Old 03-07-2012, 11:53 AM   #1076
dv8customs
dv8customs's Avatar
Re: Project '86
No tach, I could have gotten a matching 5" tach for another $150 but I was already stretching the budget.
dv8customs is offline   Reply With Quote
Old 03-08-2012, 08:48 AM   #1077
cletis
cletis's Avatar
Re: Project '86
Dash looks good! It's amazing what your creatinity and a beadroller can create.. Were the 1/4 windows cut up to work?
I think I can, I think I can,
http://67-72chevytrucks.com/vboard/s...d.php?t=452601
cletis is offline   Reply With Quote
Old 03-08-2012, 09:11 AM   #1078
dv8customs
dv8customs's Avatar
Re: Project '86
I had to trim about 1" of weatherstrip and window track off the top.
Old 03-12-2012, 06:24 PM   #1079
begining87
begining87's Avatar
Re: Project '86
Originally Posted by dv8customs View Post
Can't wait until the matching air gauges show up!
Looks as if you wanted it to look that way; Man that looks really good. Are you going to make a center console to cover the large hump you built?
begining87 is offline   Reply With Quote
Old 03-12-2012, 07:11 PM   #1080
|ow|ife
|ow|ife's Avatar
Re: Project '86
subscribed, jealous of your talent!
it's not what you buy, it's what you build
use your skills, not your wallet
|ow|ife is offline   Reply With Quote
Old 03-12-2012, 10:02 PM   #1081
dv8customs
dv8customs's Avatar
Re: Project '86
I don't plan on building a console but who knows what may happen when I get further along on the interior.
Thanks, it's mostly trial and error
Old 03-12-2012, 10:18 PM   #1082
96twodoor
96twodoor's Avatar
Re: Project '86
truck look awsome !!
96twodoor is offline   Reply With Quote
Old 03-13-2012, 12:39 PM   #1083
dv8customs
dv8customs's Avatar
Re: Project '86
Air gauges are shipping out today!
Old 03-15-2012, 11:12 PM   #1084
dv8customs
dv8customs's Avatar
Re: Project '86
Alright guys I need some help, I bought this windshield gasket from Brothers
http://www.brotherstrucks.com/prodin...number=W387STD
I have no idea how this thing goes!
Let's call this the top
This is the right side and it has two channels
This is the left side and has one large channel
This is the bottom
Anybody know how this works? Every way I turned it looked wrong.
Old 03-16-2012, 12:39 AM   #1085
CuRtdOgG
CuRtdOgG's Avatar
Re: Project '86
I would assume that the large channel is for the glass, one small channel should fit the metal around the window frame...and the other small channel I would think would be for a trim piece. I know you can purchase them w/ and w/o trim??? Hope this helps?
CuRtdOgG is offline   Reply With Quote
Old 03-16-2012, 12:40 AM   #1086
Nobaddaze
Nobaddaze's Avatar
Re: Project '86
sorry buddy, i have no idea??
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 03-16-2012, 12:46 AM   #1087
CuRtdOgG
CuRtdOgG's Avatar
Re: Project '86
actually i was wrong the big opening is where the pinch weld window frame goes (goes towards the cab)...the 2 small should face the front of the truck, one is for glass and one for a trim piece.
Old 03-16-2012, 12:48 AM   #1088
CuRtdOgG
CuRtdOgG's Avatar
Re: Project '86
The glass should fit in the middle groove with the larger channel going towards the truck to sit on the metal..and then a trim piece inserted on the outer groove. then you lay it in the frame.
Old 03-16-2012, 08:19 AM   #1089
dv8customs
dv8customs's Avatar
Re: Project '86
I got the no trim version.
Old 03-16-2012, 10:06 AM   #1090
truckzilla
truckzilla's Avatar
Re: Project '86
Man, you have done way too much cool mods to even begin to comment on. You know, its maybe possible that they sent you the wrong gasket. Stuff happens in warehouse situations. I'd look at my gasket set if it weren't still boxed up and packed away.
truckzilla is offline   Reply With Quote
Old 03-16-2012, 11:09 AM   #1091
Zebb
Zebb's Avatar
Re: Project '86
I just put a windshield in my truck with a new gasket. I ordered one with the black trim. What I ended up getting was a gasket and a locking strip. Before I put it in I was confused on how the locking strip was going to work. There was only a groove on one side for the locking strip. After the gasket was installed in the truck it became clear to me The locking strip was built onto the gasket and all I had to do was insert one side to lock it in. It was kind of tedious but it went in and tightened everything up nice. So I got the locking strip for nothing.
This is the only picture I have to help describe it.
Zebb is offline   Reply With Quote
Old 03-16-2012, 11:21 AM   #1092
dv8customs
dv8customs's Avatar
Re: Project '86
That pic helps, I think I see how it works now.
I was hoping to be able to put the gasket on the truck and use that to mark the glass where it needed to be cut but it doesn't look like I will be able to do that.
Old 03-16-2012, 07:34 PM   #1093
Zebb
Zebb's Avatar
Re: Project '86
I don't think that it will work with a new gasket either. Mine was tight and didn't really go into place until the last step of the locking strip. Maybe a used gasket with a removable locking strip that has memory of being installed might be better to get the glass fit. Or possibly another truck with no glass at all could be used to set your glass in to get a visual of how it would sit with no gasket then set yours in the same and mark your cuts.
With what you have fabricated already, I don't see this stumping you for long.
Old 03-16-2012, 10:05 PM   #1094
dv8customs
dv8customs's Avatar
Re: Project '86
Old 03-16-2012, 10:13 PM   #1095
ghettoluxury
ghettoluxury's Avatar
Re: Project '86
I like!
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-16-2012, 10:36 PM   #1096
dv8customs
dv8customs's Avatar
Re: Project '86
My gauges
Old 03-16-2012, 11:06 PM   #1097
texastruckjunky
texastruckjunky's Avatar
Re: Project '86
That looks good.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 03-17-2012, 08:57 PM   #1098
dv8customs
dv8customs's Avatar
Re: Project '86
A little sheet metal
Plus this
Equals this
Old 03-17-2012, 09:09 PM   #1099
mooseknuckles
mooseknuckles's Avatar
Re: Project '86
nice work!
mooseknuckles is offline   Reply With Quote
Old 03-17-2012, 09:10 PM   #1100
VA72C10
VA72C10
VA72C10's Avatar
Re: Project '86
Love the gauges but that firewall is SICK. Really love that!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
