Old 07-16-2007, 11:31 PM   #101
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Film Guy Project Build Thread........
Looks great. I was going to find pics of 7t7's bed for you but you already got the job done. Keep it going...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-16-2007, 11:33 PM   #102
N2TRUX
Happy to be here
N2TRUX's Avatar
Scot I think you have it. He has a show quality floor underneath his....show quality floor....
Articles-
"Refining Sierra"
Old 07-17-2007, 01:01 AM   #103
72CSTC5
72CSTC5's Avatar
That truck is ridiculous. Most amazing thing I have seen in a while. I am speechless. Did you ever mention the specs on the rear end and tire and wheel combo for the rear? I want to run big rollers in the rear with a fat lip too on my daily driver. Let me know what you did, in exchange I will paint your bed for you, all you do is supply materials!
72CSTC5 is offline   Reply With Quote
Old 07-17-2007, 01:03 AM   #104
72CSTC5
72CSTC5's Avatar
Oh, sorry double post but when you say you had the sides dipped, did you acid dip them to strip them or did you find someone to EDP coat the bedsides like the factory does?
Old 07-17-2007, 09:55 AM   #105
Film Guy
Junior Member
Film Guy's Avatar
Scotti, Not exactly the sequence of events. I removed all of the clearanced wood flooring and strips. I fabed some 3/4"X3/4" square tubing to mount on top of the cross sills. This simulated the thickness of the wood floor. The bed side sits on top of the 3/4"X3/4". I cut, drilled and taped holes in the 2.5"X2.5" tubing and mounted that on top of the original cross sills. (No wood flooring) Then I mounted another set of cross-sills on top of the 2.5" tubing. Then comes the flooring. There is only 1 wood floor. I am considering raising the stainless fuel tank up into the frame a little more for clearance and this mod may help. I can take some more detailed pics if you would like. Or you can just come over and check it out. Your local.
Film Guy is offline   Reply With Quote
Old 07-17-2007, 10:03 AM   #106
Film Guy
Junior Member
Film Guy's Avatar
72cstc5, The rear end is a ford 9" I ordered from Moser. It was custom built for me. I think it was 56" long. The wheels were made by Forgline. I think they are 20 X 12.5. Hope this helps.
Hey, I just noticed your handle 72cstc5, Do you have a chassis like n2billet is building? or do you have a C5 corvette.
Old 07-17-2007, 10:05 AM   #107
Film Guy
Junior Member
Film Guy's Avatar
randomhero472, I am sure I will make a couple of them before I get one I like.
Old 07-17-2007, 10:13 AM   #108
Rokcrln
Rokcrln's Avatar
Your bed floor looks great! I am also a fan of raising the floor instead of notching it all out. Looks like you went about 7" on your wider tub's. I did this one about 6yrs ago and still love the look. Now I just need to finish it up and find some wider tires to fill in the space. I have 335/35/17 on it right now but they have become very narrow in my view Mine is raised 6" total from stock and I used the sections from my wheel widening to build the 45* ramp at the tail gate.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 07-17-2007, 10:35 AM   #109
hyde
hyde's Avatar
Great ride...Looks killer to say the least!...
06 Crew Cab GMC[/B] on 22's
07 Duramax 4x4 Lifted Maxed Out!
1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad!
1967 Short and Wide. Soon to be an LS1 and bagged
hyde is offline   Reply With Quote
Old 07-17-2007, 10:52 AM   #110
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
Tremendous.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 07-17-2007, 11:24 AM   #111
itsmike2k
Looks great!!! I love the bed.. How much space do you have between your inner bedside and tires? Could you measure how wide from outside edge of one tire to outside edge of the other for me? I dont have a bed yet and wanna make sure the BS of my wheels are correct before they build them.. Thanks alot and keep up the good work!!!
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 07-17-2007, 11:26 AM   #112
SCOTI
SCOTI's Avatar
I considered doing something similar but using a cut up steel floor as my 'base' that the bedsides bolt to & then making the wood floor a 'faux' type floor. This seemed to be the most structurally 'solid' way to go but I didn't want the additional weight.
I'm still playing around w/various ideas (currently just have the steel floor spaced up 3").
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-17-2007, 01:49 PM   #113
Spanky_Pete
Too many trucks? Nah...
Spanky_Pete's Avatar
That is simply spectacular. Cannot wait to see more of it as you progress.
Spanky_Pete is offline   Reply With Quote
Old 07-17-2007, 01:56 PM   #114
1LoC10
Insert Title Here
1LoC10's Avatar
that truck is badass...
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-17-2007, 02:48 PM   #115
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
That looks so good! Realy nice!
LOW DOUGH is offline   Reply With Quote
Old 07-17-2007, 07:05 PM   #116
blaznhot_23
blaznhot_23's Avatar
Here's an update...The floor had to be raised a few inches so I put another set of cross sills on top of 2.5"X2.5" square tubing. Which I mounted on top of the original cross sills. Sounds complicated but it's not.
So all you did was in essence sandwiched the square tubing between the floor supports which raised the floor up correct???
blaznhot_23 is offline   Reply With Quote
Old 07-17-2007, 07:15 PM   #117
blaznhot_23
if you don't mind that would be great
Old 07-17-2007, 10:00 PM   #118
72CSTC5
72CSTC5's Avatar
No, I have a 2wd Blazer which is technically a C5 and not a K5, I wish I was running the c5 vette suspension. I had a c5 convertible but sold it. Wish I still had it sometimes. Love the truck and thanks for the specs.
Old 07-17-2007, 10:07 PM   #119
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Amazing
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-17-2007, 11:19 PM   #120
72highlander
Sophomore Member
72highlander's Avatar
hey ron, looking great! the bedsides look good, have you had them worked or is that just primed. i noticed the stake holes intact so that's why i was wondering.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 07-18-2007, 12:41 AM   #121
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Must be nice lol
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 07-23-2007, 07:29 PM   #122
soala70
soala70's Avatar
this one got to get a bump!!
bogey5
soala70 is offline   Reply With Quote
Old 12-07-2007, 01:09 AM   #123
gunkis84
gunkis84's Avatar
been a while truck finished yet? want to sell?
gunkis84 is offline   Reply With Quote
Old 12-07-2007, 01:19 PM   #124
SCOTI
SCOTI's Avatar
Nope.
It's still @ the shop w/the bed off & on a stand getting metal work done ( @ least that's where it was Monday night).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-08-2007, 08:07 PM   #125
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
How did I miss this thread... WOW..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
