08-04-2014, 07:46 PM | #1151 |
Re: 1963 C-10 in NC
PS, I have some of the chrome hub caps if anyone wants to trade for the white ones. I have two NOS white ones and I would trade for of the chrome ones for ones in good shape, other wise I am going to paint the chrome ones with rattle cans, or powder coat.
1963 Chevrolet C-10 "Ginger" 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
08-04-2014, 08:05 PM | #1152 |
"Where were you in '62?"
Re: 1963 C-10 in NC
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
08-04-2014, 09:52 PM | #1153 |
Re: 1963 C-10 in NC
My buddy craig will paint the body. Ill prep & prime. I dont mind small projects, but hes equipped for it and has far better skills. I use basic tools and alot of labor. Its not as bad as it seems if everything goes as planned.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-04-2014, 09:54 PM | #1154 |
Re: 1963 C-10 in NC
1/2 ton caps? How bout some pics?
08-05-2014, 08:34 AM | #1155 |
Re: 1963 C-10 in NC
Got a few more hours in on stripping the cab. Focused on the dash tops, which are done. Still need to pull the column to do the area around that, but more tonight. So far so good.
08-06-2014, 09:42 AM | #1156 |
Re: 1963 C-10 in NC
Got a few more of prep done inside the cab. Just need to pull column and hit the face of the dash up around it. Rest of cab is stripped, sanded or scuffed for paint. Wiped acetone to clean until I had clean white towels....so we're getting closer to paint. I need to get some primer on the bare metal tonight so I don't get any surface rust starting. I'll pull the glass when we spray, but tape it up for primer.
Green scour pad with acetone took care of the harder to hit places and a stripper disk on the grinder for the big areas. Would have been easier with the windshield out, but its doable with the glass in.
08-06-2014, 09:43 AM | #1157 |
Re: 1963 C-10 in NC
Couple more
08-06-2014, 10:35 AM | #1158 |
Re: 1963 C-10 in NC
What color are you going with?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
08-06-2014, 10:39 AM | #1159 |
Re: 1963 C-10 in NC
Pepsi blue...same as my rims. will do some white two tone inserts
08-06-2014, 05:07 PM | #1160 |
Senior Enthusiast
Re: 1963 C-10 in NC
What a miserable task. I can't remember any prep job harder than the inside of my cab. Glad to see you have it mostly behind you.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
08-06-2014, 09:14 PM | #1161 |
Re: 1963 C-10 in NC
exactly what I'm doing currently. behind the tank are is giving me a fit though. too much dirt and little nooks and crannies
08-06-2014, 10:10 PM | #1162 |
Re: 1963 C-10 in NC
Im going to do a spray in liner behind the tank. Got everything masked off and a light coat of primer down before gun crapped out. Its leaking, and not a very expensive gun, so ill replace it.
But got enough down that surface rust shouldnt be an issue
08-06-2014, 10:12 PM | #1163 |
Re: 1963 C-10 in NC
And the funnest part of the cab is I have to do the fleetside too and its got 2, maybe 3 coats of paint
08-06-2014, 10:20 PM | #1164 |
Re: 1963 C-10 in NC
Guys, y'all are making me rethink doing my interior!! At least my dash is completed.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
08-06-2014, 10:28 PM | #1165 |
Re: 1963 C-10 in NC
Its not that bad, and it'll look great when done. No more nc summers in gloss black w/black bench seat
08-06-2014, 10:40 PM | #1166 |
Re: 1963 C-10 in NC
Also got the last fitting in to plumb the factory gauge to the block in stainless -3 an line. The cluster still looks great from the restore 3 years ago, so I used a spare for mock up. I just got a factory gauge and tach set for the fleetside too, so it'll be easier to do the same conversion and plumbing with all the part #s figured out
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 08-06-2014 at 10:45 PM. |
08-07-2014, 12:34 AM | #1167 |
Post Whore
Re: 1963 C-10 in NC
ooooh hooo hooo...yes indeed....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-07-2014, 10:01 AM | #1168 |
Re: 1963 C-10 in NC
Cool! Can't wait to see it done.
08-07-2014, 10:09 AM | #1169 |
Re: 1963 C-10 in NC
08-10-2014, 02:43 PM | #1170 |
Re: 1963 C-10 in NC
Rain the last 2 days. But finally got 2nd coat of primer done. Will do doors this week and hopefully some color this weekend
08-11-2014, 12:18 AM | #1171 |
Re: 1963 C-10 in NC
Great work on the interior. It's a lot of hard work but with great dividends.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
08-11-2014, 01:05 AM | #1172 |
Re: 1963 C-10 in NC
+1 to what PDX said. It's looking great.
08-11-2014, 08:20 AM | #1173 |
Re: 1963 C-10 in NC
Thanks for the kind words guys. The encouragement always helps. I got lucky to find no upper cab issues rust or dent wise. The fleetside has around 30 holes drilled by the PO for every bolt on option he could think of and some speaker grill work, so may just swap in a new dash there.
I haven't sprayed a whole vehicle in almost 20 years. Lots of little stuff, an engine or two and tons of small panels, but I'm really considering doing the color inside the cab. I may let my buddy do the clear, but on the same token....whats the worst that could happen. A few runs and some sanding? So maybe I'll just spray the interior myself.....we'll see. Either way, I want some color this weekend. Will get the doors and jams knocked out this week. POL mounts are here, the headers were shipped Friday....so should see them in a few days. So....finish cab this week. My help will be back this weekend, so engine/trans back out next week and should be a fairly quick reswap on the mounts and headers.
08-11-2014, 10:27 AM | #1174 |
Post Whore
Re: 1963 C-10 in NC
Keep up the good work.
08-11-2014, 02:30 PM | #1175 | |
Re: 1963 C-10 in NC
