05-15-2016, 01:31 PM | #1176 |
Re: 48 Burb, bagged, 5.3, 20 year wait
Wow those do look really slick Doug I will need to track a set down for my future exhaust setup for sure
"Orange Crush" |
05-15-2016, 01:40 PM | #1177 |
You're a handy guy Doug!!
Exhaust is going to look great! Nice clamp, never saw those before unfortunalty....
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
05-16-2016, 05:37 PM | #1178 |
Nice looking exhaust. I'm not sure but I think your exhaust hanger might catch fire.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
05-16-2016, 08:20 PM | #1179 | |||
Mufflers are on order from Jegs....thinking the run might get too long to make the 90 turn to the outlet. Canning the X would simplify this, though am going to try to fab it out to fit. |
05-17-2016, 08:36 AM | #1180 | |
05-20-2016, 12:14 AM | #1181 |
SAVING ONE TRUCK AT A TIME
Progress is looking great.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
05-20-2016, 08:25 AM | #1182 | |
Thanks Chizzler. Kinda slow though some progress. The mufflers came in and hope to see about fitting them up tomorrow. Spring here has been so wet there has been zero planting done. One of my neighbors has his equipment ready to go as soon as the fields dry up enough for working. Iowaboynca, I took this pic just for you. |
05-20-2016, 11:11 AM | #1183 | |
great detail work!
here is a great comparison, apple to apple, same car with same mufflers and differing only in x and h pipe.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-20-2016, 06:39 PM | #1184 |
Thanks joedoh. The 56 has the X pipe and I like the sound. Even though there will be variance on the Burb with much shorter pipes after the mufflers, I am looking to somewhat duplicate the sound.
An H pipe is next up if the X doesn't work out. |
05-22-2016, 08:31 PM | #1185 |
OK, the X pipe set up fits.
The patent pending exhaust support system was moved back to support muffler placement. Welder series header collector flanges were used to connect the exhaust tip and flex pipe. Same for the 90 muffler exit pipe to the other end of the flex pipe. Thanks again to Bob and Marc for the flex pipe suggestion! One of the pics shows layout to determine where to cut the 90. And I forgot to include the flange thickness, so I had to cut it again. Right side is positioned and tacked together. Somehow I didn't order enough flanges, so hopefully they will be here this week. Then I can finish the left side. Once finalized, some of the connections will be welded and some secured with band clamps to facilitate any future removal. Then a couple hangers and it should be good to go. |
05-22-2016, 09:53 PM | #1186 |
Doug
The exhaust looks fantastic...Nice work. Hey in looking at your pics you might want to add a flex joint closer to the headers. I added mine after I noticed I was getting welds breaking from stress cause by movement. My exhaust system in the 48 is all SS and SS can act weird when heated and cooled. I actually have my tips with a rigid mount. I tied to have them with movement like yours but my tips would bang against the opening in the running boards. especially because like you I kept the tip opening as small as possible. Just my 2 cents, you know what your doing. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-22-2016, 10:01 PM | #1187 |
Looks great Doug. Giving me ideas!! Love it!!
05-22-2016, 10:22 PM | #1188 |
Thanks Marc and Coach! Me know what I am doing? Naw, making it up as I go and using what I learn here...and I am always way open for advice and suggestions.
Marc, the tips are bolted solid in the mounts in the running board. The rest of the system from mufflers forward is the same as I used in the 56 and it hasn't had a problem with cracking. Could be because the Pypes is 409 stainless rather than the 303? Appreciate the heads up! Here is a pic of a really nice one I found today in a thread. this one is a lot cleaner installation than mine. |
05-23-2016, 12:16 AM | #1189 |
way to go idaho!
05-23-2016, 09:51 AM | #1190 |
Looking good Doug..
For future reference Speedway has flanges for around $6 each (nothing wrong with Hortons stuff Ive used his stuff in the past, very nice quality) Speedway you usually get the next day and you can get the gaskets from them as well. A bit less money and time to get the parts (My 2 cents) Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
05-23-2016, 06:06 PM | #1191 | |
Thanks joe...made me
05-23-2016, 10:03 PM | #1192 | |
The funny thing is this was my exhaust version 1.0 In 2.0 I added a small SS brace that bolts to the running board mount to keep the exhaust tip from rattling against the running board. In version 3.0 I added flex joints and I changed the flanges on my exhaust to better match my headers. Third times a charm. Thanks Marc
05-24-2016, 07:59 AM | #1193 |
Exhaust is looking really good!
Don't see something wrong with it? I like that place for an outlet.
05-24-2016, 08:01 AM | #1194 |
Nice job Doug you got all that to fit together really nice in such a tight place. I cant wait to hear how it sounds. It took some time but I really like your under running board exhaust. Nice touch.
05-28-2016, 01:25 AM | #1195 |
Hey Doug.
I was finally able to make it through all 48 pages of your thread. What a great build! You've done a lot of great work! Your exhaust looks great! I am starting mine tomorrow and hope it comes out as good as yours did. Thanks for spending all the time to document what you have been up to. Dave
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899 |
05-28-2016, 10:48 PM | #1196 | ||||
OK, it won't win a Riddler award, though it should be good enough for this old Burb. I don't like the regular style exhaust clamps and yet need to use them on the muffler as the exhaust bends too close to it to use a band. There are exhaust bands at the slip joint behind the downpipe extensions to make disassembly easier. The butt weld at the down pipe to the extension and the slip joints going into the X pipe will be welded. And the flanges at the flex pipes need welding too. |
05-29-2016, 09:08 AM | #1197 |
Looks great Doug, this should work....
I need to get my x member out to of the attic that I had made for the 48 and see if I can use it for the Suburban...Something tells me it wont but I'm due for a break soon.... Marc
06-05-2016, 08:38 PM | #1198 | |
Just a side note, the 35 Master coupe I sold just over a year ago is on the road. Owner texted me this. I told him I changed my mind and would gladly refund his money. |
06-05-2016, 08:45 PM | #1199 |
So once the exhaust was done I threw the body back on the frame to make sure the tank brackets would fit. Yes, the tank filler pipe will have enough room.
Notice the new shop rollers? The uni-lugs were ugly and a pita to put on. |
06-05-2016, 08:47 PM | #1200 |
Loaded up...
