though!
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 08-25-2012, 09:08 PM   #1080
1972RedNeck
1972RedNeck's Avatar
Originally Posted by Dieselwrencher View Post
I also picked up this spare cluster from a friend.
How do people get lucky enough to stumble across something like this?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-25-2012, 10:25 PM   #1081
ryanroo
ryanroo's Avatar
i had that same thought. considering i am building a diesel truck as well, i have been keeping my eyes peeled for a diesel tach cluster and Ryan ends up with 2. some guys have all the luck
Ryan
72 K20 12v build
Old 08-29-2012, 09:41 PM   #1082
doubleb's69
doubleb's69's Avatar
Looks great Ryan.
Bud
doubleb's69 is offline   Reply With Quote
Old 08-30-2012, 02:17 AM   #1083
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It was dumb luck this time.
Ryan
My first one I purchased from a member here on the board and paid 2 1/2 times more than what I have in this one. I need one for my crew cab truck you know.
Originally Posted by doubleb's69 View Post
Looks great Ryan.
Thanks Bud!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-30-2012, 02:21 AM   #1084
Dieselwrencher
I managed to get the suspension sitting how I want it and not super high in the rear. Now I have to get the rear axle as close to centered in the wheel tubs as I can.
I managed to get the steering block on and the drag link hooked up. I have to get a reamer so I can get the chevy rod end in farther to the dodge steering arm.
I have to get new tie rods because Napa decided to give me the wrong ones.
Ryan
Old 08-30-2012, 04:25 AM   #1085
birdistheword
birdistheword's Avatar
Looking good keep at it.
birdistheword is offline   Reply With Quote
Old 08-30-2012, 08:02 AM   #1086
ryanroo
ryanroo's Avatar
Sweet
and that reminded me i need to mail that block for our crewcab. its still sitting in my garage....
what did you do to change the rear suspension height? i think mine is going to be high in the rear. i prefer it to be a bit higher, but without the fuel tank batteries and a bed i'm not sure yet if ill have to adjust it or not.
Ryan
72 K20 12v build
Old 08-30-2012, 02:42 PM   #1087
Str8-6-68
Str8-6-68's Avatar
Very nice progress Ryan, this orange beast will be burning rubber in no time now!
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 08-30-2012, 07:33 PM   #1088
Dieselwrencher
Thanks man.
Sweet
Ryan
That's funny you mentioned that. I was looking around for it because I couldn't remember if you sent it or not and I thought I lost it like all my other spare parts. LMAO. I prefer the back to be higher a little too, but mine was literally 4" higher. I didn't want to raise the front that much because I don't want the truck to look stupid. Big lift, small tires you know. I ended up replacing the front spring hangers on the rear springs with 2wd ones and removed the 4wd ones. This literally dropped the rear 4".
Getting real close buddy.
Ryan
Old 08-30-2012, 07:37 PM   #1089
Dieselwrencher
I just remembered some thing else. I saw on another thread where some one was saying the studs on the D60's like to break off? I can't imagine that unless you get in a wreck or severly shock load the front tires. The same guy mentioned going to crossover steering, which isn't a bad idea. But you still use the same area to mount a tie rod to, so what's the diff?
Ryan
Old 08-30-2012, 09:25 PM   #1090
ryanroo
ryanroo's Avatar
Thanks man.
That was going to be my suggestion if you didn't figure something out. great minds think alike i guess. did you have to leave the shackle bolted real close like it was? i think if it stays that way it will make the ride real choppy.
i know with the block there is a little more chance of it happening, but in the stock form in a driver type truck its a non issue. with huge tires and hydraulic steering sometimes they do shear simply from being over stressed. the off road world has solved that issue by making knuckles and arms that are keyed. in a stockish height truck and with the intent being street driver/tow i much prefer the GM factory style steering. crossover wants to push the axle on the springs and is really not that easy to get rid of bumpsteer with. the steering on my jeep is crossover and i spent plenty of time making sure the drag link is flat and everything is correctly matched. i still have a little bumpsteer wiggle on bumps on the street. with all the components in good working order and the drag link angle reasonable and sane GMs stuff does great. the only improvement would be to have the swing point of the steering in line with the spring eye so the drag link and axle swing in the same arc.
Ryan
72 K20 12v build
Old 08-30-2012, 09:57 PM   #1091
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Are you going to have full steering to the left like that? I was looking at a square body the other day with a dodge arm and it looked like it was going to need two of the short tie rod ends for it to work right, and also the hole reamed out from the top.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 09-03-2012, 08:05 PM   #1092
1968vetL-71
Junior Member
1968vetL-71's Avatar
Hey Ryan, just cruzin through and checkin out the progress. Great job! Everything is going together well. Can't wait to see that bad boy beatin the pavement. Again... great job man.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 09-03-2012, 11:03 PM   #1093
mknittle
mknittle's Avatar
Great job Ryan, looking good!
Mark
My GMC build.
Old 09-04-2012, 02:23 PM   #1094
Dieselwrencher
Yes I did have to leave the shackle bars short. I may have to make another set and give it a half inch or so. I don't know yet. We'll see how it rides I guess.
Ryan
I have heard the same issues you just described with the cross over steering before. Fords basically have cross over steering and they get bad bumpsteer when components start to wear. Plus, I want to keep the cost down and use what I have for now.
Ryan
Old 09-04-2012, 02:25 PM   #1095
Dieselwrencher
This is aother concern of mine. Once I get a steering column in it I can check that. I'd like to find a GM style steering arm for it, but if I can't, I'll have the rod ends cut and tapped so I can get it shorter. We'll see I guess,
Ryan
Old 09-04-2012, 02:26 PM   #1096
Dieselwrencher
Thanks guys. It is taking longer than I'd like. But I haven't been able to work on it at all.
Ryan
Old 09-05-2012, 07:59 PM   #1097
Beat68CST
Beat68CST's Avatar
Ryannn!
When are you gonna start on your hood latch?!
I've moved away from mine so you could master it and I could copy ;D
I'm gonna make my loop drop down lower tonight where my drive shaft runs through and the original carrier bearing is so I can run a single.
BUT! Good work as always! I'm loving it!
Beat68CST is offline   Reply With Quote
Old 09-05-2012, 09:33 PM   #1098
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I just got to thinking and my idea with the two short ends won't work, the long one is right handed threads and the short one is left handed threads. So like you said you will either have to find a short one with RH threads or cut it and have it threaded.
Tony
Old 09-06-2012, 08:38 PM   #1099
Dieselwrencher
Right now the way you see it in the pics, with the front end on jack stands, I can turn it stop to stop from right to left with no issues. I actually need to run the stops in from where dodge had them set. I don't think I'm going to have an issue. We'll see though.
Ryan
Old 09-09-2012, 11:39 AM   #1100
Dieselwrencher
I'd like to thank Bud, Double B's 69, for helping me get a really good deal on a pretty nice driver shape 72 grill. Thanks again Bud!
Ryan
