#1201 |
Re: What did you do to your truck today?
Bought a 84 half ton front clip to swap over the suspension
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
#1202 |
Redneck Hillbilly
Sadly; nothing. It pains me to think of her sitting lonely out in the shop. But for me tomorrow is Saturday and the first thing on my list is to get a new SD card and "borrow" my wife's digital camera, then go take a bunch of pics of her (the truck). Then I can begin the tear-down for the rebuild she so very deserves.
#1203 |
one suggestion to go along with the camera, BUY A HIGH QUALITY 200 PAGE NOTE BOOK TO MAKE NOTES IN. The best thing I ever did.
http://s1299.photobucket.com/user/jb...23904108567829 |
#1204 |
Redneck Hillbilly
Sounds like something I ought to do. I usually end up with a bunch of those 3x5 size notebooks packed ful of stuff, a single full size would be a lot easier to keep track of.
BTW, today I got to strip all the junk off of my 327, and got the heads off as well. Not as bad as others I've started with, but not great either. Should work just fine. Got the SD card too, so more pics are on the way in my build thread. Last edited by fryer1979; 04-30-2010 at 01:16 AM. |
#1205 |
Senior Enthusiast
Another suggestion if you're computer friendly, is to convert that information into a computer spreadsheet. Particularly the brand name and part numbers of any components you install. I have a 7 page Excel spreadsheet with all the specifications, part numbers, suppliers, part applications, etc for my truck. I've included everything from the alternator bracket to the smog valve. It sure makes it easier years later when you're trying to remember what that part originally came from. It's also an easy way to keep a running total on how much you've invested, if this is something you actually want to know!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 04-30-2010 at 02:01 AM. |
#1206 |
Redneck Hillbilly
Well, I've always grown up under the philosophy that you NEVER add up the receipts. Something I picked up from the guys who brought me up under the wrench. I do like the idea of keeping track of where everything came from though, but I'm afraid that spreadsheets are a bit beyond my abilities with a monitor and keyboard. I usually keep most of that information in my notebooks anyway, thanks for the suggestion.
#1207 |
Installed my Camaro IROC rear sway bar and added an other coat of paint to the inside of the bed.
#1208 |
Somehow that doesn't surprise me in the least.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#1209 |
spent $80.00 at home depot to put my bed together. I will have pictures when I am done. Stay Tuned!
#1210 |
Used my '66 to pick up a customer's '66.
#1211 | |
I started doing this when I built my Model A Hot Rod back in the early 1980's. The advantage to keeping this data is that when you swap major components such as motors, frames, doors, beds, cabs, etc., there can be problems with Johnny Law if you don't have proof of purchase information. Can you prove the parts on your truck aren't stolen or from a chop shop? This is especially important if someone out of state or out of the country buys your truck. Typically this will require an out of state inspection. Some jurisdictions and/or inspectors will require hard copy information showing where the parts came from. Last edited by lakeroadster; 05-01-2010 at 08:02 AM. |
#1212 |
HOW long until spring??
![]() Join Date: Mar 2009
Daughter and I went for the first drive after 11 months of project!!! Gas can strapped to the back!! And away we went-- grinning and laughing till our faces hurt.!!
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 05-01-2010 at 10:48 PM. |
#1213 |
With the help and expertise of two fellows, we spent a combined 9 hours trouble-shooting electrical gremlins on my '66 Chevy C10, only to discover, we still haven't correctly addressed the issue. Tomorrow I am putting a factory reproduction underdash wiring harness/fuse block, specific to a factory dash cluster with gauges. When I bought the truck, as a project, I put new harnesses in it, front-to-back. The underdash harness was for a factory dash cluster with warning lights. By plugging everything togehter with the factory plugs, it was draining the battery. I think we have isolated the drain, so hopefully, we can exorcise the demon.
#1214 | |
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#1215 | |
Senior Enthusiast
#1216 |
I too am trying to figure out some electrical demons
#1217 |
Changed tranny fluid. Drove her around town and then picked up the Mrs. for a trip to the ice cream stand.
#1218 |
Started it for the first time since last September. Considering the amount of wiring to get an LT1/4L60E into a 63 I was amazed it started on the first try. Of course a couple of minor issues came to light but hopefully its driving by next weekend.
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. |
#1219 |
Worked on the '62 today - the '64 hasn't made any progress since I got it stripped to the frame, and I needed to work on something I could feel good about!!!
Tore the steering column apart to replace horn/signal switch and harness. Turns out (aside from the switch having disintegrated from age) that the PO had cut the wiring harness for an unexplained reason and tossed half of it. Now my horn works. Lights don't work, but everything is good at the switch... Got the side window installed (previous passenger window broken out thanks to kids with rocks). Replaced the choke cable and made some necessary adjustments. Starts WAY easier now. Pulled the grille and bumper for a swap. Attempted to install a different grille on her, then discovered (thanks to some help from this site) that the grille I had was for a large truck, not a pickup, so she's faceless...
GMCMG 1964 GMC 1/2 ton LWB project - 1982 GMC 6.2 diesel engine/suspension donor - 1966 Chevy 3/4 ton frame/doors/fenders donor - tons of parts - cause you can't build a truck without 4 of everything! 2001 3/4HD Duramax Diesel extended cab lwb4x4 1984 Chevy C30 6.2 diesel lift truck (project) 1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!) glascock.m@hotmail.com |
#1220 |
UCA63
Finally got my chassis indoors and up on jackstands
got front x member assembly out,frame(front part) cleaned up and primed Next: paint front of chassis,install '75 front xm with disc brakes,PS box,idler arm etc. to get her back on 4 wheels again. Feels good to get back on her again(the truck guys,the truck) I seem to have been hogtied lately (LOL llike, a year)on progress,hopefully I can make good strides this summer T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
#1221 |
I had a very productive weekend. Got my quarter panels painted...
Painted my 65 Impala Steering wheel (I'm putting on the truck this weekend). ...and painted a couple of wheels. I'll post more pics later.
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 |
#1222 |
I curled one of my lower control arms.
![]() Lesson learned- Pick up the truck before you drive it!
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
#1223 |
After searching for over a year, i finally found a world class T-5 transmission from a v-8 camaro. 2.95 first and a nice tall .063 overdrive. this was like the hardest thing to get my paws on for my truck.Will bolt right in to the 62.
#1224 |
Justified!
I drove mine to the cruise in tonight!!!! First time on the road in almost 3 years!!!
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
#1225 |
Daring to be Different
That's the first thing I'll do.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
