08-24-2014, 05:25 PM | #1076 |
Re: What did you do to your truck today? Chapter II
Took it out to the car show Saturday night!!
08-24-2014, 10:46 PM | #1077 |
Looks good.
08-24-2014, 11:42 PM | #1078 |
Ordered a new Hughes rebuild kit for my TH350, including new sprags.. plus a TCI shift improver kit..
08-25-2014, 07:11 AM | #1079 |
Dan Johnston
I got my Overload springs Sand Blasted, Primed and Painted over the weekend... I also sand blasted the wheel tubs and got them in Epoxy Primer...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
08-25-2014, 03:49 PM | #1080 |
Got my headers, holeshot 2400 converter, lifters, double roller timing chain set, air cleaner, valve stem seals, hardened trans input shaft, and some other odds and ends, getting ready for the install.
08-25-2014, 10:56 PM | #1081 |
08-26-2014, 11:47 AM | #1082 |
Been a while since I've posted on here. But I got it back on the road and put it right to work. I can't say no to free firewood, especially if all I have to do is drive out my drive way and drive onto my next door neighbors property... I was in process of trying to find an affordable material for heat/sound deadener, when I was at the local 99¢ store I found these windshield sun reflectors for $1.27 a piece. Foil on one side foam the other. Bought 5. I stopped by hardware store on way home to pick up roll of aluminum foil tape for ten bux. I spray adhesive the shields back to back so foil would be exposed on both sides, and turned them into panels. I used some good stubble-sided dicky tape in the contours and corners so as not to let them lift. Then foil sealed all sides. I was about four square feet short so picked up a few more to finish the job. Turned out far better than I had predicted, also far cheaper...(I need all the gas money I can get!) I fully insulated the floor pan from firewall to gas tank for about $20! Also I got the low pile carpet for free from a friend. I'm no carpet installer, and I accept that. But it will get me by until I can afford better. It definetly keeps the cab cooler and quieter, even with my "super" 40's! Now I can actually hear my stereo.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
08-27-2014, 02:47 PM | #1083 |
I got my seat back from the upholstery shop yesterday and I set it in the truck temporary just to see how great it's going look. I ordered the seat cover from Seatz out of Anaheim, CA & had a local upholstery shop put the new cover on & installed new foam. I also included a before pic.
"Now all I need is a shop to go with my shop vac!" |
08-27-2014, 03:16 PM | #1084 |
Very nice!
08-27-2014, 03:42 PM | #1085 |
Thanks! it's been a huge transformation. And I'm still not done...lol
08-27-2014, 08:34 PM | #1086 | |
08-29-2014, 04:44 PM | #1087 |
08-31-2014, 12:00 AM | #1088 |
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
08-31-2014, 12:32 AM | #1089 |
Damn! Nice looking shop you got there!
08-31-2014, 12:36 AM | #1090 |
Nothing major, I wired up my glove box light tonight. It's all in the details right?
08-31-2014, 07:19 AM | #1091 |
got some epoxy on the cab and finally sprayed some color in the intieror.
in the 3rd pic you can see the darker green between the windsheild and dash pad(thanks sstim) next is the drip rail sealer and gonna try too start the process of getting the doors and windows jammed out in 503. oh and because everybody like before and after pic's just mine are backwards
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
08-31-2014, 11:17 AM | #1092 |
I did a nice, easy maintenance afternoon where I changed the oil, put on a new lower radiator hose, lubed/greased the front end, rotated the 2 front tires and changed out the power steering fluid and did a little underhood clean and tidy stuff. Nothing too serious.....and, well, it was actually last weekend....LOL
(note: still haven't resolved the increased power steering 'whine' tho'....) All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
08-31-2014, 04:35 PM | #1093 |
The Niner
I busted a hood hinge 10 days ago, so Wes from Classic Heartbeat hooked me up with some nice ones.
And I've been driving around w/o power brakes the last month, so I finally replaced the power booster.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
08-31-2014, 11:33 PM | #1094 |
About 32 hours later and it's a different color!!!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
09-01-2014, 10:06 PM | #1095 |
Replaced the original 45 year old upper and lower ball joints and put in a set of 2in lowering springs up front.
Erik 1969 Chevy K20 6.0L/4L80E/NP205 1971 Chevy C30 Cheyenne Longhorn 454/TH400 1979 Chevy K30 dually currently in pieces |
09-01-2014, 11:18 PM | #1096 |
Rebuilt my valve body, added a shift kit and started rebuilding the sub-assemblies in my TH350.
09-01-2014, 11:59 PM | #1097 |
Thanks.
09-02-2014, 01:08 AM | #1098 |
Finished my seat brackets and got it all in!
09-02-2014, 03:54 PM | #1099 |
Eat, Sleep, Drive a Chevy
Got the wood bolted down and the bed put on.
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
09-02-2014, 07:08 PM | #1100 |
started buffing the paint. been a long time since I've done any major buffing. forgot what a pain it can be. especially black!
