09-05-2019, 09:58 PM | #1101 |
Re: "Project Orangepeel" 52 A.D
These are a few shots of a cover I made that goes between the lower section of dash and console.
Pic 1. Template. Pic 2. Transferred to metal. Pic 3. After getting the shape I wanted I fine tuned the fit. Pic 4. Another view.
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
09-05-2019, 10:11 PM | #1102 |
Post Whore
looks good...also looks like copilot spot has been claimed
09-06-2019, 08:30 AM | #1103 |
Thanks Greg!
Yes they are my little shop dogs they go just about everywhere with me. Mark.
09-06-2019, 08:34 AM | #1104 |
What are you covering it with? I'm envious of the metal work! Looks good.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
09-07-2019, 08:46 AM | #1105 |
Well thank you very much Robert!
The entire set will be painted. Mark
09-07-2019, 01:52 PM | #1106 |
wow that looks great, great use of butcher paper for the pattern too.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
09-07-2019, 04:51 PM | #1107 |
Thanks Russ.
The product I use for making patters etc. is called Ramboard. it's used for covering floors while moving furniture. https://www.amazon.com/gp/product/B00QO1T2A8/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
09-07-2019, 07:40 PM | #1108 |
Post Whore
ramboard looks similar to the chipboard paper I use
09-08-2019, 07:39 AM | #1109 |
Had to read back a little
Nice work again Mark!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
09-08-2019, 09:37 AM | #1110 |
Greg,The ramboard is 3ft by 50ft roll so you can just cut to the size you need.
where do you get the chipboard paper?
09-08-2019, 09:39 AM | #1111 |
Thank You Kees
09-11-2019, 08:20 AM | #1112 |
Pic 1. The band all drilled .
Pic 2. The top piece drilled as well. Both of these will match the other pieces in the truck. Pic 3. After putting insulation on back of cab I made pieces for mounting the fuse panel and this will aid in mounting clips for the wiring. Mark.
09-11-2019, 08:32 AM | #1113 |
That looks good. Very nice.
09-11-2019, 06:26 PM | #1114 |
Thanks again Robert!
09-12-2019, 05:30 PM | #1115 |
beauty man! I am going to check local for some ramboard
09-13-2019, 12:53 AM | #1116 |
Post Whore
Mark..I've been getting the chipboard from a local shipping company...i also have some of what they call craft paper....the craft paper i got from a return goods sale we have at work...its on a 3ftx50ft roll...the chip board is 4x4 squares...the chipboard is .022 thick and the craft paper is .005 thick...
I've been useing both to make transfer patterns.....
09-13-2019, 08:17 AM | #1117 |
Thanks Russ!
09-13-2019, 08:23 AM | #1118 |
Greg, Yes ive used the craft paper as well. It is a bit flimsy for making some templates. The RamBoard can be bent with a sheet metal break to make a perfect template.
09-13-2019, 06:37 PM | #1119 |
Here is a pic of the Ramboard I use
It is .033 thick and as I'm showing here it bends and holds its shape reallynice. Mark
09-13-2019, 08:34 PM | #1120 |
Post Whore
That is nice....I need to find me some of that...
09-13-2019, 09:28 PM | #1121 |
Pic 1. This was just after I painted the floor with POR 15
Pic 2. The next day I was able to install the 3M insulation. Mark
09-14-2019, 12:14 AM | #1122 |
Post Whore
What 3M insulation?....
09-14-2019, 01:18 AM | #1123 |
Post Whore
Just for my curiosity I tried the chip board in my metal break....works pretty good...I'd hadn't thought about bending it in the break....that's a good idea Mark..
09-14-2019, 08:53 AM | #1124 |
I get it at our local paint store (colorvision) ill see if I can get the part # for you.
they come in 19x19 sheets and very sticky. a box of 10 sheets is $78 and you can by them a sheet at a time as well. Mark
09-14-2019, 09:27 AM | #1125 |
here is a shot of the insulation at my shop.
The link from Amazon is exactly the same stuff. A box of 10 is $89 so a bit more expensive.
