Old 12-30-2006, 06:29 PM   #101
jkade
jkade's Avatar
Re: Who has Impala SS rear disc brakes ??
Originally Posted by Ram-Man View Post
jkade, those look nice. Here are what your brackets look like if you got them from glock.
Those look like quality little pieces there. I think I will be happy with those.
Thanx for the pics.
jkade is offline   Reply With Quote
Old 12-31-2006, 04:50 PM   #102
JustLiveIt
JustLiveIt's Avatar
WOW those brackets look good. I think i should have gone with the impala or camaro setup. I have the caddy kit from abspowerbrake and it took some work to get the caliper bracket parallel to the rotor. I think my axle flanges were not welded on perfectly straight. Has anyone had to use shims to get the impala ss setup to work properly?
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 12-31-2006, 07:37 PM   #103
1966C10
New Member
These brackets, are they for the Impala style setup. Thanks for the all the help.
1966C10 is offline   Reply With Quote
Old 01-01-2007, 05:19 PM   #104
Ram-Man
Ram-Man's Avatar
These are for the impala calipers "94-96". These brackets are some quality pieces. They fit like a glove. Should be a nice set up when I'm done.
Ram-Man is offline   Reply With Quote
Old 01-02-2007, 10:15 AM   #105
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
There is a slight possibility that shims will be needed between the new bracket and the OEM bracket to get the caliper centered over the rotor.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-02-2007, 03:55 PM   #106
JustLiveIt
JustLiveIt's Avatar
Okay. That makes me feel a little better about how mine is setup. Thank you for the info.
Old 01-08-2007, 11:52 PM   #107
Col Clank
Has anybody designed a bracket for the 10 bolt rear end to do the Impala rear rotor/caliper swap. Really want to do this at the same time I change the rear gears....TTT
Col Clank is offline   Reply With Quote
Old 01-09-2007, 12:12 AM   #108
Col Clank
Ttt
Old 01-09-2007, 12:29 AM   #109
glock35ipsc
Are you using a car rear end? 10-bolt?
Bob
Old 01-09-2007, 08:25 AM   #110
Col Clank
no truck 10 bolt.
Old 01-09-2007, 11:15 PM   #111
Col Clank
Ttt
Old 01-09-2007, 11:22 PM   #112
powell72
powell72's Avatar
I haven't heard of anyone doing up a set of brackets for a truck 10 bolt, it's not a common swap at all into our trucks.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-09-2007, 11:28 PM   #113
Col Clank
just checking I know that there was a way to do it with Impala rotors and S10 front calipers, speedway brackets.
Old 01-10-2007, 12:56 AM   #114
383 Stroker
383 Stroker's Avatar
Here are the specs on the bracket I made.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 01-10-2007, 10:06 AM   #115
glock35ipsc
Hey ya'll, I have another dozen sets of Impala brackets cut and ready to ship!
A527 Gr. 50 steel, laser cut to perfection! They come with mounting hardware too.
Send me a PM for more information, or check the classifieds.
Bob
Old 01-10-2007, 10:50 AM   #116
Inthuwind
Straight jacket required
Inthuwind's Avatar
Those look great!! I have a question for an easier mount-- could the brackets be cut, so they slide over the axle, instead of taking the axle out?? I have already done the brake mod, but didn't think about this until after. Also, if cut, would it weaken the bracket? Everything is bolted solid. Just a thought for people wanting to do this swap and keeping the axles in. What do you think? I think the kits are cut.~~~
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 01-10-2007, 10:59 AM   #117
glock35ipsc
I had thought of that before I started making them, but then Powell72 reminded me that the axles need to come out anyhow to get the original drum brake backing plate off. But if that has already been removed, I don't see that removing that section of the bracket can hurt anything once secured to the axle flange.
Bob
Old 01-10-2007, 10:59 AM   #118
jkaylor68gmc
jkaylor68gmc's Avatar
I have a question, do they offset the wheels any more than the drum brakes. I have limited clearence and cannot afford to push my wheels out any furthur.
jkaylor68gmc is offline   Reply With Quote
Old 01-10-2007, 11:02 AM   #119
Inthuwind
Inthuwind's Avatar
Originally Posted by 7387chevys View Post
Wonder wow good this would work with hydroboost If anyone has done this on 73-87s please chime in
Shane
I'm going with hydroboost and should have awesome stopping power
(I hope)
Old 01-10-2007, 11:05 AM   #120
Inthuwind
Inthuwind's Avatar
AAhhhh, that's right!!! Good catch! those are great peices you're making. I wish I had caught you before my fabrications, keep up the good work Glock.
Old 01-10-2007, 11:06 AM   #121
glock35ipsc
It will be very minimal, probably somewhere around 3/16" to a 1/4". Whatever the thickness difference is between the part of the drum that sits on the axle, and the same part of the rotor. I don't have a rotor in front of me to measure, so that is just a guess.
Bob
Old 01-10-2007, 11:09 AM   #122
Inthuwind
Inthuwind's Avatar
Also for size of brake line and fitting to run,here's the response from 383Stroker~(thanks)
What size brake lines and fittings did you use on the rear brakes and did you have to use adapters? Thanks in advance.
They are the Impala SS or caprice police factory rear disc lines that I got from GM for about $25 ea. I used a weatherhead part# 1442 brake fitting adaptor that converts the metric bubble flare rubber hose female to 3/16" male standard inverted flare steel line.
The lines from GM come with the bolt and two copper sealing washers for the caliper connection where one frrom a parts house does not.
Old 01-10-2007, 11:09 AM   #123
glock35ipsc
Thanks Inthuwind! Let me know if something else comes up that I might be able to help you out with!
Bob
Old 01-10-2007, 08:41 PM   #124
glock35ipsc
Just so everyone knows, since a TON of people have been asking, I will be working on coming up with a bracket for the 93-9? Camaro calipers that have an e-brake. No promise as to when they will be ready, but my guess is about a month.
Bob
Old 02-05-2007, 07:39 PM   #125
jlaird
jlaird's Avatar
This might have been already discussed, but why is everybody wanting the e-brake? Is it because of safety or is it because you need it to pass inspection. I know in New York State, it wouldn't pass inspection if I didn't keep the ebrake.
jlaird is offline   Reply With Quote
