Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-10-2006, 12:30 PM   #101
71Dragtruck
71Dragtruck's Avatar
Re: Ran 11.44 @117.69mph
I wanted to get a 1 piece, but nobody wanted to build one that long, they said it wouldn't hold up.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-10-2006, 01:40 PM   #102
nxtruck
nxtruck's Avatar
I think that the 2-piece shafts are stronger than a lot of people think. I always heard jokes from my buddies when we were at the track about seeing parts of driveshafts coming out from underneath my truck on a pass, but it never happened, and I went some 6.70s in the 1/8 with that setup. I finally got nervous enough about it and put the 1-piece in it.
nxtruck is offline   Reply With Quote
Old 07-10-2006, 02:29 PM   #103
71Dragtruck
Mine has been good so far, hope it holds up. It is made of heavy duty 1350 series parts and makes the stock shaft look like a tooth pick.
Sponsored by:
Hard Candy Customs
Old 07-10-2006, 02:46 PM   #104
nxtruck
nxtruck's Avatar
71, if you're running 1350-series parts, then you're definitely running better stuff than I was. All I ever ran was the factory stuff. About every 2 years or so, I'd put a carrier brg., u-joints, and a slip yoke in it. Never had any trouble out of it.
Old 07-10-2006, 03:09 PM   #105
57sailplane
57sailplane's Avatar
hey djracer
did you get your torque convertor problem fixed? have you been running? haven't heard from you for a while..
57sailplane is offline   Reply With Quote
Old 07-10-2006, 07:23 PM   #106
djracer
djracer's Avatar
I have the old one out of my camaro in it right now but I have to get the other one redone to be able to spray it! This one seems to run about the same but I don't want to kill this one!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-17-2006, 03:44 PM   #107
djracer
djracer's Avatar
anybody run this weekend? I just took my two boys and a friend down the track!
Meathead found me glass bedsides and a tailgate now I got to go to Tn.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-17-2006, 04:27 PM   #108
71Dragtruck
And details on the glass tailgate would be???????? Where, weight, how much.
No racing for me, seats are suppose to be in this week, and mine is going in for a roll bar. Have all the parts now to run 10's.
Sponsored by:
Hard Candy Customs
Old 07-17-2006, 05:10 PM   #109
nxtruck
nxtruck's Avatar
I didn't run this weekend. I'm trying to figure out a high-rpm vibration that seems to be drivetrain related. What do you guys run as far as pinion angle is concerned?
Old 07-17-2006, 09:26 PM   #110
bigjimzlll
bigjimzlll's Avatar
Too damn hot to run here..over 110 and we are getting ready to shoot the primer. Going to install the new converter and ultimate playback tach. We are 2 degrees down with the ladder bar set up. I'm going to drop the barsdown one hole to try and get a good shot of a wheelie.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-17-2006, 09:39 PM   #111
djracer
djracer's Avatar
Good luck with the new mods! You need the roll cage! The glass stuff is super thin and just a skin!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-17-2006, 09:52 PM   #112
bigjimzlll
bigjimzlll's Avatar
yea...but...where and how much????? I used a tail gate skin(after market) pretty light and cheap
Anderson,CA
Old 07-17-2006, 11:22 PM   #113
djracer
djracer's Avatar
Meathead found this stuff in Tn but its new never installed. I think its probably from U.S. Body source!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-17-2006, 11:49 PM   #114
bigjimzlll
bigjimzlll's Avatar
I didn't think US body had bedsides....complete beds yes..I'll have to look into it.
Nevermind..they do...not cheap though:O
Anderson,CA
Old 07-18-2006, 01:30 AM   #115
409biscayne
409biscayne's Avatar
Hey Jim
I finally got my truck to 1.99 60ft , not exactly down where you are , but ....
Do you think i would benefit from some front drag shocks ? I'm running new gas da stock replacement from Napa . They seem much stiffer than the rears . Thanks ...................................... 409 .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 07-18-2006, 01:34 AM   #116
bigjimzlll
bigjimzlll's Avatar
are you spinning? What converter? are running the slicks I sold you? Sub 2 second is getting there. What was your MPH
Anderson,CA
Old 07-18-2006, 01:38 AM   #117
bskylerj
bskylerj's Avatar
I did not run at the track but we did get the supercharged beast fired up and ran down the road. It is going to be sweet. At 40 mph I gave it about 3/4 throttle and it left a 20ft long patch and was gone. We still have to play with the timing and carb. It hit 5lbs of boost and I have it set up for now to do 8lbs of boost. I might try the 10lbs sooner than later. Sorry to highjack the thread, just excited to finally drive the beast.
bskylerj is offline   Reply With Quote
Old 07-18-2006, 02:01 AM   #118
409biscayne
Not spinning that i can tell ,does shudder a little , 2400 street fighter , on your slicks , mph only 92. It;s been hot here as well , so et 14.42 - 14.49 ish.
409
Can-Am Motorsports
Old 07-18-2006, 09:00 AM   #119
bigjimzlll
bigjimzlll's Avatar
Front drag shocks wouldn't hurt(except the wallet) but I don't think you will pick up much. When I first started I ran 14.57 at 87mph, so you do have some ET left. Have you played with tuning yet? A quicker advance curve with a higher total timing should help the short time. What distributor are you running.
You can always call me at 530-945-8975
Anderson,CA
Old 07-18-2006, 09:46 AM   #120
71Dragtruck
Right on, JIM'S DRAG TRUCK HOT LINE !!!!
Good job breaking the 2's.
Just remember, when looking at your 60', it's not like a car, that's alot of steel your trying to move. I've taken alot of car's that out 60' me, I have good reaction times, so cross first so you don't notice unless your watching the clock.
You thinking of going to glass bedsides Jim? I wonder what US body's cab weighs?
Sponsored by:
Hard Candy Customs
Old 07-18-2006, 09:50 AM   #121
71Dragtruck
You have to get that thing to the track, slap on a set of slicks and see what she runs. We need to know details like that.
Sponsored by:
Hard Candy Customs
Old 07-18-2006, 09:57 AM   #122
bigjimzlll
bigjimzlll's Avatar
Nope on the bedsides. We talked about it last night. I can remove and install my complete bed by myself. So I figure around a 125lbs. 2 bedsides(outer skin only) and a tail gate skin. So I can't justify the 1000.00 for the glass stuff...and it may even weigh more. I am going to email US body and find out how much the glass doors weight...our doors are real...real heavy.
Anyone that needs help or wants to compair notes..or just say hey can give me a call...I have like 10,000 roll over minutes I need to use...lol
Anderson,CA
Old 07-18-2006, 10:00 AM   #123
djracer
djracer's Avatar
Post us some pics I'd love to see your ride!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-18-2006, 10:11 AM   #124
71Dragtruck
Let us know what you find out about the doors. The pics you showed of your bed, that's complete? You just have side skins and tail gate skin no front, with framework? What do you run for a cover? I've often wondered if a aluminum floor would be worth the cost, I want to lighten mine up, but would like to keep a full bed.
Sponsored by:
Hard Candy Customs
Old 07-18-2006, 10:24 AM   #125
409biscayne
Morning guys
This is my favorite thread . I'm running the factory points distr , with 38 degs of timing , no vac advance , i do have a 6a box and msd distr i could swap in . Whatta ya think of a 75 shot of NOS ?
Not trying to hi - jack , that's my last question .
Thanks ....................................... 409.
Can-Am Motorsports
