Closed Thread
Old 12-14-2010, 10:18 PM   #1176
trkfrk
trkfrk's Avatar
Re: What did you do to your truck today!
I machined my front rotors to fit my Boss 338 wheels.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline
Old 12-15-2010, 04:37 PM   #1177
Garthc20
Garthc20's Avatar
I installed a new grant steering wheel, now I have a horn that works! It was kind of interesting to do it without a puller. I ended up putting the big nut under the wheel and using the three small outer bolts to pull it off the spline. It just makes me feel better with a horn to let people know I'm here! Also got a new stool for my garage and stuff to do an oil change
1970 Custom camper 20 lwb
1978 yamaha xs1100
(insert clever quote here)
Garthc20 is offline
Old 12-15-2010, 04:45 PM   #1178
scooterskoolkustoms
scooterskoolkustoms's Avatar
Damn started the truck and found water in my oil,no what i have oil in my water.anyway pulled the heads and found a set of thin metal head gaskets with water leaking in # 6 and 8 cyl.so I'm off to buy a good set of head gaskets and put her all back together again.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 12-15-2010, 06:46 PM   #1179
Hubscrub
Cruzin
Hubscrub's Avatar
looked out the window at it to see how much ice has accum. on it
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 12-15-2010, 07:29 PM   #1180
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Originally Posted by Kidd-7 View Post
Here are some links I've found about the QJett:
http://www.florida4x4.com/tech/quadrajet/
http://www.carcraft.com/howto/57178/index.html
I'll be doing this soon; let me know if this helps.
Thanks for those. I'll have to spend some time going through those. I'll let you know if I find anything that does help.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline
Old 12-16-2010, 01:27 AM   #1181
60ratrod
yes, i do
60ratrod's Avatar
i hauled out the old motor on my own in about 3.5 hours. not too bad for doing it myself. but then again that isn't totally consecutive. i had to stop to get my wife's cat from the vet, my daughter from daycare, and then run back to the parts store to get hyd fluid for my cherry picker
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 12-16-2010, 02:36 AM   #1182
nickp51chevy
At least it was wormish for ya.
Had;
Old 12-16-2010, 02:52 AM   #1183
60ratrod
yes, i do
60ratrod's Avatar
Yeah, but it started raining when i had to stop cause the ram on my hoist ran out of oil and get more. And what was worse is i had to set the motor down with out being bolted in to service the ram
60ratrod is offline
Old 12-16-2010, 05:36 AM   #1184
swamp rat
swamp rat's Avatar
Well now that you mentioned the cat, daughter and the hydralic fluid run i guess 3 1/2 hours isn't too bad. When i pulled my engine back around 95 i had the fluids, fan and radiator out in about 30 min, then went to get a cherry picker, brought it home and had the engine out and the picker back in about an hour.. Oh to be young again! LOL!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 12-16-2010, 05:39 AM   #1185
Rustybaggs
While deployed....I once again spent my time off researching the c*#p out of this forum....it just never ends. There are so many different threads and different ideas that I'm now confused on were I want to go with my 67 stepside once I return.
Ohhh, and my wife gets a call saying "the truck is an eye soar" sitting in the driveway......some people just don't get it.
Rustybaggs is offline
Old 12-16-2010, 12:37 PM   #1186
60ratrod
yes, i do
60ratrod's Avatar
both times that i pulled a motor out of this truck i never removed the rad. always managed to clear the rad and core support just fine. i just wish i didn't have to pull the hood to get the motor out though
60ratrod is offline
Old 12-16-2010, 12:52 PM   #1187
dan76
Thanks for your service.
Suggest you get a truck cover sent to your wife so she can cover it. Not only does she not need "nosiness" from the neighbors, but if it's unregistered/uninsured someone may call the code enforcement folks and they'll start hassling her. If it's covered, they can't look under the cover for a current license. The cover will also help protect the truck from folks with sticky fingers from lifting parts.
Good luck and come back safe.
dan76 is offline
Old 12-16-2010, 06:57 PM   #1188
mcmlxix
Collector of Projects
mcmlxix's Avatar
I found out my rear axle is worn out.... probable never serviced.... so I started looking for a 14BFF ... Go big or go home, right?
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 12-16-2010, 08:11 PM   #1189
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
put in a new vacuum advance in my distributor. 10 mins. next, torque converter...hopefully only 2 or 3 hours.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline
Old 12-16-2010, 08:18 PM   #1190
imholte
imholte's Avatar
Put in a new starter. Could have done it last summer when I knew it was getting tired, but I figured it would be better to wait till it was 30F outside to do it.
Starts perfect now.
72' Custom10 4wd 350: Daily Driver
imholte is offline
Old 12-17-2010, 03:29 AM   #1191
ItsRandy
ItsRandy's Avatar
I picked up my new 4l85E today. Now I can get started on my project. Had to wait until I had all of the big parts before tearing my truck apart (ZZ502, 4l85E and a Strainge 9" with Wilwood brakes).
ItsRandy is offline
Old 12-17-2010, 10:25 AM   #1192
60ratrod
yes, i do
60ratrod's Avatar
Starts perfect now.
doesn't it always seem like a good idea?
60ratrod is offline
Old 12-17-2010, 02:24 PM   #1193
67Slider
67Slider's Avatar
Finally got to start working on my bed wood again. It's been a couple of weeks and I havent got to do anything but fire her up for a few minutes. Sanded down the bottom side and put on the first coat of Spar Urethane. Hopefully it dries enough today that I can put another coat on tonight. Got two more coats to go then I can start on the top side.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 12-17-2010, 03:00 PM   #1194
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
It's raining and dreary here today. Made a trip into town yesterday and got an early BD present from the Boss (wife). She had already ponied up $200 of the $400 for the front and rear window purchase/install.
That was supposed to be it. But when she saw me pawing a Craftsman polisher (for the interior I painted a few weeks ago), she "insisted".
Nice.
So, today, I'm staying under the roof next to the wood stove.....and reading the Forum.
Let's see if I can find some kind of pic that's related to this post.....Thanks for the polisher, Woman!!!! (Just in case she reads the Forum today )
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 12-17-2010, 03:59 PM   #1195
legendary
legendary's Avatar
See above...and thank you for your service
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline
Old 12-19-2010, 03:56 PM   #1196
glider_6969
Today I put in, the radio, antenna, which is hidden under the cowl, I filled in the hole on the cowl during the body work, wanted a cleaner look. The wipers back on,, washer pump wouldn't work so I put in a universal one under the hood.: 68gmc2:
glider_6969 is offline
Old 12-19-2010, 04:04 PM   #1197
67chevy1series
67chevy1series's Avatar
did a little painting hope to make my truck like this
67chevy1series is offline
Old 12-19-2010, 05:04 PM   #1198
sjarrett71
sjarrett71's Avatar
Nothing to the truck but installed a new connecting rod in my air compressor. No I've just gotta fill it up with oil and get my electric routed and I'll be in air tool heaven!
-Scott-
sjarrett71 is offline
Old 12-19-2010, 05:43 PM   #1199
tex_waco_usmc
Project Heaven in my 67!!!
I did the same exact thing, being as I am deployed to the Stan right now as well. I am thinking (after all my extensive research) that after completing Project Heaven I am going to try and do all the work on my 68 by myself...Engine/drivetrain were never the issue but I am going to dive into rust repair and paint myself this time to save the STUPID amount of money I spent on Heaven! LOL
tex_waco_usmc is offline
Old 12-19-2010, 07:02 PM   #1200
67Slider
67Slider's Avatar
Sanded down the tops of the bed wood. I will put on the first coat of urethane tonight. Bought my wife a set of american racing wheels for her mustang. Should be worth some points for chevy parts.
[IMG][/IMG]
and here is the boy with the bed wood. He would rather work on the truck than hang with his friend across the street. Good times!
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Closed Thread
