Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 11-08-2005, 09:17 PM   #101
Striker169
Car O'Holic
Striker169's Avatar
Re: Rear Fuel Tank swap
Does anyone have a link or pictures of the gas tank where the filler hole was in the stake holes in the bed?
Striker169 is offline
Old 11-10-2005, 10:17 AM   #102
yank
yank's Avatar
My filler is not run down through the post but I thought I'd show what I'm doing with mine. There's alot of fabrication involved. If you plan to do any heavy hauling in the bed I would not suggest going this route since I had to cut most of the support out of the corner of the bed.
70 C/10 SWB
Go ahead chance it........Columbus did!!!
Steve (Chitlin) Bacon
My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/
yank is offline
Old 11-19-2005, 09:29 AM   #103
ebfabman
yank have you tried to mount the rear bumper with that set up? You may find you won't be able to get the tail light open enough to get a gas pump nozzle to the filler tube. Thats why most set ups like you've got use a rear roll pan instead of a bumper. Your thoughts???.........
ebfabman is offline
Old 11-20-2005, 06:31 PM   #104
yank
yank's Avatar
ebfabman, I had thought about that. AS you can see in this pic I will have no problem clearing the bumper. My tail light pivots in at the bottom so there is interferance with the bumper.
70 C/10 SWB
yank is offline
Old 11-21-2005, 10:12 PM   #105
BowTieMan
BowTieMan's Avatar
Does $75 for just a blazer tank seem high. Thats not with strapes or anything.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline
Old 11-21-2005, 11:14 PM   #106
71swb4x4
71swb4x4's Avatar
If it's in good shape that seems like a great price. Jump on it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline
Old 11-22-2005, 01:08 AM   #107
DangerBoy
Originally Posted by Senator350
i was really thinking about a fuel cell. but i didn't want a gas tank under the bed. so at the risk of being completely origional, i'm installing a diamond plate combo tool box/tank. it is pretty normal for people with 5th wheels to have an aux tank like this. but i really like having the combination and having a 50 gallon capacity. looks attractive, holds alot, strong as hell, easy to get to (no fabbing fuel doors) check out www.transferflow.com just for kicks.
just my $.02
Thats the same thing I'm workin on doin.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline
Old 11-22-2005, 02:09 PM   #108
Longstep70
Junior Member
[QUOTE=yank]My filler is not run down through the post but I thought I'd show what I'm doing with mine. There's alot of fabrication involved. If you plan to do any heavy hauling in the bed I would not suggest going this route since I had to cut most of the support out of the corner of the bed.
QUOTE]
This is cool. This is actually what I have been planning to try but I hadn't seen it done until now. Do you have any more pics? Even larger versions of the first two would be useful. How much room do you have for getting to the cap and getting the fuel nozzle in there? How are you latching the lens up into place?
Longstep70 is offline
Old 11-23-2005, 12:28 PM   #109
dmec
dmec's Avatar
i used 1 from a chevy van. dont know the year. just went to pick a part and measured until i found 1 that would fit. cost $25.
dmec is offline
Old 11-26-2005, 10:15 AM   #110
hoser
Originally Posted by lock
I have the ECC FI version.. not cheap but its a very nice product.
Who is ECC have a link or address?
How much did the tank cost?
Do you have a part number or do they only sell one make model of tank?
How many gallons?
hoser is offline
Old 11-26-2005, 11:50 AM   #111
71swb4x4
71swb4x4's Avatar
Originally Posted by hoser
Who is ECC have a link or address?Thanks
Early Classic Enterprises
http://www.earlyclassic.com/home.aspx
71swb4x4 is offline
Old 11-26-2005, 12:46 PM   #112
BowTieMan
BowTieMan's Avatar
Im a little confused. If I use one off a newer blazer thats fuel injected what to do I do about them pump since I have a carb? I know I use the mechanical but I mean what do I do about the one allready in the tank.
Old 11-28-2005, 11:14 AM   #113
72MARIO
72MARIO's Avatar
I am glad someone got the flip down taillight to work. I spent at least a week trying ot get mine to clear as it returns into the light opening. What are you going to do with the wiring ?
I just decided to fill it thru the bed floor.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Old 11-28-2005, 12:24 PM   #114
Mudder
Mudder's Avatar
Bowtieman. I am running a carb and I used a tank off of a 85 Blazer. It is made for a regular sender. A regular sender will not work in a FI tank. You can buy new tanks for around a hundered buck from Raybucks. They also have all the hardware like straps and senders.
Mudder is offline
Old 12-06-2005, 03:06 AM   #115
gringoloco
A guy with a truck
gringoloco's Avatar
I have pored through every thread I can find on this subject and have not been able to answer this:
Are there existing holes in the frame that can be used for the hanger bolts when using the Blazer/Suburban tank, or will they have to be drilled?
FYI- Classic Performance has a "Conversion Kit" for $169. Cheapest I've found.
Thanks,
Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline
Old 12-06-2005, 09:20 AM   #116
72MARIO
72MARIO's Avatar
There are no existing holes they need to drilled. Not a very difficult job. Hacking the bed cross sill to clear the top of the blazer tank is the hard part.
2005 TAHOE DD
72MARIO is offline
Old 12-06-2005, 09:41 AM   #117
yank
yank's Avatar
My 70 swb had holes in the frame that lined right up with the blazer tank kit.
70 C/10 SWB
yank is offline
Old 12-06-2005, 06:57 PM   #118
72MARIO
72MARIO's Avatar
Oky well the LWB dont. As far as I know.....
2005 TAHOE DD
72MARIO is offline
Old 12-06-2005, 10:34 PM   #119
gringoloco
A guy with a truck
gringoloco's Avatar
Sweet! I'll look for them tomorrow.
Just scored this on eBay:
Click here for eBay linky
-Chris
Old 12-09-2005, 03:29 AM   #120
drh1485
I was given a tank from an 87 w/FI. Is there anyway to use it with a carb on a 70?
drh1485 is offline
Old 12-09-2005, 10:19 PM   #121
webbes
how do you get in touch with fuel cell guy or does he have a website
webbes is offline
Old 12-09-2005, 10:40 PM   #122
Jimbotronics
YA YA
Jimbotronics's Avatar
He's a member of this board - his info is:
Board member: Fuelcellguy
www.aluminumfuelcell.com
FuelCellGuy@juno.com
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline
Old 12-24-2005, 01:53 PM   #123
BowTieMan
BowTieMan's Avatar
How many gallons does that hold? Got any more pictures of it.
Ok I am going to put some sort of a fuel tank in the back of my 70 longbed but still am unsure of a few things. So any 73-87 blazer tank will work with my mechanical fuel pump and all that? And about how low will one hang?
Old 12-24-2005, 01:54 PM   #124
BowTieMan
BowTieMan's Avatar
I dont remeber where I got this picture. What kind of tank is this?
Old 12-31-2005, 03:21 AM   #125
67chevemall
67chevemall's Avatar
$25! good score I'd say that is the way to go!
I tried a cell in the bed and now I have it under the bed.
Now I'm looking for fuel sensor ideas for plastic cells?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline
