11-04-2012, 12:09 PM | #1076 |
Re: Project Grande Slam: Coley's Hot Rod Shop
Definitely going to consider the one piece drive shaft. Dad showed me the carrier bearing but I can't remember what it looked like.
Any ideas on my exhaust? I'm not sure if you can tell by the pictures but it runs right out behind the cab, almost directly over the top of where the trailing arm connects. Maybe 3 or so inches wide of this point.. What I'm thinking is to run a 90 straight down, then straight over and put the mufflers outside the frame rails? I'm looking at the round ones from Magnaflow. There's a little room under the bed sides there, then out and turned down in front of the rear tires. Maybe a Cuda style or 94-95 Z28 style tip? Just a flat / rectangle style, almost a Nascar look? I just want it to blend into the side of the truck, low and sleek. Not hanging down or out past the wheel any at all. Other ideas / pictures? I'm not sure I want to cut my cross member (yet anyway..)
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
11-04-2012, 12:14 PM | #1077 |
Looking at my pictures again .. What if I just offset that bend from the lower part under the cross member ? Cut it there, put a 2.25 slip on it so that would turn about 30deg OUT. That would bring it outside the frame rail, up tight and tucked. The muffler would sit in that little void area at the front part of the bed, then over and out (turned out in front of the tire) Would that blow crap all over my wheels? When I stuck my foot in my tired 255hp 3OTT ??
11-04-2012, 12:15 PM | #1078 |
67-72 parts collector,…
Do you have holes in the trailing arm crossmember for your exhaust?
11-04-2012, 12:23 PM | #1079 |
No, just stock. With a 6" or so drop, do I really need to run it that tight? (I don't know, I'm asking .. )
11-04-2012, 12:30 PM | #1080 |
No.
11-04-2012, 06:15 PM | #1081 |
A guy with a truck
...but, it sure looks better that way
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-04-2012, 07:16 PM | #1082 | |
I'm going to do it after I put the gas tank in the frame (out back) and then fab up the exhaust (running through the trailing arm crossmember) over the rearend as tight to the bed as I can and try to run it out just behind the bumper. I'll cross under the frame just after the rearend (where the frame is a bit higher in the body) so I can exit the exhaust around the new gas tank placement...In theory |
11-04-2012, 09:13 PM | #1083 |
A couple holes in the bed floor with 10 in stacks?
Well get something worked out. Posted via Mobile Device
11-04-2012, 09:17 PM | #1084 |
Yesssss!!! NOOOOO!! haha You can see what I did to mine in my build thread. Right now it stops just through the trailing arm crossmember but I think I am going to turn it up and come over the frame between it and the bed and then 45 down and turn out in front of the wheel!
-Rus |
11-04-2012, 10:48 PM | #1085 | |
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
11-04-2012, 10:57 PM | #1086 |
11-04-2012, 11:02 PM | #1087 |
C/10 junkie
Yes I do. Would those happen to be for sale?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
11-04-2012, 11:05 PM | #1088 |
That's my Pop!
11-05-2012, 12:46 AM | #1089 |
Heck of a fella!!! You're a Lucky guy. I don't have the luxury of having my pops, much less a fella who loves it as much or more than me. Lucky Lucky!!!
Posted via Mobile Device |
11-05-2012, 07:23 AM | #1091 |
10 in stacks are pretty gawdy, I would stick with 8 in stacks
Posted via Mobile Device Posted via Mobile Device |
11-05-2012, 01:00 PM | #1092 |
man the wheels look sick. Kicking myself in the a$$ after my dad I bought his truck.
11-06-2012, 04:19 PM | #1093 |
Thanks guys for the compliments. I ordered some round Magnaflows and exhaust slip joints / bends last night so we can re-route them enough to get to the muffler shop. I'm going to try and stay inside the frame rails, just run two rounds instead of the regular shape.
Dad had some Flowmaster copies put on it not too long ago. They are like new. If you know of anyone who might be able to use them, I'll have some up for sale soon. No kidding, they may have 500 miles on them (if that) and sound a lot like Flows .. maybe 44's ? Not real loud but sound really good. Let me know .. I'll post them in the For Sale as soon as we get them off.
11-17-2012, 11:18 PM | #1094 |
Any updates friend?
-Rus |
11-18-2012, 05:04 PM | #1095 |
.. Yep. Here are a few pictures. The sway bar is on, everything for the most part (except the emergency brake cable is too short) on the brakes, axle, etc is all set. I'm waiting on a little fun money to build back up then I'll get my track bar and lower shock bar from Nate.
We have the exhaust temporarily ran to the side just so we can get it to the muffler shop. I will be changing it over to 5"x22" Magnaflow round ones. (inboard, then over the axle as best we can. To finish up the back: Driveshaft - 62 3/8 we measured for it yesterday (trans tail shaft seal to pinion yolk centerline) .. the drop shortened the drive shaft about 5/8" .. Wow. Plus the fact we're going with a 1 piece now.. I guess that had a lot to do with it. Shocks - cant measure until I get the shock bar Shock bar Track bar Brackets, etc. Finish up the Em Brake cable then on to the front Once everything is mounted up and we get the bed back on I might want to add more block too. Maybe a 2" ? We'll see. It has a 1" in it now. I would like to keep my U bolt legth till we get it back on the ground, the right wheels on it, the bed back on .. just so I can sit it perfect and cut the bolts off then. Anyway .. here she is. The wheels on it are the ones for my stepper (255/45) and look a bit narrow for a fleetside. Don't worry .. they're comin ..
11-18-2012, 05:25 PM | #1096 |
Great attention to detail!
Do you still have the 5-lug rally wheels off your stepside? Maybe you can run those until you get the new front wheels. Or will they work with the big brakes?
11-18-2012, 06:05 PM | #1097 |
I thought maybe through the winter I would put the grey ones on the front of the gmc and yeah.. probably slip the rallys back on the front of the stepside.
I think my pop is going to take over finishing the stepside then well probably sell it. All it needs is interior and finish paint.. then just put together. Once I get the front Heritage the grey ones go back to the stepper. Were trying to finish both for the HRPT in June 2013 Posted via Mobile Device
11-18-2012, 06:09 PM | #1098 |
Thanks for the compliment by the way. It means a lot man.. thanks.
11-18-2012, 06:09 PM | #1099 |
Looks "okay"... :lmao: actually it's Perfect!
What calipers does that rear kit use? My Parking brake cables were to short too and I'm going to get a pair from a supplier here in B'ham. We may need the same ones? Posted via Mobile Device |
11-18-2012, 06:23 PM | #1100 |
Sup Ed! ?
Dad and I were thinking maybe we replace the intermediate cable and go with the ones McGaughys sent. Its odd your cables were too short too. You have the same kit I do (I think) Im considering the long haul in the tour. Do you want to start in Bham and meet up with Jeff and those guys? You can run with us if you want.. Posted via Mobile Device
