01-25-2017, 06:22 AM | #1076 |
Re: A 15 year old's project. Rusty 62 stepside
Very nice looking work. Your idea sounds good to me since they are run with a single belt in a serpentine system.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-25-2017 at 07:40 PM. |
01-25-2017, 10:42 AM | #1077 |
That bracket turned out great! I bet you'll be just fine running a single belt for the whole system and it looks like you've got room to mount a simple idler/tensioner pulley later if needed.
Keep it up! |
01-25-2017, 11:43 AM | #1078 |
Post Whore
Great job man!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-25-2017, 07:59 PM | #1079 |
Excellent work on your bracket! Well done!
01-25-2017, 10:17 PM | #1080 |
Nice job on the bracket. Looks very professional.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
01-25-2017, 11:15 PM | #1081 | |||
Thanks tj Thanks Doug Thanks Dale, but I'm far from professional, I just really took my time and put lots of effort into this piece.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
01-26-2017, 11:19 PM | #1082 |
Today I worked on making the adjustment arm. I welded these two together.
01-26-2017, 11:19 PM | #1083 |
And smoothed it out
01-26-2017, 11:21 PM | #1084 |
Then bent this little jog into the piece so it lines up correctly, then drilled a hole through both pieces and put a bolt through.
01-26-2017, 11:22 PM | #1085 |
Here it is all together
01-26-2017, 11:24 PM | #1086 |
Here is the pump adjusted all the way in.
01-26-2017, 11:25 PM | #1087 |
And here it is adjusted all the way out. Power steering pump Bracket is now completely finished.
01-27-2017, 12:22 AM | #1088 |
Bracket and arm looks good!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
01-27-2017, 11:54 PM | #1089 |
Thanks!
Today I got both the coil springs installed and then torqued the lower ball joints to spec. |
01-27-2017, 11:56 PM | #1090 |
I was then able to put the wheels on and put the truck back on the ground for the first time in months.
01-27-2017, 11:58 PM | #1091 |
And since I was already outside I just decided to drill out the plastic pins and separate the collapsable steering shaft.
01-28-2017, 10:42 AM | #1092 |
Post Whore
Bracket turned out great.
01-28-2017, 10:43 AM | #1093 |
Nice job! I might have to get you to make me one for my truck!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
01-28-2017, 01:11 PM | #1094 |
01-28-2017, 09:38 PM | #1095 | |
Thanks Tj
Thanks bill
02-05-2017, 05:36 PM | #1096 |
Well about a week ago the temperature dropped and now we're down to -10 celcius with almost one foot of snow on the ground, but I've still been making progress
02-05-2017, 05:37 PM | #1097 |
I started with working on getting the framerail near the steering box welded back in place, so first I tacked it up
02-05-2017, 05:39 PM | #1098 |
Then I fully welded it up and ground it down smooth with a flap disk, it actually looks much nicer than the factory weld seam which can be seen to the far left
02-05-2017, 05:46 PM | #1099 |
I also went to the hardware store and picked up some bolts that are the correct length, the steering box then got bolted in place for the second last time
02-05-2017, 05:48 PM | #1100 |
I then cut the pre-existing solid shaft to the correct length
