Old 11-27-2012, 06:16 PM   #1126
nlped
nlped's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
Personally, I'd open up the hole a little bit, you haven't painted it or powder coated it yet, right? Bigger bolt=More strength in my opinion, and you sure don't want the shock eye having play in it, it'll rattle I'm sure.
And I'm very curious as to your "fix" for the parking brake cables. I was just going to move that bracket back closer to the rearend too, but my problem is the dang cable that came with my kit has a spring on the actual cable (looks to me like a drum brake parking cable) that when installed on my caliper it is completely compressed and theres no movement left in the cable to actually articulate the parking brake mechanism on the caliper... does that make sense?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-27-2012, 08:52 PM   #1127
lolife99
67-72 parts collector,…
lolife99's Avatar
Does Nate use a shock specific stud on his upper and lower bars?
Keith
Convert to disc brakes.
Old 11-28-2012, 08:31 PM   #1128
CC69Rat
CC69Rat's Avatar
Not sure really (?) I just want to be sure before I drill it. I think the ones I have are slightly larger than the ones in the picture above. They look beefier ..
We'll get it figured out. I found a guy on the forum (THANKS Gringo!) with the lower shock bar and brackets possibly for sale. We'll see how it works out and I might save a few bucks. I'm in no hurry, the truck is probably down for a couple weeks anyway.
Dad and I spent the majority of the day today stripping the front stuff out. We have everything apart now, just cleaning and detailing. Maybe this weekend (supposed to be in the 70's here on Sat / Sun We can paint and start bolting things back up. I'm just doing stock arms for now. If I keep the truck, and / or LS3 in the future I will do PB arms upper and lower, front and rear.
Here are a few pictures from today. The door is only about 1/2 latched. Dad is cleaning up the rockers and we're going to re-spray them. The weatherstripping is pulled back just a little and we just don't want the door to sit fully closed and mess up the rubbers. The rear is all but finished. Shocks, lower bar, brackets, trackbar and we can put the bed back on. .. just waiting on my money tree to bloom again.
Anyway, here's the front.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 11-28-2012, 08:34 PM   #1129
CC69Rat
CC69Rat's Avatar
Mais Um..
Chad
Old 11-28-2012, 08:36 PM   #1130
CC69Rat
CC69Rat's Avatar
Oh, by the way .. the wheels/tires underneath are only extra caution. (My old 6 luggers) The truck is not sitting on the tires, there are stands under it and a jack under the cross member.
Chad
Old 11-28-2012, 09:00 PM   #1131
nlped
nlped's Avatar
Lookin good. I did the same stuff up front too. I went ahead and replaced the brake lines at the same time since I had to replace the m/c & p/v too. Best time to do it, considering the 40+ year old lines.
Tell me about the brake cables.
Carter
Old 11-28-2012, 09:09 PM   #1132
CC69Rat
CC69Rat's Avatar
Dad is taking pictures now.. will post in a few.
Chad
Old 11-28-2012, 09:13 PM   #1133
nlped
nlped's Avatar
If y'all are gonna be working on it Saturday, maybe Kim & I could swing by and check it out?
Carter
Old 11-28-2012, 09:28 PM   #1134
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
When you think about it you have to be crazy not to run all new line with all the money you have tied up. I used stock brake parts and still had new hard lines run.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 11-28-2012, 09:29 PM   #1135
CC69Rat
CC69Rat's Avatar
Yeah man! You both are welcome anytime. Ill be there all day. Come on up.
Chad
Old 11-28-2012, 09:56 PM   #1136
CC69Rat
CC69Rat's Avatar
Ed, here's a picture of what we did. Where you see the red arrows, those are the original mounting holes. (where the rivets used to be) From the back side of the trailing arm, I just knocked those out and got the brackets off.
Originally the bracket is facing the other direction. To make the angle of the bracket vs. the line itself more suited for the fact the trailing arms have been raised a little, the rear McGaughy's lines are a bit shorter, etc. We just moved the bracket back 6.75" (center of the original hole to the center of the new hole) and flipped it around the other direction.
Also, .. the intermediate brake cable was replaced. Dad picked up some steel cable and ends which worked great, but it has too much strech in it. As soon as we pulled the brakes a couple good times the cable just keeps streching out. We're going to re-do that intermediate cable with something different.
It needs touched up. You can still see where the original bracket was and the rusty powder stuff is just from drilling through the trailing arm.
I know, the sway bar needs to move back about an inch .. I'll fix it.
Chad
Old 11-28-2012, 10:29 PM   #1137
nlped
nlped's Avatar
That's kinda what I intend on doing too. But I need to see the other end at the caliper. That's where my issue is right now.
I think I'll just see it in person on Saturday. I bought a new Harley and have convinced Kim that chatanooga would be a good day road trip
Carter
Old 11-28-2012, 10:39 PM   #1138
shawno72
C/10 junkie
shawno72's Avatar
Looking really good Chad. Can't wait to see this thing on the ground.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-29-2012, 12:43 AM   #1139
Graham57a
Graham57a's Avatar
Very nice, what are the plans for the wheels? Find two more billet specialties just like the rears?
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 11-29-2012, 07:57 AM   #1140
CC69Rat
CC69Rat's Avatar
I have another wheel to go on it. The ones on it in the pictures are the ones I have for my stepside. I bought the two Heritage wheels that Stiney had for sale a while back. ( in a couple of the earlier pictures)
Chad
Old 11-29-2012, 10:35 AM   #1141
67cheby
67cheby
67cheby's Avatar
looking great man, nice progress !
67cheby is offline   Reply With Quote
Old 11-29-2012, 12:18 PM   #1142
Graham57a
Graham57a's Avatar
So you plan on running the wheels off the stepside??
ANDREW
Old 11-29-2012, 12:42 PM   #1143
CC69Rat
CC69Rat's Avatar
Billet Specialties Heritage.
I'll have to put my front ones (Dagger - G ) on for a couple weeks until my front Heritage arrive. I only have two right now.
(Big brakes up front .. )
Chad
Old 11-29-2012, 06:19 PM   #1144
superflysteiny
superflysteiny's Avatar
Nice wheels
superflysteiny is offline   Reply With Quote
Old 11-29-2012, 08:01 PM   #1145
CC69Rat
CC69Rat's Avatar
Man, I cant wait to see them mounted.
Its going to make the whole truck.
Chad
Old 11-30-2012, 02:40 PM   #1146
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looking good, nice progress!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-30-2012, 03:09 PM   #1147
CC69Rat
CC69Rat's Avatar
Hey -- thanks Nate
Ed, you gonna ride up?
Can anyone tell me if these upper arms will work as a 63-70 stock replacement? My concern is I bought the spindles for 63-70 style balljoints. What I don't want. is the balljoint in these arms to be different than what I need for my spindles. I just want t odouble check that everything would match up.
http://www.summitracing.com/parts/cl...del/c10-pickup
Just curious really right now. .. I'm considering tube arms for my GMC. Any opinions on CPP control arms?
thanks.
Chad
Old 11-30-2012, 03:14 PM   #1148
Rusbuilt
Rusbuilt's Avatar
You would just need to be sure you have 63-70 ball joints installed in those arms.
Rusbuilt is offline   Reply With Quote
Old 11-30-2012, 03:15 PM   #1149
lolife99
lolife99's Avatar
You should be able to get the in whatever balljoint you need.
Keith
Old 11-30-2012, 03:58 PM   #1150
original-71
///Relaxed Atmosphere
original-71's Avatar
put them on anyways without the tires take a picture for us then put them back in the box looking by the way.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
