12-29-2006, 06:01 PM | #101 |
Re: Autometer Cluster Projects
cool---- now i need my wife to see what kind of employee discount she can get on gauges for me
12-29-2006, 06:46 PM | #102 |
So, do the Autometers come with sending units? if they don't can you use what you already have? And they are mechanical, right?
12-30-2006, 01:15 AM | #103 |
They do come with sending units and they can be had mech or elect.
02-15-2007, 04:02 PM | #104 |
More Cowbell....
Mine were all electric, but DID come with the needed sending units....excluding the speed-o-meter. The sender is seperate, because you may have a GM, Ford, or Dodge tranny.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
02-15-2007, 04:46 PM | #105 |
chevy runs deep
02-16-2007, 03:31 AM | #106 |
Nothing clever
So Putter, how much to have a set of dem made, including the gauge prices?
Got "the Midas Touch!" |
02-19-2007, 09:09 PM | #107 |
What are the size's of the speedometer and tach area, do you know if autometer makes the cobalt in that size? I put the 2 3/8 in the four gauge that cross the bottom, looks great, so great that I have to do something with the speed/tach/fuel gauges
Bryan 1971 Chev Shortbed Fleetside Blown 355 605 hp 528 ft lbs torque 1970 Chevelle SS454 LS5 (numbers matching so I have to leave it alone) 2006 Chev Z06 I used to be schizophrenic but we're all better now [] |
02-27-2007, 10:34 AM | #108 |
I am setting my guages now is there any trick to get the smaller ones as close to the bezel as possible for better angle viewing? I have removed the little ribs around the back of the holes. Is there anything else I can do?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
02-27-2007, 12:49 PM | #109 |
More Cowbell....
Franky - YES. Excluding the speedo, they will come with the needed senders.
Cojnit - 'Dey ain't cheep. I have just over $600 in mine (all electric), all new parts. Alemck - Speed & tach are 5", temp (center) is 3-3/8". And if memory serves me, you can get ALL the gauges in the sizes you need with the COBALT series. 76bonanza - I have seen a few guys actually remove the trim ring from the gauges and set it behind the factory lens. Other than that...I don't have any suggestions. (sorry)
02-27-2007, 01:01 PM | #110 |
Tightwad
Hey Putter, i think that is some great work there...wish i was as good as you...maybe in due time....not....Rob should really like that set you got together for him can't wait to see pics of it installed
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
02-27-2007, 07:35 PM | #112 |
Hey putter is it worth the effort or can you see the smaller gauges good when the dash is mointed in the truck?
03-08-2007, 05:14 PM | #113 |
I am draging this thread out again with a feew more questions
First, does the bezel and cluster tilt when mounted in dash looks like it mounts at a angle. second, I got one of those pin conectors from the shack. Seems ok but when I pull the plugs apart it pulls the wires forward some and I have to reset them am I doing somthing wrong?
03-08-2007, 05:55 PM | #114 |
Does anyone know of a tach that can fit in the center hole of the without cutting plastic glass?? I have the Three Hole Cluster and want to have a tach. If not, do you know of a tach that can fit on my steering column (which id rather do) ---Andy
1972 Chevy Truck 350ci/th350 Auto. Daily Driver |
03-08-2007, 07:32 PM | #115 |
I checked the Autometer site & they showed the Cobalt speedo/tach available in 3 3/8 but I didn't see any 5" P/N's. They did list a 3 3/4" & 5" 'pedestal mount' tach.
03-08-2007, 11:13 PM | #116 |
Not Autometer, Stewart Warner. I like that the SW's are different than what everyone else has.
1968 C10 - 383, non-stop project 1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies |
02-19-2010, 11:56 PM | #117 |
Has anyone had any luck finding any 3-3/8" Autometer gauges for the center hole lately? I want to run a 5" Speedo & 5" Tach, and would prefer a fuel level gauge in the 3-3/8" Hole. Just wondering if anyone has any advice on finding one, cause I'm sure not having much luck.
____________________________ 1967 C10 SWB Big Block 4 Speed |
02-20-2010, 12:13 AM | #118 |
You need to search any autometer you can find in the 3 3/8 size then buy the rest to match. Autometer doesn't make them anymore.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
02-20-2010, 01:56 PM | #119 |
Yeah... It's not easy to find anything in that size. Unless it's a tach or speedo, but that would leave an empty 5" hole. I'll keep looking. Or maybe i will leave the center hole blank and use it for some turn signal, high beam and brake light indicator setup
02-20-2010, 02:57 PM | #120 |
2WD Jimmy
Heres a picture of the cluster Putter did for mine. He IS DaMan
02-20-2010, 04:03 PM | #121 |
Champagne Taste on Beer Budget
Man it's too bad they don't make the3 3/8" fuel gauges!
Those look great!!
Coming Soon: Project 1970 Country Truck |
02-20-2010, 05:38 PM | #122 |
Sweet! Those fuel gauges are worth they're weight in Gold!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-20-2010, 07:42 PM | #123 |
Wasn't there a list of all the 3 3/8 part numbers some where on the board.
02-20-2010, 08:02 PM | #124 |
02-20-2010, 08:10 PM | #125 | |
Fuel Gauge -3 3/8" electrical Part #5514 Oil Pressure - 3 3/8" mechanical Part #5505
