Old 01-15-2011, 11:27 AM   #1126
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: "Rice Rocket'
If you want a different speedo cable PM me your address, I won't be needing mine
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-15-2011, 02:46 PM   #1127
67chevy1series
67chevy1series's Avatar
Re: "Rice Rocket'
well it looks nist and cozy in there ,im taklin about the dash bezel!
67chevy1series is offline   Reply With Quote
Old 01-15-2011, 04:55 PM   #1128
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: "Rice Rocket'
Not sure if I need a speedo cable or not yet. I think the end that goes onto the trans is stripped. But not sure.
Dont throw yours away usmcchevy, I'll buy it from you if I turn out needing it, thanks! I still envy your LS build
John
1999 Toyota Tacoma 4x4
Old 01-15-2011, 05:00 PM   #1129
67chevy1series
Re: "Rice Rocket'
ls 's are cool but no matter how hard you try and old skool small block 327 or 283 with the factory orange looks awsome!!!!!!!!
Old 01-15-2011, 05:21 PM   #1130
oldblue1968chevy
Re: "Rice Rocket'
I dunno, check out the holly shop truck they made it look pretty retro and its LS lol
John
Old 01-15-2011, 06:43 PM   #1131
67chevy1series
Re: "Rice Rocket'
ya but the script vavle covers and the intake they can never make it look like those although if i had to have a ls i would make it match the holley shop truck
Old 01-15-2011, 06:49 PM   #1132
oldblue1968chevy
Re: "Rice Rocket'
Did you see the Holley truck?
Ok, I need help. Im trying to get my speedometer working again. Its screwed into the back of the bezel and I screwed/unscrewed/screwed it into the trans (3 spd man.) Backed thet truck up, and moved it forward it still doesnt work. Soo whats wrong?
And I also sorta kinda fixed my hood (sticking way up in the back) I adj. it and it looks 'better' but not much the gaps are really close and I had to SLAM the thing to get it closed all the way...
Looking at my bezel cruising down the road does make me smile though
John
Old 01-15-2011, 06:53 PM   #1133
67chevy1series
Re: "Rice Rocket'
let me guess you un tightened all of the bolts for the hood hinges and pushed it up and then tightened it up then colsed it and your gaps were better right? i did the same thing .
2cnd the dash looks great and my dash is probably the only good looking thing in my truck lol
3rd i have no idea what would help you except maybe get a new cable
Old 01-15-2011, 06:56 PM   #1134
oldblue1968chevy
Re: "Rice Rocket'
Haha, my grandpaw said today while riding with me to get groceries, that if only the rest of the truck looked that good
Yah, It pulled the back of the hood down, but 1 hinge the rivits are really sloppy. I didnt really 'fix' it, I just made it a little better, now I cant close it without jumping up and putting my fat butt on it to close it
John
Old 01-15-2011, 07:00 PM   #1135
67chevy1series
Re: "Rice Rocket'
hahhaha you aint fat!!!! you are skinny! like me!!
Old 01-15-2011, 10:26 PM   #1136
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
have you checked the drive and driven gears in the trans? the driven gear is broke on mine thats why my speedo don't work. Take the cable loose at the trans and spin it with your fingers while somebody looks at the speedo it should move some if it does your problem is probably somewhere else
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-15-2011, 11:48 PM   #1137
jbclassix
Junk Yartist
jbclassix's Avatar
Re: "Rice Rocket'
another place to start with your speedo is...
remove your bezel again,
leave your speedo cable out where you can see it,
drive around and see if the cable spins,
if yes, then stick a small flat-tip bit in a CORDLESS (you want it to turn slow) drill and spin the back or your speedo to verify the speedo itself is bad.
if no, remove the cable from the adapter on the trans,
use a small flat-tip screwdriver to see if the drive spins (if it does the problem is in your tranny)
You can hook your speedo back up and use a chordless drill again with the transmission end chucked LIGHTLY and run it to see if the cable is not broken. Usually if the cable is broken, tugging on each end will pull out half of the broken cable.
Hope I didnt confuse you.
Something to note... your speedo will only work spinning it CCW from the back... the same way the needle travels, you can spin it CW from the back but it will not do anything.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-16-2011, 01:40 AM   #1138
oldblue1968chevy
Re: "Rice Rocket'
I"ll try all of this tomorow, thanks for the info guys!! I think have a few bad bulbs also, 1/2 the gas guage is illuminated and 1 turn signal doenst flash (only on the dash, the actual turn signal still works)
John
Old 01-16-2011, 01:48 AM   #1139
67chevy1series
Re: "Rice Rocket'
man you are a big time slacker on pics only when you have done somthin you take pics we need more random shots or full truck shots
Old 01-16-2011, 02:00 AM   #1140
oldblue1968chevy
Re: "Rice Rocket'
Ha, the only reason this thread is at the top alot is because me and you (rick) bs back and forth haha
I'll take pictures of stuff with the nice camera tomorow, or the next day its warm i'll wash it (probably carwash to get salt off)
John
Old 01-16-2011, 02:05 AM   #1141
67chevy1series
Re: "Rice Rocket'
that sounds good john , i have to say ,I LOVE BSÍNG WITH YOU
Old 01-16-2011, 09:10 AM   #1142
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
Originally Posted by oldblue1968chevy View Post
Ha, the only reason this thread is at the top alot is because me and you (rick) bs back and forth hahaI'll take pictures of stuff with the nice camera tomorow, or the next day its warm i'll wash it (probably carwash to get salt off)
True
It now looking to good around here for warm weather i haven't got to wash the salt off my DD from the christmas snow yet
Proverbs 3:5,6
Old 01-16-2011, 12:03 PM   #1143
jbclassix
Junk Yartist
jbclassix's Avatar
Re: "Rice Rocket'
before you replace the bulbs bend the little tabs out a bit and make sure the copper contacts on the printed board are clean...
-Jeremy
Rebuilding an NP205
Old 01-16-2011, 01:48 PM   #1144
67chevy1series
Re: "Rice Rocket'
i am probably gonna need to do this as well
Old 01-17-2011, 06:35 PM   #1145
67chevy1series
Re: "Rice Rocket'
well john anything new goin on
Old 01-17-2011, 10:15 PM   #1146
oldblue1968chevy
Re: "Rice Rocket'
Nothing much, need to be fixing my speedo and parking brake cables
Maybe some new misc easy upgrades to come this week...Idk yet
John
Old 01-17-2011, 10:56 PM   #1147
67chevy1series
Re: "Rice Rocket'
well lets hope so!
Old 01-20-2011, 11:40 PM   #1148
67chevy1series
Re: "Rice Rocket'
well it seems john is abandoning this thread so i stole one of his pictures from today!
Old 01-20-2011, 11:52 PM   #1149
oldblue1968chevy
Re: "Rice Rocket'
Gee lol
Update Update Update!
USMCCHEVY sent me a speedo cable (This place has some very remarkable people on it!) I received it today! Its snowing AGAIN! So im going to build a fire tomorow and tinker with speedo and guage lights or something tomorow..Special thanks to usmcchevy 2manyprojects va72c10 and probably a few others. Place is a great!
Thanks to ricky for always keeping my thread at the top
John
Old 01-20-2011, 11:54 PM   #1150
67chevy1series
Re: "Rice Rocket'
thanks john! yes 2 many projects is the man i havent delt with va72c10 and usmcchevy but if i do i will now know that they are good to delt with
