08-20-2014, 03:05 PM | #1201 |
Re: 1963 C-10 in NC
08-20-2014, 04:04 PM | #1202 |
Re: 1963 C-10 in NC
Clutch delete plug? Never heard of it. Stepside is a manual, fleetside will be an auto.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-20-2014, 04:20 PM | #1203 |
I'm just glad to be here!
Re: 1963 C-10 in NC
I think he is talking about the plug that goes in the hole that the clutch linkage passes thru on the firewall to the Z bar.
Trucks are looking good.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-20-2014, 04:44 PM | #1204 |
Re: 1963 C-10 in NC
Yeah....I could definitely use one. I was going to weld it up, but I'd rather have the plug.
08-21-2014, 09:07 AM | #1205 |
Re: 1963 C-10 in NC
Got the glass removed last night with help from Austin. Pinch welds all look great. Some light surface rust on the lower corners, but not rot or pinholes...and nothing the wire brush didn't take off. Should be able to finish prep on windshield opening....tape off and primer the rest of the interior tonight. MY goal at least. Hoping to get color down over the next weekend and start reassembly. Then back onto engine/trans.
08-23-2014, 02:19 PM | #1206 |
Re: 1963 C-10 in NC
Got seam sealer down last night. 2 coats sealer and 2 coats base so far. Need 1 more coat base and then clear
08-23-2014, 03:11 PM | #1207 |
Re: 1963 C-10 in NC
Diggin' the Blue!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
08-23-2014, 03:22 PM | #1208 |
Re: 1963 C-10 in NC
Up to 3 coats color..1 clear
08-23-2014, 03:23 PM | #1209 |
Re: 1963 C-10 in NC
08-23-2014, 03:44 PM | #1210 |
Re: 1963 C-10 in NC
08-23-2014, 03:54 PM | #1211 |
Re: 1963 C-10 in NC
No problem.
Last coat clear down. Came out great.
08-23-2014, 04:55 PM | #1212 |
Post Whore
Re: 1963 C-10 in NC
DANG!!! Looks terrific!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-23-2014, 05:24 PM | #1213 |
Re: 1963 C-10 in NC
Not bad for outside, 20gal portable compressor and home depot husky spray gun. Finish came out great, no runs
08-23-2014, 07:44 PM | #1214 |
Re: 1963 C-10 in NC
Looking good!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
08-23-2014, 07:56 PM | #1215 |
Re: 1963 C-10 in NC
Thanks for the kind words. need to touch up the undercoating on the firwall. I did the undercoating 1st and oversprayed on purpose so the seams get double coated. The 3m seam sealer in the squeeze tube was easy to use. My buddy use to do glass for a living stopped by. He'll help me set the glass back in mon or wed next week. Ill hold o# reassembly until glass is in.
Heres a few more pics of finish. 1st one ive sprayed in 18 years.
08-23-2014, 07:59 PM | #1216 |
Re: 1963 C-10 in NC
Will do the doors this week and then prep exterior of the cab.
08-23-2014, 08:05 PM | #1217 |
Re: 1963 C-10 in NC
In case any ones interested:
Primer omni mp281 lacquer Base omni dark pepsi blue 12908 Clear shop line jc630 polyurethane And the clear hardner 4:1 shop line jh6370 polyurethane
08-23-2014, 10:06 PM | #1218 |
Re: 1963 C-10 in NC
Got the glass sealed into the gasket tonight. Will get the trim in tomorrow or monday. Lots of tape
08-24-2014, 06:23 PM | #1219 |
Re: 1963 C-10 in NC
Some more headway inside the cab. Got most of the dash switches in. Floor vents and cab light in. Taped off and sprayed the rear of the cab. And masked off the firewall and touched up the undercoating there.
08-24-2014, 06:28 PM | #1220 |
Re: 1963 C-10 in NC
Few pics of the dash.
Also did the window trim install just a few minutes ago. Undid one 1/4 of the tape, installed trim piece. Ewtaped using what I just removed and repeated process. The trim is the 60-61 wide trim and really makes the glass look good.
08-24-2014, 07:08 PM | #1221 |
Re: 1963 C-10 in NC
Lookin' Good Brother!
08-24-2014, 07:11 PM | #1222 |
Re: 1963 C-10 in NC
08-24-2014, 07:37 PM | #1223 |
Re: 1963 C-10 in NC
08-24-2014, 07:58 PM | #1224 |
Re: 1963 C-10 in NC
Haha, and then start the fleetside fulltime
08-25-2014, 06:43 AM | #1225 |
Re: 1963 C-10 in NC
looks really good and i like that color of blue also. hard to believe it was painted outside... nice job.
