04-20-2016, 11:36 PM | #1076 |
Re: 1949 Chevy 3600 into a daily driver
You make really cool tables.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
04-21-2016, 09:34 AM | #1077 |
Thanks!! It is a hobby I have done for about 4-5 years.
04-21-2016, 10:34 AM | #1078 |
Busy night in the garage.
I had some help and we got the bed sides cut out for the wheel and UCA clearance and got the bed mounted. I did not anticipate removing so much material. The bedsides clear the tires now but just barely. I will probably take out a bit more to have some clearance. I will also have to remove some of the fender flange. |
04-21-2016, 09:22 PM | #1079 |
Coach, I really like those tables! Very nice. Good to have friends to help out with the heavy lifting.
04-21-2016, 09:42 PM | #1080 |
Spent a couple hours tonight finishing up the bed sides and mounting the rear fenders. Loving what I am seeing!!
04-21-2016, 11:07 PM | #1081 |
Yup that looks really nice.
04-22-2016, 01:11 AM | #1082 |
the double camber is just doper than a meth lab
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
04-23-2016, 02:18 PM | #1083 |
Thanks guys!!
04-23-2016, 10:15 PM | #1084 |
Looks great......laaayed out
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-24-2016, 09:57 AM | #1085 |
I have found myself just standing in the garage staring at him...........
04-24-2016, 10:26 AM | #1086 |
Take credit, YOU built it !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-24-2016, 10:11 PM | #1087 |
That's the best part when you bolt parts back on after bagging it. I remember doing the same thing with my 48. You spend so much time visualizing how it will/might look, that when you finally see it you keep looking to make sure your not dreaming it....ha ha
04-25-2016, 09:31 AM | #1088 |
Exactly.
04-25-2016, 06:42 PM | #1089 |
Best part about it for sure!!
04-26-2016, 10:18 AM | #1090 |
Not much photo worthy to report. Getting everything wired up. Battery will be in an old Hamm's cooler in the box. Running battery cables, etc.
Relays for my compressors are under the seat with my stereo stuff. Chasing some leaks in the air system. So far I have a couple in the fittings in the air tank, |
04-26-2016, 10:41 AM | #1091 |
That is a cool shot. No doubt you will be cruising soon.
04-26-2016, 11:30 AM | #1092 |
Hollister Road Co.
That looking pretty badass
04-26-2016, 04:29 PM | #1093 |
Leaks on your tank system are not good. Good luck! I have one on my drivers rear I can not find, no bubbles anywhere.
04-26-2016, 05:52 PM | #1094 |
The leak is between a couple fittings so I think there is hope. Tank openings are 1/2". I have a 1/2" Galvanized Street 45 degree fitting, then a 1/2" to 3/8" threaded reducer. The compressor leader hose threads into the reducer. I have a leak between the threaded reducer and the 45 degree fitting.
04-26-2016, 06:06 PM | #1095 |
I have owned a lot of bagged trucks, chasing slow leaks, like when the tank goes empty overnight for example, is a good way to go insane. I started using an engine driven compressor so empty or full, I can leave in about 5 seconds. on a couple with electric compressors I just put a large ball valve on the tank and turn it off when I get out.
the rule of leaks is: once you have a leak you have an air ride system, and vice versa. keeps me sane!
04-26-2016, 07:52 PM | #1096 |
A couple points to mention is it is critical that your air line is trimmed straight. The slightest angle can cause a leak.
Also when you insert your plastic air line into the fitting, push it in and the try to pull it toward you a couple times. This helps to seat the line. Tracing the system with a spray bottle full of soapy water helps to pin point trouble leaks. I'm sure that I'm not telling you anything new just thought I would mention it as that helped a lot with leaks I had in my air system. Looking great man... Marc
04-26-2016, 08:23 PM | #1097 |
Good points here guys as I am only on my second bagged truck. My first one had leaks at the fitting on the valve block.
04-26-2016, 09:15 PM | #1098 |
WE HAVE PRESSURE!!
Fired up the compressors tonight. Quieter than I had thought they would be. Hit 140 PSI in about 2 min roughly. |
04-26-2016, 10:09 PM | #1099 |
On my 49hardtimes (sold) I'd be lucky to get 2 days without loosing air throughout everything. I had some older viairs on there and wouldn't yah know I replaced the leader hoses with check valves. Thing filled up way faster and also little to no leaks for two straight weeks!!! So if you start noticing you are taking longer to fill up or pop fuses for your comps or have leaks, replace those leader hoses!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
04-29-2016, 09:26 AM | #1100 |
So far I just have a couple leaks between the compressors and the tank. I think if I raise the tank up a bit I can eliminate a fitting which will help.
Hopping to drop him down tonight off the jacks stands and see if I have any leaks between the switches and the bags. |
