05-09-2012, 06:12 PM | #1201 | |
Re: Make it handle
When I gave my truck over to the alignment tech, I gave him a file card with the specs I wanted. When he balked at setting it that way, I told him he could set it to my specs or not get paid. He complained that he'd never heard of such a thing, I told him we learn something every day. I made sure to go back a few days later and compliment him on the job he had done. I want to thank you again for for being willing to share your knowledge with all us peons out hear. Thanks,
Jack Byrd '70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4 '76 Airstream Argosy MH(want a longer one), 454CID, TH400 |
05-09-2012, 07:25 PM | #1202 |
Re: Make it handle
I'm glad you were succesfull. What specs did you set it at? Thanks for the feedback, it helps others try it.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
05-10-2012, 05:12 AM | #1203 | |
Old member
Re: Make it handle
Yes needs a lot more light! I liked the other video's though of the side of the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 05-10-2012 at 08:08 PM. |
05-10-2012, 09:45 PM | #1204 | |
Re: Make it handle
Next I'm going with relocated lower CA's, 1" lowering springs in the front, 2" lowering blocks in the rear and I've recently acquired an 1 1/4" front sway bar off a one ton. I'm considering clipping a couple on inches off the ends of the sway bar and welding on a bracket to use a link to attach it rather than the factory bushing mount. Am I on the right track? Thanks,
05-10-2012, 11:49 PM | #1205 |
Re: Make it handle
sounds great. keep us posted
05-11-2012, 01:40 AM | #1206 |
Re: Make it handle
Gonna be buttoning up the front of my truck soon as well. Got my three inch drop spindles and springs and a flip kit with a 1" drop shackle So it be about a 6-7 drop on my square with the front control arms located one inch forward the rear leafs rebuilt and teflon stripped. Shock relocations front and back. New steering components and bilsteins an a one ton sway bar with heim joints on the ends. After all this a rear sway bar and panhard are in order.
Going to try -1* camber 6-7*caster and 1/8ths toe out. We will see how it goes! Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 Last edited by INSIDIOUS '86; 05-11-2012 at 01:41 AM. Reason: Jesus drives Chevy trucks |
05-13-2012, 02:58 PM | #1207 |
Re: Make it handle
How's my caster looking? Lol Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 Last edited by INSIDIOUS '86; 05-13-2012 at 02:59 PM. Reason: My lateral g's were so intense I had to post twice |
05-13-2012, 04:48 PM | #1208 |
~Rest In Peace~
Re: Make it handle
i would change those old brake lines ,just sayin'
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
05-13-2012, 06:58 PM | #1209 |
Re: Make it handle
Russel steel braideds are in transit to my mail box
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-13-2012, 11:38 PM | #1210 |
A guy with a truck
Re: Make it handle
What ball joints? Concerned with scrub issues on the lowers? Looks like lotsa caster built in. Can you detail your process and any problems you ran into?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-13-2012, 11:48 PM | #1211 | |
Re: Make it handle
I want about 7-8 degrees dialed in if possible. I had to trim the crossmember and the sleeves of the lower control arm bushings. Right now I'm having an issue with my 16" rims rubbing the control arms when I turn to full lock my steering stops are taken off but where the steering stops is before it would ever hit the stop. Posted via Mobile Device
05-14-2012, 02:58 PM | #1212 |
Re: Make it handle
How much did you move the lower arm forward?
05-14-2012, 03:25 PM | #1213 |
Re: Make it handle
Good monday Truckers. First off, I'm glad to see you guys making some changes and trying this stuff. Anything you do that makes you truck safer, and/or a better driver will increase the chances of you driving it. And after all, that is the goal here.
Friday was a long, frustrating, exciting, fun, hot and wonderfull day. The third annual Truckin' Throwdown was the best yet!! This year trucks were split into two classes, 'street' and 'race'. The deciding factor had to do with build style. If the truck can be duplicated with a credit card and a craftsman 256 pc tool kit, it's 'street'. (and by credit card, they mean it's built with parts that anyone can order, not using your visa to pay a guy like me to build you a one off truck). So, if it required extensive welding, fab and machining to build, it's 'race'. This means you can have a 1000 hp stock chassis truck in the street class, and a 350 hp modified chassis truck in the 'race' class. But, I'm on thier side on this one. This event will only get bigger, and more competetive, and the rules will need to be clear. The four track events are a 1/4 mile Drag Race, 700 ft slalom (10 cones @ 70 ft), Speed-Stop (1000 ft run into a stop box), and this year, what I will call the 'Monster-cross' (an autocross with 100+ mph sections that took 1 min 57 sec to run, if you were really fast!) We left my house at 5:30am, I drove Hellboy and the shop crew were in the dually. 35 mi to Corona where we met up with Mike who had taken the 'Bullit home. From there it's 53 miles to El-Toro. Both trucks ran great down the freeway even with So Cal traffic, and Hellboy got 26 mpg!!! WOW, thats a shocker. We topped of at the shell station and drove in to the old air station. Things were already going. First we were informed that the 'Bullit would not be making competetive runs, since it was last years winner, but that Mike could drive in all events. Hey, thats life. Hellboy passed tech, and was definately in the 'race' class. We saw some old friends, and met some new ones. I was shocked at the amount of raw horsepower. three trucks with 1000+! We ran the slalom first, and learned of a new problem, running the slalom at 65+ in 2nd gear, I'm steering at 6000+rpm, and the pump is causing the steering to be VERY tight. I did get some solid runs in, but it was a new feeling, usually I'm off the throttle or part throttle in a corner, not full. A phone call to KRC tells us we need to change the high pressure valve in the pump. After some tire pressure changes it was drag race time. The trans shows me who's boss. It does not like to shift under load from 2-3. I have since found out this is common. This plagued us all day. - and I'm sure it cost some time. All I know is I was at 116-120 mph at the end of the 1/4. During the Speed-Stop, shifting was a problem also, but the new brake pads worked well. On my 2nd run, my foot slipped over just enough to touch the gas pedal for a second, and I went through the stop box by 2 feet. I was a bit pissed on that one, as it would have been my best Speed-Stop ever! Finally it was autocross time, and as we went out for parade laps, it just kept going, and going. Shifting was a must, as some corners were 5-10 mph, and some straights were 100+. Even with the shifting problems this was the coolest autocross ever. I know that Scott Call in his 69 ford ran the fast lap at 1.53, a full 2 sec faster than my 1.55, he makes it look too easy. We did win the race class, and as we get Hellboy sorted out, it shows more and more promise. We took a lot of video, and I'm now learning how to edit. Give me a few days and I'll get some up. Thanks
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 05-14-2012 at 03:48 PM. |
05-14-2012, 05:07 PM | #1214 |
Re: Make it handle
It's forward 1 inch. Lol made me toe out an inch and a half, I need to get an alignment. But even with the toe crazy and nothing aligned. The turn in and cornering seem good. I'm excited to see what it does with an alignment.
I think I may have to get rid of the drop springs and do cut 3/4ton springs to keep the front from moving so much over bumps cause right now I bottom out and it's just to soft of a ride Posted via Mobile Device
05-14-2012, 06:03 PM | #1215 |
Re: Make it handle
Thats awesome ^^^ Out west seems like the place to be for these types of events.
Hey, I have a question about the above suspension. I've heard people talking about the tall or adjustable ball joints. What exactly do they do? I would guess they allow you to get the A arms closer to paralell with each other and the ground but i've guessed wrong many times!!! Info on this subject would be cool, thanks.
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247 |
05-14-2012, 06:10 PM | #1216 |
Re: Make it handle
1" is good. should be able to get 6* - 7* caster easy. lol, you only need a 1/16" to 1/8" toe out, .... not 1 1/8". Just try the 3/4t spring, full hieght if you don't want it that low, but hang on to the drop spindle for now. - remember, only change one thing at a time.
05-14-2012, 06:12 PM | #1217 | |
Garage wrench
Re: Make it handle
It sounds like it was a fun day!
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
05-14-2012, 07:40 PM | #1218 | |
Re: Make it handle
Then it's working on getting the rear to stick in a corner. Which as is I'm sure my front end will outperform the rear unroll the rear has a panhard and sway Posted via Mobile Device
05-14-2012, 07:42 PM | #1219 |
Re: Make it handle
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
05-14-2012, 09:32 PM | #1220 |
Re: Make it handle
These reverse Ackerman angles are killing me! >
05-15-2012, 01:44 AM | #1221 |
Re: Make it handle
It has always made me wonder, if your going to make dropped spindles, why wouldn't you change the ackermen, sort out some bumpsteer, and adjust the spindle hieght for a better camber gain???? but - no.
05-15-2012, 01:48 AM | #1222 | |
Re: Make it handle
Taller, and adjustable ball joints are used to tune/adjust the roll center, and/or increase the camber gain rate. Most commonly they are used in the upper ball joint, Raising the UBJ can increase camber gain, and raise the roll center.
05-15-2012, 12:54 PM | #1223 | |
Re: Make it handle
05-15-2012, 03:03 PM | #1224 |
Re: Make it handle
05-15-2012, 03:21 PM | #1225 |
Re: Make it handle
You asked, so please listen carefully I have cut and welded on many a spindle. Almost always in a situation where I had control over the periodic inspection of the car/truck. My F-100, the 'Bullit, has been on welded spindles fo years. These were the prototypes for our ZG spindles now used on our Wide-Ride IFS. You have to be carefull, you have to start with a good spindle, and you have to weld it, really weld it. If I cut a steering arm off to reposition it, once i have it fitted for the new location, I gring a 3/8" bevel on both the spindle body and the arm to put the weld in. Then i smoothe weld out and fishplate the seam with 3/16 cold roll on the inside and outside. I usually MIG the first welds, then TIG the fishplate. Moving the outer TRE out toward the rotor can help with ackermen, but may start to interfere with the rim. - making the arm shorter can make the steering quicker, both of these can play havoc with the bumpsteer. Usually I'd say not to move it more than 1/2" in any direction.
